***NEW*** Truck Tough HD Alternators - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Poly Performance
Old 01-26-2012, 03:33 PM   #1 (permalink)
PIG
PIG's Avatar
Member # 4502
Yo, we just picked up this line a few weeks ago... We have had a few sent over to inspect/test out. Their products are pretty legit, check it out...
Mention this add off of PBB and get freight freight on your alternator order!
Truck Tough Application Listing
Truck Tough high output alternators are built to handle the harshest environments. Hot rated at 240a, these units put out 140a at idle and feature heavy duty components built to provide reliable service for years to come.
Stator: Stators are designed for maximum output and achieve peak output by 1700rpm.
Regulator: 100% OEM compatible regulators insure easy installation, accurate voltage regulation and long life.
Rotor: Precision balanced OEM alloy rotor provides maximum output at all speeds with low vibration for long bearing life. OEM alloy properties promote cooler operating temperatures.
Rectifier: Exclusive solid copper rectifier with high capacity diodes has two times the power handling and cooling capacity of other "high output" rectifiers for reliability in high demand conditions.
Bearings: Premium NTN bearings provide long life and smooth operation with a low failure rate.
Pulley: Billet drive pulley provides the best traction for your belt in any situation.
Output & Ground Studs: Over-sized positive and ground studs provide easy, secure connections for upgraded power cables.
Dyno Tested Hot Output (200 degrees Fahrenheit):
140a @ idle
240a @ 1700rpm
All Truck Tough alternators are hot tested on our dyno before shipping and are covered by a 2-year warranty.
Click the sig for everything you need to build a tube car
www.SynergyMFG.com
Cool stuff for your buggy, Jeep, Dodge 2500/3500
www.4130Clothing.com
A unique apparel line geared for the off-road enthusiast
PIG is offline   Reply With Quote
