Suppressor design and development - Page 17 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-27-2012, 07:17 AM   #401 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
Originally Posted by 4runner View Post
I have access to a hydraulic stamp press we use to make small steel plates which screw onto motorcycle side covers...working on a set of dies that would allow a one-step forming pf the baffles which took 3-4 steps in the video.
So, 1"? 1.25"? 1.5”? 2"? All of these?
Here is a pic of some copied from Maxims design...
Those came out nice. Stainless?
Want to know how I lost 25lbs in 9 weeks? Try INSANITY®.
www.beachbodycoach.com/petermhope
I love it when a plan comes together
Colorado Springs, CO Based FFL-07/SOT
aloharover is offline   Reply With Quote
Old 01-27-2012, 07:36 AM   #402 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
For your reading pleasure
http://www.google.com/patents?q=fire...Search+Patents
Old 02-01-2012, 07:48 AM   #403 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
Muzzle Brake
I do not have a mill (yet) and I am trying to come up with a brake/suppressor mount.
The YHM mount is patented. So while I could get away with cutting there ACME specs onto my can, I better not try and sell that can.
Making the can have a standard 30cal 9/16 or 5/8 thread is possible but I like the idea making the can a little easier to remove.
So on the left is the piece that threads onto your barrel. Internally threaded 9/16 or 5/8. External threads are going to be some 1" ACME standard pitch. The external taper is designed to meet with the same taper on the can itself. The idea being that your screw the can on until the taper 'seals' This keep gas and crap from leaking and getting onto the threads.
The brake itself is a 1.75x.75 piece of stainless. Center bore the entire thing .32". Then bore out the first 1.25" depth to an ID of .65". I was thinking of a series of radial holes around the center bore from this initial chamber, into the second chamber. The second chamber will open to the sides, like the end of this.
I dont know if this would be threaded to the 'mount' piece thus providing a easily replaceable blast shield or maybe press fit and weld.
The part on the far right is the beginning of the can itself. Right know it is going to be 1.75x8x30cal.
The initial chamber is 2" long and then each successive baffle will be .25 smaller with the last one being 1" long.
Baffles will be stepped cones posted earlier.
I got a foot of 1.75 stainless tube and solid rod yesterday. i have the scaled plans all printed out so I am ready to start cutting baffles. I have never done acme threads so will have the basic can done, and simplify the mount.
For now I am going to just make the muzzle end end-cap direct thread onto the barrel with the 2" blast chamber. Basically the muzzle cap and the peace in my plan at the far left will be one piece.
After I get acme done, I will turn down the OD on the end cap to 1" cut the acme and taper and then make a new end cap.
Old 02-01-2012, 07:54 AM   #404 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
Pete, if you are wanting to try steps I can send you a bunch of titanium valve spring retainers to try. We can hash out trade later
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
You cant ban knowledge, learn to make your own guns right Here.
New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight.
usmcdoc14 is offline   Reply With Quote
Old 02-01-2012, 08:12 AM   #405 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
All my reading about titanium makes me want to avoid it for baffles.
Old 02-01-2012, 08:17 AM   #406 (permalink)
usmcdoc14's Avatar
Member # 13344
inconel?
Old 02-01-2012, 08:19 AM   #407 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
I can weld and machine 316. I just cant see any reason to get all fancy.
4 baffles, some spacers, end caps, out tube. 30 cal can that can be taken apart. Pretty straight forward to build. Think I can sell them for 450.
On the .22 I have redesigned the monocore. Tube, end cap, monocore all anodized alum, 9black or OD green) Then the muzzle mount and blast chamber are stainless. going to weigh 5-55.oz. Not super light weight but respectable. Maybe consider it more of a rifle can than a pistol. 150-175$.
Anyway, I don't see mass producing these, but a couple here and there. If I can sell a couple will then buy a DRO for the lathe.
Old 02-01-2012, 09:04 PM   #408 (permalink)
Member # 132925
A quick question how thick are yall making the back end caps for a .22? Are yall doing a a full .5, or some variation?
Citzen_Hawk is offline   Reply With Quote
Old 02-01-2012, 09:41 PM   #409 (permalink)
Biohazard
Gozuki's Avatar
Member # 3088
Half inch is incredibly thick.
Originally Posted by fatdan460 View Post
it leads to real abuse, like guys who will smack a broad in the head
For Sale!! F150 5x135mm wheels!!
Wanted, Ak parts, kits or whole rifles!
Gozuki is offline   Reply With Quote
Old 02-02-2012, 05:43 AM   #410 (permalink)
rockmup's Avatar
Member # 16699
OAL is .625. Standard length threads for rifles is .600 including relief
Pistols are all over the place but generally .435
07/C2 SOT
/Making guns and fun toys, one hammer swing at a time
Need quality ammo ?
AMERICAN LEAD DISTRIBUTORS
Need a POV system ? REPLAY XD
rockmup is offline   Reply With Quote
Old 02-02-2012, 12:21 PM   #411 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
My 22 tubes are 1x6
My muzzle end are .5x1dial stainless rod. Internal threaded .5x28 and externally .92x32
I want to make a custom bit that will create a u shaped channel between these two areas to remove weight and the OD thread only needs to be .25 so the end cap may end up looking like a T
Old 02-02-2012, 02:58 PM   #412 (permalink)
please fix my runner
4runner's Avatar
Member # 946
Send a message via AIM to 4runner
Very small hole saw?
4.3runner ---A golf course is a pointless exploitation of a perfectly good rifle range---
buy my ultra rare Omega III presentation rifle special price $42500.00
4runner is offline   Reply With Quote
Old 02-02-2012, 05:16 PM   #413 (permalink)
NEWMANS OWN's Avatar
Member # 24650
Originally Posted by aloharover View Post
My 22 tubes are 1x6
Are you working on 5.56?
NEWMANS OWN is offline   Reply With Quote
Old 02-03-2012, 01:02 PM   #414 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
Jumping to 30.
Just got the materials in. Will see how much I can get done this weekend.
Was chatting with a friend the other night and he thinks I should scale up the mono core. 1.75 alum rod and 1.5 forstner bits.
Old 02-03-2012, 01:08 PM   #415 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
Figured I would look at some commercial offerings.
First up is the mite. Mount is on the right of tube. it is stainless and looks to be .5. Not sure how it's fixed to the alum end cap.
Baffles alum, with blast stainless blast baffle at far left
Sparrow. One piece mount and baffle stack. Honestly don't know if alum or what
Element. Mount is on upper right. Pretty thick.
Element, Sparrow, Wraith, Pilot, Mite
Wraith and Pilot do not come apart
I am really thinking about cutting the ends off, and making my own end caps for them.
Old 02-03-2012, 02:44 PM   #416 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
How does the wraith sound?
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is offline   Reply With Quote
Old 02-03-2012, 05:19 PM   #417 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
To my ear the Element is the quietest, the rest are all the same. Then mine, just a tiny bit louder. Don't need ear plugs for any of them. P22 host, fired in the garage with the doors closed.Will try out a different baffle design and see how that does.
This is the completed baffle.
This last can I made is 5.5"x.985 and weighs 5.0oz. I am very happy with those physical dimensions. I went ahead and measured of the COTS cans.
Mite is 5.25x1.04 4.1oz
Wraith is 5.5x1.26 6.7oz
Pilot 5.25x.998 5.1oz
Sparrow 5x1.07 6.9oz (the heaviest)
Element 5.5x.985 5.0oz
Old 02-04-2012, 09:53 AM   #418 (permalink)
Member # 132925
Thank yall
As I suspected with a 1" dia tube there is not a lot of room for varying designs.
I did find an over the barrel design: ( The pic is HUGE )
http://sub-silentsuppressors.com/wp-...pressor-02.jpg
Same guy also does some ports on the buisness end that I havent seen on most of the commercial suppressors
Old 05-04-2012, 07:32 AM   #419 (permalink)
Biohazard
Gozuki's Avatar
Member # 3088
As a matter of fact I am thinking about this for a new jig
Old 05-04-2012, 09:29 AM   #420 (permalink)
Biohazard
Gozuki's Avatar
Member # 3088
Old 05-04-2012, 12:35 PM   #421 (permalink)
rockmup's Avatar
Member # 16699
I want one mike
07/C2 SOT
Need quality ammo ?
Old 05-04-2012, 02:16 PM   #422 (permalink)
Biohazard
Gozuki's Avatar
Member # 3088
I'm gonna hafta charge more than I did for this one
I tried doing the side holes first, but they caused the long thru hole to deflect almost 0.010 at the end of the 6.5", so I remade it and did the long hole first on the second one. The ten thou probably wouldn't make any difference, but it wasn't right and it pissed me off.
Old 05-08-2012, 02:22 PM   #423 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
I'll buy dinner next time I visit
Old 05-08-2012, 03:36 PM   #424 (permalink)
Biohazard
Gozuki's Avatar
Member # 3088
I've got to get it to the PO first. Working OT is hard on bank and post office runs...
Old 05-09-2012, 05:59 PM   #425 (permalink)
lets go Squatchen
aloharover's Avatar
Member # 14561
Not to mention seeing your kids
