New Products. Synergy Suspension Dodge Components -----------------------> - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Poly Performance
Old 09-16-2011, 04:57 PM   #1 (permalink)
PIG
PIG's Avatar
Member # 4502
Front Upper Control Arms
Description:
Application:
94-Up 1500 Megacab/2500/3500 4x4
Features:
Suspension components feature an abrasiveresistant powder coat finish for maximum durability and corrosion resistance
Made from high quality crush resistant 1 1/2" X .156" Wall 1026 DOM tubing
Incorporates the tried and true Currie Enterprises Johnny JointsŪ for paramount performance
Synergy Suspension Double Adjuster Sleeve & Pinch Bolt Assembly: allows for adjustment of control arm length without removing control arm mounting bolt
100% bolt on components assures an easy, trouble free installation with the use of basic hand tools
1994 to present, requires drilling of mounts to 9/16'' on 94 to 99 models
Sold in pairs
Dodge Front Lower Control Arms
Description:
Application:
94-99 1500/2500/3500 4x4 * Requires 9/16'' hole to be drilled in mounts
00-09 1500/2500/3500 4x4 w/ 16mm Bolts
10-Up 1500 Megacab/2500/3500 4x4 w/ 16/18mm Bolts
Features:
Suspension components feature an abrasive resistant powder coat finish for maximum durability and corrosion resistance
Sold in pairs
Dodge Front Track Bar
Description:
03-present 2500/3500 & 1500 Mega Cab 4X4
94-02 2500 / 3500 4x4 with Synergy late model track bar upgrade bracket (PPM-8554)
Bent to clear most aftermarket differential covers
Retains factory track bar mounting bolts & hardware
Made from high quality 1-3/8" 1045 Solid tubing
Allows centering of front axle when running a suspension lift
FK Bearing heavy duty heat treated 7/8" chromoly rod end at axle end
Synergy Suspension double adjuster sleeve & pinch bolt assembly allows for adjustment of track bar length without removing control arm mounting bolt
Includes:
(1) Grade 8 Pinch Bolts & Hardware
(1) Synergy Suspension Double Adjuster Sleeve
(1) Synergy Suspension Dodge Front Track Bar
(1) FK Bearing Heavy Duty Heat Treated Chromoly Rod End
Note: The trackbar can be adjusted from 38.625" (.25" shorter than stock) to 39.438". This allows the track bar to be used when lowering trucks for race applications up 3" lower than factory specs and lifted applications up to 4.5" over factory specs.
Dodge Conversion Track Bar Bracket
Description:
Synergy Suspension Dodge Track-Bar Conversion Bracket for 94-02 4x4 trucks
Eliminates the weak link in the otherwise stout 4x4 Dodge chassis which has been plagued for years due to its poor track-bar design
Converts the stock ball-joint style TB to the newer 03-current bushing style track-bar
Designed to work with a factory Dodge Track-Bar or with a Synergy Suspension Adjustable Track-Bar (PPM-8550)
Tightens up steering and suspension feel and helps eliminate dreaded "Death Wobble"
Laser cut, CNC bent and precision welded
Grey powder coat finish for maximum corrosion resistance
Bolt on installation
PM or Post for Intro Pricing. Thanks
Click the sig for everything you need to build a tube car
www.SynergySuspension.com
Cool stuff for your buggy, Jeep, Dodge 2500/3500
www.4130Clothing.com
A unique apparel line geared for the off-road enthusiast
PIG is offline   Reply With Quote
Old 09-16-2011, 05:22 PM   #2 (permalink)
mopartim's Avatar
Member # 48016
price on the ram track bar conversion
my truck is a 2002 2500 and i have a brand new 04 track bar i was going to make my own bracket but it would be much easier to buy yours
Originally Posted by BallisticDave View Post
I don't have a good answer Tim. I will however look into this, find where the error was and do what is necessary to remedy this in the future. We clearly dropped the ball.
mopartim is offline   Reply With Quote
Old 09-19-2011, 10:02 AM   #3 (permalink)
65Chevy4x4's Avatar
Member # 37016
Pm sent
WWW.POLYPERFORMANCE.COM
Thanks to my Sponsors
www.yukongear.com
65Chevy4x4 is offline   Reply With Quote
Old 09-22-2011, 10:07 AM   #4 (permalink)
Newbie
Member # 144982
Can I get a price on a track bar for a 2000 Ram 2500. Shipped to 94551. Thanks
97FrankenHeep is offline   Reply With Quote
Old 09-22-2011, 10:18 AM   #5 (permalink)
65Chevy4x4's Avatar
Member # 37016
pm sent
www.yukongear.com
Old 10-31-2011, 10:16 AM   #6 (permalink)
Newbie
Member # 171607
will these help correct th "hunting" feeling in my steering? 2001 2500 4x4.
lucky1 is offline   Reply With Quote
Old 11-07-2011, 05:37 PM   #7 (permalink)
TwoTurtlesRacing's Avatar
Member # 183269
Cool
Curious about cost for a set of upper and lower control arms for an 01 2500. Shipped to 80816.
Coe Guthrie ><>
'75 FJ40 and a few other toys...
TwoTurtlesRacing is offline   Reply With Quote
Old 11-08-2011, 01:07 PM   #8 (permalink)
65Chevy4x4's Avatar
Member # 37016
Alot of these components can help the wandering or hunting feeling. It could be steering box flexing, which the brace will fix. Loose track bar letting axle move side to side causing steering input when not moving the wheel. Any of these items could contriubte the the problems your experiencing.
PM Sent.
www.yukongear.com
Old 11-14-2011, 05:35 PM   #9 (permalink)
Member # 53390
Any chance you will be making a poly fixed length uppers too?
BUY MY UHAUL IN OREGON!
http://www.pirate4x4.com/forum/showthread.php?t=910113
AK-Josh is offline   Reply With Quote
Old 11-16-2011, 02:49 PM   #10 (permalink)
PIG
PIG's Avatar
Member # 4502
Prob not on the fixed length uppers. But we are working on a new bushing set up for them. It should help bring the retail price down a little if we can get something in there that works.
Old 11-20-2011, 08:39 PM   #11 (permalink)
geeride's Avatar
Member # 106504
Add Content
geeride is offline   Reply With Quote
Old 11-23-2011, 10:20 PM   #12 (permalink)
Member # 53390
Cool. Looking at a set of links, just dont need anything fancy. Bushings should be fine. Please post up when you do.
Old 11-27-2011, 05:55 PM   #13 (permalink)
Member # 177404
quote
Price for the synergy upper and lower control arms and track bar conversion and bracket? Thanks, Mark
hdoffroad is offline   Reply With Quote
Old 03-03-2012, 10:50 AM   #14 (permalink)
mopartim's Avatar
Member # 48016
has anyone actually installed one of your conversion track bar brackets and used a factory track bar? i am installing a 04.5 track bar on my 02 using your bracket kit ...... the truck is torn apart half in the garage half out and the bar does not fucking fit its not even close
at full drop the bend in the stock bar is making contact with your bracket.... short of cutting a chunk out of the bracket or grinding a 1/4 inch off the face of the track bar its not going to work
wonder how i am getting to work ?
Old 03-03-2012, 02:05 PM   #15 (permalink)
mopartim's Avatar
Member # 48016
when someone at poly gets this shot me an e-mail, this kit does not work with a stock track bar
tm_collins85 a t y ah oo . c o m
Old 03-05-2012, 01:50 PM   #16 (permalink)
Wh1t3NuKle's Avatar
Member # 200856
Description:
The track bar bracket is very similar to the BD Diesel one. Pricing?
Wh1t3NuKle is offline   Reply With Quote
Old 03-05-2012, 04:22 PM   #17 (permalink)
mopartim's Avatar
Member # 48016
I just wanted to shot a quick reply to this .... The people at poly are awesome, I got emails back from them on a Sunday night, they asked for pictured of the problem I was having .... Explained what was going wrong, apologized for everything and they are hooking me up with a great deal on the parts I need to get my truck back on the road
Best company to deal with ever
Thanks again guys
Old 03-13-2012, 07:49 PM   #18 (permalink)
PIG
PIG's Avatar
Member # 4502
Thanks again guys
Old 06-23-2012, 09:55 AM   #19 (permalink)
Member # 85007
I finally got the rest of my order. The rear shackles do not fit on my truck. Your site shows them for 2003+ trucks only when listed individually. In the kit listing on your site, there is nothing saying they dont fit on a 1997 truck. What else in this kit wont/will fit on a 1997 truck?
wilco is offline   Reply With Quote
Old 06-24-2012, 02:19 PM   #20 (permalink)
PIG
PIG's Avatar
Member # 4502
Yea, looks like an error on our site. Give me a call Monday and i'll help get things figured out for you. Sorry about the error.
Dave
805-242-0397
Old 06-24-2012, 04:55 PM   #21 (permalink)
D45
D45's Avatar
Member # 102974
What size lift are the upper and lower CAs for?
Or, how long are they from eye to eye?
'04 QC/LB, 4WD, 305/555 HO CTD, 37x13.50 Toyo MTs on BMF Sota 8, 6" Lift, MBRP 5", IceBox Intake, Air Dog 150, ATS Pulse Flow Manifold, BD Special Turbo, SMARTY SR POD, ARP Studs, T&C WILD Fuel Rail, T&C CPRV, II Dragon Fire 85% CP3, II 100HP Nozzles, Built 48RE, Bullet Proof Steering
D45 is offline   Reply With Quote
