Loading complacency... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-16-2011, 12:30 PM   #1 (permalink)
Member # 59127
If ya turn your powder hopper off to see what disc is installed, it helps to turn it back on when ya start the next batch.
Spot checking charge weight will make sure you only have to pull a dozen or so boolits when you find you've been charging your .38sp with 0.0gr of Green Dot, which is not published data in any manual.
Mothfukle!
Bullet puller = friend
[QUOTE=Muddin;7252258]If I was you, I'd stop signing your name at the end of your post. You sir, are teh unfunnay and if you continue to sign your name, we'll know who it is that brings teh unfunnay.
:flipoff2:[/QUOTE]
Fishslayer is online now   Reply With Quote Quick reply to this message
Old 05-16-2011, 12:56 PM   #2 (permalink)
III
Chris's Avatar
Member # 2032
I'd pull them all apart. Cases have enough differential to make you believe it has powder when it doesn't.
Chris is offline   Reply With Quote Quick reply to this message
Old 05-16-2011, 01:41 PM   #3 (permalink)
Member # 59127
Already done. I only had to pull a dozen or so.
Worst was awhile back one of my spot checks revealed that some crud in the tube was causing an occasional light/zero charge. I had to pull a hunnert bullets. I actually got pretty lucky. Out of all the rounds I took apart very few actually had significantly light/zero charges. I just happened to spot one.
I frequently inspect the powder path for cleanliness now...
I got one of those bottle type brush assortments from Harbor Freight. Great for cleaning dies.
:flipoff2:[/QUOTE]
Old 05-16-2011, 02:09 PM   #4 (permalink)
Member # 21312
Send a message via AIM to freerider5.0
This is why "I" load with a single stage press. Form, trim, prime, charge, insert bullet. All single steps. This ensures when my cases in in the case holder i can look into the tops of my cases and tell which ones have powder and which ones don't.(Thanks for the tips Animator!)
Sure, it takes longer, but hey, its not like i am married with kids or anything
Elliot
freerider5.0 is offline   Reply With Quote Quick reply to this message
Old 05-16-2011, 02:16 PM   #5 (permalink)
PRegner's Avatar
Member # 50212
Same here. I have no life outside of work and my hobbies. I find that if I put some good music on, I can get into a nice groove, and actually make reloading a "zen-like" experience. Compound with that, my mortal fear of a squib; I end-up double checking each and every round for powder charge, and I verify weight every ten rounds.
"Sic gorgiamus allos subjectatos nunc"
"Islam in a man is more dangerous than rabies in a dog"
PRegner is offline   Reply With Quote Quick reply to this message
Old 05-16-2011, 03:36 PM   #6 (permalink)
Member # 59127
Loading on a turret isn't that far removed from single stage. I can actually turn mine into one if i want. Each round gets handled and it's usually not hard to catch the occasional if you're paying attention.
Loading pistol ammo on a single stage would drive me nuts.
:flipoff2:[/QUOTE]
