#52 (permalink) |
Petty Amm Flipper
Member # 14561
you ned the taper inside of the threads.
Want to know how I lost 35lbs? Try INSANITY®. www.beachbodycoach.com/petermhope I love it when a plan comes together Colorado Springs, CO Based FFL-07/SOT |
#53 (permalink) |
Member # 5110
Of course. As I said "just like a big AN fitting". You could even use the same 37° taper. It would do a very good job of holding the can together to keep the exit hole from shifting.
Link to thread on my calculator http://www.pirate4x4.com/forum/showthread.php?t=204893 |
#54 (permalink) |
GREEN BASTARD!!!
Member # 123458
just take a nut(same thread as barrel) weld it to a washer then weld some exhaust tubing to the washer, stuff with steel wool and cap it off with another washer.
It's a hell of a thing, killing a man. You take away all he's got, and all he's ever going to have. |
#55 (permalink) | |
Petty Amm Flipper
Member # 14561
![]() ![]() What are you smoking?
#57 (permalink) | |
Member # 20728
Whatever floats your boat I suppose.
#59 (permalink) |
Marines deleted mine
Member # 84339
black text, dumbass, black text.
![]() :fucking noobs, I swear :angryobamaman:.
The definition of irony: http://www.pirate4x4.com/forum/attac...1&d=1334801294 Yeah, Janelle R Becher is a cunt
#61 (permalink) |
Member # 16699
clean up on isle 3 Doc !
__________________ 07/C2 SOT /Making guns and fun toys, one hammer swing at a time Need quality ammo ? AMERICAN LEAD DISTRIBUTORS Need a POV system ? REPLAY XD Last edited by rockmup; 04-10-2009 at 04:03 AM. |
#62 (permalink) |
Petty Amm Flipper
Member # 14561
#63 (permalink) |
Fistful of Boomstick
Finished...almost
![]() stainless body and endcaps that index the monolithic baffle inside. the baffle is the "working" part and does not require the "can" for alignment. The baffle is aluminum with a stainless steel .250 ID "liner" down the entire bore, the first baffle and the threaded attachment are stainless. The baffle fits loose in the can without the O rings shown, with rings in place each baffle is air tight. It works VERY well oh and her name is Jenny, I hope the guy doing my tax stamp had a sense of humor because he would have known the can's name based on my serial number
Doc-14 Tactical Products: When it absolutely, positively needs to be made from random crap found in the back of my garage. You cant ban knowledge, learn to make your own guns right Here. New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight. |
#64 (permalink) |
also if you notice the first and last baffle are the only ones that are symmetrical with the single first being centered and same with the last "double" hole.
The end caps are made for easy removal. I may fuck with new baffle design or just leave this one as is.
#65 (permalink) |
Member # 5110
Do you have a hard time saying the serial number without saying niiiiieeeeeiiiiiinnnnnneee at the end
I wonder how many other cans are out there with the same serial.
#66 (permalink) | |
I don't think there are that many individuals like me out there
#67 (permalink) |
oh and Bev got more amusement out of the reason on my form more than the number:
reason for building: Hearing Conservation
#69 (permalink) |
You put all that work into the silencer and then you go and hand engrave your info and SN on it? You should have gotten it engraved professionally
I realize you're a cheap bastard, but I'm sure you could have found a guy to engrave it for some gunfuckery or something you have floating aroudn your house.
Brennan
Nemo me impune lacessit |
#70 (permalink) | |
that hand engraving will be gone as I plan on fluting the can and those marks will be cut out after new "nice" ones are engraved into it. ![]() There is no point into putting effort into a simple thing when you plan on changing shit
#71 (permalink) |
Petty Amm Flipper
Member # 14561
Nice.
You left more material then I expected. Whats the final weight? What size chambers 1/2"? Why did you decide on a loose fit?
#72 (permalink) | |
Biohazard
Member # 3088
I know someone who can do the fluting and engraving...
Wanted, Ak parts, kits or whole rifles! |
#73 (permalink) | |
1/2" to allow easy cleaning as I can replace an O ring easy if I have to hammer out the stack because I was lazy to clean ![]() you work in trade right now? I am light on cash and heavy on other shit
#74 (permalink) |
I think I am getting baffle strikes
hard to tell with what my target is so I will have to go to the range.
