.22lr Chamber Dimensions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-13-2010, 07:35 AM   #1 (permalink)
LiLBucket's Avatar
Member # 79539
I have a cut M16 barrel (muzzle end). I want to make a .22lr chamber on the cut side (for rimfire). I have about 10" of good barrel left. What're the dims for the chamber? Super stoopid tolerences on this? Is there a .22lr chamber reaming tool i can use? Need I a lathe??
Yes, pondering homebuild ideas here.....thanks!!
This space now for rent. No free adds here!!! :flipoff2:
LiLBucket is offline   Reply With Quote Quick reply to this message
Old 01-13-2010, 07:58 AM   #2 (permalink)
Member # 73107
22 rimfire and 22 centerfire have different barrel dimensions I believe it is .221 vs .224.
That being said here are some reamers.
http://www.brownells.com/.aspx/sid=1..._Rifle_Rougher
http://www.brownells.com/.aspx/sid=1...Rifle_Finisher
Not too sure you need both but I would say a lathe would be favorable.
[QUOTE=fatdan460;14154037]why did i just look at sturgell's dick?[/QUOTE]
Sturgell is offline   Reply With Quote Quick reply to this message
Old 01-13-2010, 08:03 AM   #3 (permalink)
LiLBucket's Avatar
Member # 79539
Edited post...yes, this is for rimfire...
Old 01-13-2010, 09:14 AM   #4 (permalink)
Gozuki's Avatar
Member # 3088
Do you "need" a lathe? No, but it is definately the right tool for the job. What else did you have in mind, drill press?
Most 9 ' s are capable of firing 380 and if push really came to shove, you can fire .357 and 38 special through one.
Gozuki is offline   Reply With Quote Quick reply to this message
Old 01-13-2010, 09:22 AM   #5 (permalink)
LiLBucket's Avatar
Member # 79539
Originally Posted by Gozuki View Post
drill press?
ya...why?
Old 01-13-2010, 09:27 AM   #6 (permalink)
Member # 73107
I knew that from the 22lr in your post lol, what I am saying is that the inside diameter of the barrels are different.
Old 01-13-2010, 09:31 AM   #7 (permalink)
LiLBucket's Avatar
Member # 79539
It's a "demilled" or whatever Colt M16A1 barrel (Saw cut). Does the ID you refer to matter? No different than a .22lr kit shooting through an AR right?
I think I'm the confused one here
I'm wanting to make a .22lr gun out of this barrel section and some other crap in the parts drawers....maybe a single shot, break action. Not sure though.
Old 01-13-2010, 09:42 AM   #8 (permalink)
Member # 73107
It will work and will most likely be accurate enough for general plinking.
Old 01-13-2010, 10:10 AM   #9 (permalink)
Regular Guy
300sniper's Avatar
Member # 26382
the 22lr conversions work although they definatly are not right. i wouldn't spend any time or money trying to turn a 22 cal centerfire barrel into a 22 cal rimfire. a .22 rimfire barrel is .222" and a .22 centerfire barrel is .224". the twist on a centerfire barrel is also much faster than a rimfire barrel. i think a typical 22lr barrel is a 16 twist. your barrel stub is probably a 7 or 9 twist (i think the a1 had a 9 twist and then a 7 twist for the a2 but i could be wrong).
basically, it could work but it definatly is not the best way to go about it.
edit: sounds like the a1's had a 12 twist barrel, not a 9.
It's time to switch to whiskey, we've been drinkin' beer all night.
300sniper is offline   Reply With Quote Quick reply to this message
Old 01-13-2010, 10:19 AM   #10 (permalink)
LiLBucket's Avatar
Member # 79539
This is the objective
Good info indeed, thank you!
I'm just looking to cobble together something out of parts on hand though. Just a project sort of thing, just because, no reason. I definitely want to stay safe/legal too though which is why this question comes up.
EDIT: based on most of the stuff you guys post that you build/machine, this is gonna be a "turd"...just a noisemaker...
Old 01-13-2010, 10:35 AM   #11 (permalink)
Gozuki's Avatar
Member # 3088
ya...why?
Well, it's better than a handheld cordless. See if you can bribe a local machine shop employee to turn it for you, shouldn't cost more than $10 in
Old 01-13-2010, 10:47 AM   #12 (permalink)
LiLBucket's Avatar
Member # 79539
...and a step up from the Dremel
Ya, I think I can get it turned locally, but I still need the dims!!!!!!!!!
...and a "joke" about the dremel....man I shouldn't even admit this....
...I took the dremel with the carbide bit on it to the inside a while back to make a .22lr ratshot cartridge fit w/the intentions of making a snake-gun for the lake. Something not very loud or high powered for if a snake is near the dock/swimming area this summer. Never finished the build though, but I tested it with a pair of vise-grips holding the barrel and a hammer.........it worked....
So, needless to say, I'll have to turn/cut a little off before boring anyhow...
Old 01-13-2010, 11:20 AM   #13 (permalink)
Gozuki's Avatar
Member # 3088
I firmly believe some people should not be allowed to own welders or dremels.
Old 01-13-2010, 11:30 AM   #14 (permalink)
LiLBucket's Avatar
Member # 79539
It was VERY low powered shotshell....I wouldn't risk anything else...
I did built this with said dremel/welder!!.....seriously...bent the flat by scoring it along the bend line with the dremel, then welded the bend on the inside after bending "by hand".....well over 2000 rounds through it w/out a problem....(also did a Romy this way!)
So back off muh Dremel skills!!!!
Old 01-13-2010, 02:54 PM   #15 (permalink)
4runner's Avatar
Member # 946
Send a message via AIM to 4runner
how long a piece of bbl you want?
I have an 8" piece I cut off the free gun mossy 22rimfire...even has a front site dovetail in it.
better?
4.3runner
4runner is offline   Reply With Quote Quick reply to this message
Old 01-13-2010, 02:56 PM   #16 (permalink)
Regular Guy
300sniper's Avatar
Member # 26382
I have an 8' piece I cut off the free gun mossy 22rimfire...even has a front site dovetail in it.
damn, that's a long barrel!
Old 01-13-2010, 03:21 PM   #17 (permalink)
Member # 13467
.22 WMR uses a centerfire diameter bullet. It also uses a slightly faster twist (1-14") than .22lr (1-16") so you'd be a little closer there, too.
[QUOTE=Willyswanter's Dad;8398776]I'm trying to find spinner caps that will fit the wheels so when I'm stuck it will look as though I'm still wheeling[/QUOTE]
Ben Segrest is offline   Reply With Quote Quick reply to this message
Old 01-13-2010, 05:29 PM   #18 (permalink)
Gozuki's Avatar
Member # 3088
He has a barrel remnant that he wants to chamber.
Old 01-13-2010, 05:35 PM   #19 (permalink)
Member # 73107
Might be good for the Aguila SSS bullets.
Old 01-14-2010, 05:26 AM   #20 (permalink)
LiLBucket's Avatar
Member # 79539
This
So, the chamber dims?? Gonna make me register on rimfirecentral? (if i'm not already )
Old 01-14-2010, 05:36 AM   #21 (permalink)
PONY_DRIVER's Avatar
Member # 44662
As mentioned the .22 WMR is .224" in diameter as is the .223 Rem/5.56 NATO round. Might want to look into that and rent a reamer.
"I'm strangely comfortable with it."
PONY_DRIVER is offline   Reply With Quote Quick reply to this message
Old 01-14-2010, 06:45 AM   #22 (permalink)
Gozuki's Avatar
Member # 3088
Google fu shows this
.22LR Chamber Dimensions
Type______Length__Mouth Dia._Throat Dia.
Sporting____0.8751"____0.2307"____0.2270"
Bentz______0.6900"____0.2270"____0.2255"
Match _____0.6876"____0.2267"____0.2248"
Win 52-D___0.5800"____0.2278"____0.2248"
The "Ruger" 10/22 factory chamber is the "Sporting" chamber above.
The "Bentz" chamber is the 'match' chamber for semi-autos.
The "Match" chamber is for bolt actions.
The "Win M52-D" is a bolt action target rifle.
Since you're going to need at least the finish reamer, why not buy that and measure it?
Old 01-14-2010, 06:45 AM   #23 (permalink)
Member # 73107
This
http://lmgtfy.com/?q=22lr+chamber+dimensions
3rd link down.
Old 01-14-2010, 06:46 AM   #24 (permalink)
Member # 73107
Damn you beat me by mere seconds.
Old 01-14-2010, 07:20 AM   #25 (permalink)
LiLBucket's Avatar
Member # 79539
I had seen that link and honestly forgot I saw it.....sorry...thanks though
So, what size do dremel carbide bits come in
