Suppressor design and development - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-20-2009, 08:24 PM   #1 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
This thread is for those who can or will LEGALLY make a firearm silencer. It will be for designs and ideas for baffles, attachments and all other aspects of a sound suppressor.
This is NOT for information to be used in the illegal manufacturing of ANYTHING. All builders should understand the guidelines required for legal ownership and manufacturing of sound suppressors. None of the posters in this thread are responsible for any of your stupidity or legal ramifications.
This thread is NOT for you to be asking "how can I legally build a silencer", you should already know that answer and have the tax stamp IN HAND before going anything beyond design.
So, lets have fun
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
usmcdoc14 is offline   Reply With Quote Quick reply to this message
Old 02-20-2009, 08:26 PM   #2 (permalink)
LiLBucket's Avatar
Member # 79539
Great.
Another thread I won't be able to afford.
but somehow will
I'm still waiting on my paperwork
This space now for rent. No free adds here!!! :flipoff2:
LiLBucket is online now   Reply With Quote Quick reply to this message
Old 02-20-2009, 08:31 PM   #3 (permalink)
usmcdoc14's Avatar
Member # 13344
As of this writing I am waiting on my tax stamp. I have done NO machining and am working only on design. All parts I have are nothing more than pipe. This will be for a 22lr.
I plan on making a mono stack something like this:
But the blast chamber will be centered with all other chambers "skimming" the bore instead of overlapping like this
So, questions:
How tight should the bore be for a 22lr? .24 good?
What should I use as a sleeve retaining compound to hold the bore liner and initial blast chamber ? Loc-tite?
Will stainless work for a bore liner and blast chamber liner or should I go with titanium ?
Should I undersize the mono stack and insert O-rings between each chamber to facilitate easier cleaning and to give a MUCH better seal than just a slip fit?
Old 02-20-2009, 08:32 PM   #4 (permalink)
4runner's Avatar
Member # 946
Send a message via AIM to 4runner
maybe someone should post up some photos of baffles from a suppressor so that others can see what they look like?
if you can look past the grit buildup...
4.3runner
4runner is offline   Reply With Quote Quick reply to this message
Old 02-20-2009, 08:41 PM   #5 (permalink)
usmcdoc14's Avatar
Member # 13344
if I recall correctly you may be needing some new baffles for that one as well
Old 02-21-2009, 05:15 AM   #6 (permalink)
ItsaCJ6's Avatar
Member # 6340
Some how that looks suspiciously like an autoclave part.
shameless plug.....For the best deal on 8 lug disc brakes click here-->
Marc
In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good."
Love and kisses, Zaphod..
ItsaCJ6 is offline   Reply With Quote Quick reply to this message
Old 02-21-2009, 05:39 AM   #7 (permalink)
Member # 2099
So, questions:
How tight should the bore be for a 22lr? .24 good? depends on how straight you can bore the hole and how concentric the threads are. For mine, I bought a 20" GM barrel for my 10/22. I'm going to cut it off at 12" inches, then use the remainder for the core of my suppressor. I'm going to open it up to .25 I think. This should get rid of the rifling, but still be tight enough. I think I've read that up to about .265-.270 is good for 22lr.
Should I undersize the mono stack and insert O-rings between each chamber to facilitate easier cleaning and to give a MUCH better seal than just a slip fit? I would definetly put o-rings on each end to make sure everything seals nicely. Now if you're talking about mulitple o-ring down the length of the body, I could see them getting filled with gunk and making it real hard to slip the outer tube off
BTW, I'm also waiting on my tax stamp for a .22lr
LostIt is offline   Reply With Quote Quick reply to this message
Old 02-21-2009, 05:44 AM   #8 (permalink)
Member # 2099
To further aid in keeping this thread clean, if you have any questions on the legalities or what must be done to build a suppressor, go here and read http://www.silencertalk.com/forum/ Pay specific attention to the silencer smithing forum
Old 02-21-2009, 05:47 AM   #9 (permalink)
Member # 2099
no just working on drawings and figuring. I can't do anything till my stamp gets back. I was wondering what to reinforce the blast chamber with, either stainless or Ti.
Do you have both materials on hand?
Old 02-21-2009, 03:49 PM   #10 (permalink)
Gozuki's Avatar
Member # 3088
how well does titanium hold up to erosion?
Good to extremely good. There are hundreds of Ti alloys used nowadays.
Most 9 ' s are capable of firing 380 and if push really came to shove, you can fire .357 and 38 special through one.
Gozuki is offline   Reply With Quote Quick reply to this message
Old 02-21-2009, 04:07 PM   #11 (permalink)
usmcdoc14's Avatar
Member # 13344
nope
I think I may go stainless as my ability to machine Ti is.....unknown
Old 02-21-2009, 04:22 PM   #12 (permalink)
Gozuki's Avatar
Member # 3088
Mine is. I have some grade 5 and 11 on hand...
Old 02-21-2009, 04:39 PM   #13 (permalink)
I build stuff
aloharover's Avatar
Member # 14561
I am using stainless machinable 303 I believe
It's all fun and games 'till someone loses an eye, then it's just fun you can't see.
1970 Land Rover Series IIa 105". 5.3l L59, 4L80 MT1, NP241, F&R D110 Salisburies
aloharover is offline   Reply With Quote Quick reply to this message
Old 02-21-2009, 05:59 PM   #14 (permalink)
Gozuki's Avatar
Member # 3088
303 is easily machinible, but usually unweldable.
Old 02-21-2009, 06:12 PM   #15 (permalink)
usmcdoc14's Avatar
Member # 13344
how hard is it to machine? basically I would sleeve the ENTIRE bore with tube and the first chamber.
Old 02-21-2009, 06:16 PM   #16 (permalink)
Member # 2099
nope
We use alot of stainless tubing at work, and always have scrap, so I may be able to get you some, depending on what OD and thickness you need
Old 02-21-2009, 06:18 PM   #17 (permalink)
usmcdoc14's Avatar
Member # 13344
I will make it from scratch. hold while I merge some posts to this thread.
Old 02-21-2009, 06:23 PM   #18 (permalink)
Gozuki's Avatar
Member # 3088
Ti is not diffifcult to machine. It's not as abrasive as the high nickel super-alloys, but it's definately tougher than 316-303. Go easy any make sure you have good coolant flow.
Old 02-21-2009, 06:26 PM   #19 (permalink)
usmcdoc14's Avatar
Member # 13344
I have no coolant on my work bridgeport
Old 02-21-2009, 07:39 PM   #20 (permalink)
I build stuff
aloharover's Avatar
Member # 14561
Luckily i all held together with threads and the like.
The blast chamber is going to be a press to fit in the first baffle cavity.
Old 02-28-2009, 11:55 AM   #21 (permalink)
usmcdoc14's Avatar
Member # 13344
I ordered the stainless, I have an idea
Its going to be like the above baffle but the aluminum will be used to "hold" the stainless baffle sleeves. The aluminum will be in the middle and the sleeves will stick out and contact the inside of the tube.
Old 03-01-2009, 03:22 PM   #22 (permalink)
NEWMANS OWN's Avatar
Member # 24650
only thing I can add to this thread. hope the pic helps
NEWMANS OWN is offline   Reply With Quote Quick reply to this message
Old 03-01-2009, 03:23 PM   #23 (permalink)
Member # 24650
1.HTG Eureka 5.56mm
2. HTG Aris 5.56mm
3. HTG Universal .22 cal
4. KAC SR25 7.62mm
5. KAC Navy 9mm
6. Gemtech M4-96D 5.56mm
7. Costal ???
8. SWR Wolverine 5.56mm
9. AAC Scar SD 5.56mm
10. SRT Hurricane 5.56mm
11. Gemtech M4-96C 5.56mm
12. AAC M4-2000 5.56mm or M4-1000 ,M4-2000 07'models???
13. KAC NT4 5.65mm
14. Gemtech Trinity LID 9mm
15. AAC Evo 9 9mm
16. Gemtech Raptor 3LUG 9mm
17. Brugger &Thomet 9mm
Old 04-08-2009, 11:38 AM   #24 (permalink)
I build stuff
aloharover's Avatar
Member # 14561
Can Designs
So right off the bat lets start of by saying that you need an approved Form1 or a valid current SOT.
Working on my first .22lr design and I have it so both end caps will unscrew from the tube.
I want to place a groove in each cap inside of the threads. idea is to place an o-ring here to help prevent crud from getting to the threads and make future disassembly easier.
What type of material does the oring need to be made of?
Old 04-08-2009, 11:52 AM   #25 (permalink)
PONY_DRIVER's Avatar
Member # 44662
delrin?
"I'm strangely comfortable with it."
PONY_DRIVER is offline   Reply With Quote Quick reply to this message
