Member # 82908
sbr vs pistol
what are the legal differences? i see "pistols" in rifle calibers and rifles in "pistol" calibers...
does it all boil down to have a stock or not? if so, if you make a rifle that cannot accept a stock, is it then a pistol? |
Member # 11727
basically... yes... if a pistol has a stock, its a SBR. And I believe if a pistol has a forward grip its an AOW
~Ryan~ If Danger came from the tap, I'd shower in that shit! |
Member # 82908
so, if i take a vz 58 and mill the mounts off for the factory stock and weld up any holes in the back, i should (in therory) not have to extend the barrel out to the legal 16" required for a rifle?
#4 (permalink) | |
Smores!
Member # 1889
Additionally, 922r does not apply to pistols, only rifles, so you don't need compliance parts, either. I think I remember hearing that 922r also does not apply to NFA stuff--IIRC, it was in the context of "compliance parts were more expensive than a tax stamp, so I SBR'd my...." Double check that before taking it as gospel, though. |
Member # 11598
Correct, 922r does not apply to NFA items. Also, there are many pistols that could be fittted with a foregrip easily (threaded in, change foregrip, etc). For instance, AR pistols could easily have a stock added, but as long as there is no stock on it you're good to go.
You can add a foregrip and AOW or SBR your pistol. However, if it's a AOW you cannot add a stock. Laws are confusing, and they generally don't make sense!
This space for rent. |
Rapey
The real question is: why go through the effort of milling and welding on a receiver, when you can just as easily weld on a muzzle brake to get you to the legal length?
Seems like a lot of work for not a lot gained.
Think you're a marksman? Test your skills by joining the 200yd Iron Sight Challenge happening NOW in the OSR Forum: http://www.pirate4x4.com/forum/outdo...-may-31-a.html |
Member # 82908
i was just using the vz as an example....(mostly because it is sitting in front of me).... i saw the ak pistol in a thread on here a few weeks ago, and it got me thinking about a small weapon that shoots rifle rounds....
lets go Squatchen
Member # 14561
Scott and Jason have provided the correct info regarding SBR, AOW, and (22r.
FWIW if you live in a state that allows an SBR, it really is worth it. I am really starting to think that everyone should register at least on AR lower as an SBR. You can put any upper you want onto the registered lower. i just feel that it's really worth it.
Want to know how I lost 25lbs in 9 weeks? Try INSANITYŽ. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT |
#9 (permalink) | |
Member # 11598
#10 (permalink) | |
Member # 105338
Depends on how your receiver was sold. If it was logged as a "rifle" you're hosed. If it was logged as a "bare receiver" or "pistol" you can get away with it, but I'd document the build... Once a rifle, always a rifle. |
#11 (permalink) | |
#12 (permalink) | |
Member # 82908
what do you mean by document it.. in order to register a SBR, do you just get a form from the ATF, fill it out and send it back with some money or what? |
#13 (permalink) |
Member # 35318
yes
[QUOTE=FordFascist;8565189] My solution: CCW and Open Containers. Just like the South and if you'll notice, people are much friendlier down there.[/QUOTE] [I][CENTER][FONT="Arial Black"][SIZE="3"][COLOR="blue"]Find me on [URL="http://www.gunbroker.com/Auction/SellerAuctions.asp?User=812872"]Gunbroker![/URL] [/COLOR][/SIZE][/FONT][/CENTER][/I] |
#14 (permalink) | |
Member # 35318
If you are going to register it as an SBR anyway, it wouldn't matter. Here is an ATF letter concerning building a pistol from an AR receiver. http://www.jcweaponry.com/images/ar15/BB.JPG
#15 (permalink) | |
Hell, I'd consider registering my FAL receiver as one, too. |
#16 (permalink) | |
Member # 2099
Yes. I'll be registering my AR lower and Saiga 12 as SBRs as soon as I can afford to. I also just mailed off a form 1 for a .22 suppressor and a form 4 for my YHM .308 suppressor |
#18 (permalink) | |
Biohazard
Member # 3088
It would be an SBS.
Wanted, Ak parts, kits or whole rifles! |
#19 (permalink) |
please fix my runner
in order for it to be an AOW, it has to have NEVER had a buttstock attached to it at all. And AOW=$5 transfer rather than $200.
4.3runner ---A golf course is a pointless exploitation of a perfectly good rifle range--- buy my ultra rare Omega III presentation rifle special price $42500.00 |
