Member # 4502
FOX 10" & 12" 2.0" DIA Air Shocks ----> $150 Each
OK folks. We got an over stock shipment from Fox of 10" and 12" travel Fox 2.0 air shocks. The kicker is is that all these have the anodized blue rod ends. Also, these shock do not come with our standard valving.
Valving Specs: Travel = 10” Part # FOX-980-99-018-A Valving = (35 Compression/45 Rebound) Travel = 12” Part # FOX-980-99-019-A Valving = (75 Compression/85 Rebound) We only have a few of these and are being sold as a first come first serve basis. EMAIL me for order info.... Try not to PM please as it is not as efficient. DAVE@POLYPERFORMANCE.COM or call the order in x203
Click the sig for everything you need to build a tube car www.SynergySuspension.com Cool stuff for your buggy, Jeep, Dodge 2500/3500 www.4130Clothing.com
A unique apparel line geared for the off-road enthusiast |
Moderator
for those of us that are shock idiots, what would this valving work well with?
Check out our new Team Ape Eater Racing Like us on FaceBook KF5EQF Sniper Fab 4x4Oil SBwinVPS Custom Splice C2GFab |
Member # 6340
Location: Telluride CO, within site of of Black Bear Pass
x2. how doe sit compare to a 9012 rancho etc.
Marc In what appears to have been an understatement, the plant operator described the situation at the Number 4 reactor as "not so good." Super conversion calculator website Love and kisses, Zaphod.. |
Member # 37016
The valving is for a light weight buggy really. A re-valve is simple and can be done for around $50.00 a shock if you so desire, or read online and do it yourself. Simple $10-15 in parts and a hour of your time and your done.
so would the 12" work on the rear of a ranger short shortbed? Im not sure what the 75/85 weight means as compared to real weight.....
IL Air Natn'l Guard 1Ton Ranger Project - F250 7.3 Piped/Intake/Chip/Leveled Last edited by bronkho31; 05-16-2010 at 06:46 PM. |
Member # 37016
Those should work. The valving isn't the weight or something. It's basically how stiff the compression or rebound damping of the shock is. You adjust ride height by nitrogen pressure and oil volume. These should work fine for your truck, and you can always re-valve them in the future.
