Fox 2.0 16" Emulsion Coilover - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Poly Performance
Old 04-15-2010, 08:30 PM   #1 (permalink)
Hottrod81's Avatar
Member # 36464
I spilled some oil out of my coilovers, can you tell me how much oil they should have? Thanks.
Hottrod81 is offline   Quick reply to this message
Old 04-15-2010, 10:33 PM   #2 (permalink)
onepersonriot's Avatar
Member # 50021
Send a message via Skype™ to onepersonriot
We have all that info at the shop/office, I'll post up in the morning.
7 JV
259 Tellico
onepersonriot is offline   Quick reply to this message
Old 04-16-2010, 10:02 AM   #3 (permalink)
Member # 50021
They should be filled 7.50" from the open end of the body. Fox is kind weird how they do their shit.
7 JV
259 Tellico
Old 04-16-2010, 11:12 AM   #4 (permalink)
Hottrod81's Avatar
Member # 36464
Thanks. So I need to take the end off of the body? How do I do that? I don't want to damage the shock.
Old 04-16-2010, 11:57 AM   #5 (permalink)
Member # 50021
Ahhh, you must be trying to fill it through the schrader. Here's a quick run through of the steps.
1 - Clamp shock in vice, shaft up.
2 - Use 3/32" Allen to loosen set screw on the colored cap where the shaft goes into the body.
3 - Unscrew the colored cap, use a spanner wrench in the two holes.
4 - Push the seal carrier down and remove the wire retaining ring.
5 - Pull entire shaft/bearing assembly out and set aside, keep the wear band that is on the piston.
6 - Fill with oil and reverse steps to re-assemble shock.
Edit: I forgot, make sure you have shop towels around, I can't keep the stuff off of me.
This is the same procedure to re-valve/rebuild except you have to pull the nut off the shaft to get to the valve disks.
If you have any questions you can email me directly ar Kurt@polyperformance.com or give me a call: 805-783-2060 (ask for Kurt)
7 JV
259 Tellico
Old 04-16-2010, 09:07 PM   #6 (permalink)
Hottrod81's Avatar
Member # 36464
Thanks. I will e-mail or call you if I can't figure it out.
Old 04-16-2010, 09:18 PM   #7 (permalink)
Member # 11982
Maybe you guys could post up the fluid amounts for all the fox coilovers. (for the guys running 10,12, 14, 18, etc.)?
InstaGator is offline   Quick reply to this message
Old 04-18-2010, 03:12 PM   #8 (permalink)
PIG
2indapink&1indastink
PIG's Avatar
Member # 4502
Good idea... I am gonna see what we can do about loading oil volumes for ALL the shocks we carry to our site, not just the airs.
USE CODE: PIRATE10 FOR 10% SAVINGS ON YOUR NEXT ORDER!!!
COOL STUFF FOR YOUR BUGGY, JEEP, DODOGE 2500/3500
PIG is offline   Quick reply to this message
