inexpensive TSA approved hardcase - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-15-2009, 10:02 AM   #1 (permalink)
Mo
Everyday is Tuesday.
Mo's Avatar
Member # 47
are those doskosport cases TSA approved? my google-fu is weak today. other options?
Mo is offline   Reply With Quote Quick reply to this message
Old 07-15-2009, 10:34 AM   #2 (permalink)
NEWMANS OWN's Avatar
Member # 24650
In a quick spot. I just bought the $20 deal from wally mart. It had spots for locks on it and it passed through no problem. I think it just has to have locks on it.
I felt like an ass having 2k in a $20 carrier though.
NEWMANS OWN is offline   Reply With Quote Quick reply to this message
Old 07-15-2009, 10:49 AM   #3 (permalink)
Member # 1889
I think so, but I have a rifle one and they're not real impressive, and TSA regs now say that if the case can be easily pried open, it won't pass. It has five padlock holes, and if you regard drifting out unprotected hinge pins as "easily", I could "easily" have that case empty in five minutes even with five padlocks on it. If you assume that the hinge is "secure", then a minimum of three padlocks are needed (both corners plus in the middle of the handle) to make the case remotely close to secure. Part of the problem is how flexible the plastic is--makes it unlikely to be damaged itself, but it doesn't protect well against crushing, bending, or prying. I'm also fairly confident that with a box cutter and a couple good blades, I wouldn't even need to drift the hinge pins, I could probably just slice the case wall out and have the contents.
Pelican cases stomp the hell out of nearly everything else out there, IMO, but their pricetag is substantial too. I want one, and truthfully, $200 for a case that nice, is a deal, but I just don't "need" one badly enough to spend that kind of cash on it yet.
Scott@Rockstomper is online now   Reply With Quote Quick reply to this message
Old 07-15-2009, 10:51 AM   #4 (permalink)
Sully's Avatar
Member # 12121
Send a message via MSN to Sully Send a message via Yahoo to Sully
I've flown with super-cheap cases before, but I usually use an older SKB case that I picked up at a good deal. It works great and was a lot cheaper than a nice pelican.
[COLOR=skyblue]Live Free or Die[/COLOR]
[COLOR=BLACK]Why is mankind the only species that attempts to preserve the shallow end of its gene pool?[/COLOR]
Sully is offline   Reply With Quote Quick reply to this message
Old 07-15-2009, 11:46 AM   #5 (permalink)
TNToy's Avatar
Member # 5776
I used a $30 RedHead case I picked up at Bass Pro.
A minute with a screwdriver would probably defeat it easily, but it worked fine. The counter people barely glanced the case. I probably could have used tupperware with a padlock clipped to it if I had wanted.
Flew last month with my Glcok 19 on Delta/Northwest. Print out the TSA regs, and the airlines regs. Highlight the part where the 'unloaded firearm' tag goes on the OUTSIDE of the locked case... Everybody thought it went inside. What the hell is the point of putting a tag inside of a case no one can open?
Also highlight the part about where ammo can go.
I field-stripped the gun and had the barrel lying seperately in the case. The counterperson stil asked if it was unloaded. And again if I was certain. Probably not a firearm enthusiast.
The tag is just a slip of paper. Next time, I'm sticking a few 6" long pieced of tape to the case that I can peel up, and use to hold the tag to it. My tag was just lying on the case inside of my bag.
Any other questions?
Old 07-15-2009, 12:09 PM   #6 (permalink)
Hef
Member # 11907
I have a Winchester 2-pistol hardside case that I travel with. I paid $40 for it 5 years ago, and have never had a problem. It has an integral combo lock too.
μολὼν λαβέ
Hef is offline   Reply With Quote Quick reply to this message
Old 07-15-2009, 04:48 PM   #7 (permalink)
I build stuff
aloharover's Avatar
Member # 14561
Mo rifle or pistol?
I have a case for both if you want to borrow.
It's all fun and games 'till someone loses an eye, then it's just fun you can't see.
1970 Land Rover Series IIa 105". 5.3l L59, 4L80 MT1, NP241, F&R D110 Salisburies
aloharover is offline   Reply With Quote Quick reply to this message
Old 07-15-2009, 05:22 PM   #8 (permalink)
Mo
Mo's Avatar
Member # 47
Originally Posted by aloharover View Post
Mo rifle or pistol?
rifle, but I'm not sure I'll have a chance to get down there - I'm flying Friday. Thanks for the offer though.
Old 02-29-2012, 09:04 AM   #9 (permalink)
TJGreg5's Avatar
Member # 98578
Bringing this to the top.
So I read through the TSA regs and it more or less confirms the experiences here with no true benchmark for cases. I emailed flamabeau to see if they had any better confirmation but no reply yet.
Any restrictions on hw may firearms I can cram into one case?
Should this case be good? By the post above it seems so; really don't want to shell out anything for a new one.
http://www.flambeau-cases.com/rifle-...-case-6490.htm
Flambeau 6499 Case: Double Gun Case
• Four locking points for extra security built into the Flambeau 6499 case
• The Flambeau 6499 case has a combination of piano style hinges and brass hinges to provide durability, safety and protection
• 6499 oversized double wall, will accommodate two scoped rifles
• Flambeau 6499 includes durable convolute (egg-crate) foam
Semper Fidelis
TJGreg5 is offline   Reply With Quote Quick reply to this message
