Member # 4502
Synergy Suspension Leaf Spring Accessories
Synergy Suspension Formed U-bolt Spring Plate
Available in 4 different sizes to fit 1000's of applications. Description: Synergy Suspension Formed U-bolt Spring Plate Part # Description PPM-3126-250 Formed U-bolt Spring Plate, 2.50" Wide Spring, 2.50" - 3.125" Axle Tube PPM-3126-300 Formed U-bolt Spring Plate, 3.00" Wide Spring, 2.50" - 3.125" Axle Tube PPM-3127-250 Formed U-bolt Spring Plate, 2.50" Wide Spring, 3.125" - 4.00" Axle Tube PPM-3127-300 Formed U-bolt Spring Plate, 3.00" Wide Spring, 3.125" - 4.00" Axle Tube ![]() Synergy Suspension Spring Plate Shock Tabs Great addition of any outboard leaf spring setup. Allows shock to be moved above the axle and out of harms way. Description: Synergy Suspension Spring Plate Shock Tabs (Pair) ![]() Synergy Suspension Formed Weld-on Spring Perch Available in 6 different options to fit almost every axle out there. Lower Profile design will maximize ground clearance on spring under applications. Description: Synergy Suspension Formed Weld on Spring Perch Part # Description PPM-3123-250 Formed Weld-on Spring Perch, 2.50" Wide Spring, 2.50 - 2.75" Axle Tube (2.75" Ideal) PPM-3123-300 Formed Weld-on Spring Perch, 3.00" Wide Spring, 2.50 - 2.75" Axle Tube (2.75" Ideal) PPM-3124-250 Formed Weld-on Spring Perch, 2.50" Wide Spring, 3.00 - 3.25" Axle Tube (3.125" Ideal) PPM-3124-300 Formed Weld-on Spring Perch, 3.00" Wide Spring, 3.00 - 3.25" Axle Tube (3.125" Ideal) PPM-3125-250 Formed Weld-on Spring Perch, 2.50" Wide Spring, 3.375 - 4.0" Axle Tube (3.375" Ideal) PPM-3125-300 Formed Weld-on Spring Perch, 3.00" Wide Spring, 3.375 - 4.0" Axle Tube (3.375" Ideal) ![]() Synergy Suspension Single U-Bolt with Hardware Available in 3 different sizes to fit axle tubes from 2.5" - 3.375". High strength 9/16" U bolts w/hardware. Description: Synergy Suspension Single U-Bolt with Hardware Part # Description PPM-UB-2750 Single U-bolt w/ HDW for 2.50 - 2.75" Axle Tube PPM-UB-3125 Single U-bolt w/ HDW for 3.0 - 3.125 Axle Tube PPM-UB-3375 Single U-bolt w/ HDW for 3.125 - 3.375" Axle Tube ![]() Synergy Suspension Leaf Spring Conversion Kit Description: Synergy Suspension Leaf Spring Conversion Kit Everything needed to do spring over leaf spring swaps Kit Includes: (2) Synergy Suspension Ultra Low Weld On Wide Springs Perches (2) Synergy Suspension 3/8" thick U-bolt plates (4) Synergy Suspension HD E-coated 5/8-18 UNF U-bolt plates (8) 5/8-18 UNF tall U-bolt nuts (8) 5/8" ASTM F436 extra thick hard washers Part # Description PPM-3130-250-2750 Leaf Spring Conversion Kit for 2.50" Wide Springs and 2.750" Axle Tubes PPM-3130-300-2750 Leaf Spring Conversion Kit for 3.0" Wide Springs and 2.750" Axle Tubes PPM-3130-250-3125 Leaf Spring Conversion Kit for 2.50" Wide Springs and 3.125" Axle Tubes PPM-3130-300-3125 Leaf Spring Conversion Kit for 3.0" Wide Springs and 3.125" Axle Tubes PPM-3130-250-3375 Leaf Spring Conversion Kit for 2.50" Wide Springs and 3.375" Axle Tubes PPM-3130-300-3375 Leaf Spring Conversion Kit for 3.0" Wide Springs and 3.375" Axle Tubes The following is a list of the most common solid axle swaps and their axle tube sizes. Note: these kits are designed to fit 2.750", 3.125" and 3.375" axle tubes exactly. They will fit other sizes with minor grinding. ![]() PM for Intro Pirate Pricing.
Click the sig for everything you need to build a tube car www.SynergySuspension.com Cool stuff for your buggy, Jeep, Dodge 2500/3500 www.4130Clothing.com
A unique apparel line geared for the off-road enthusiast |
