***NEW*** Poly Performance Budget Bump Stops - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Poly Performance
Old 06-11-2010, 04:40 PM   #1 (permalink)
PIG
PIG's Avatar
Member # 4502
Poly Performance Budget Bump Stops:
Description:
This part is designed for the builder who wants to add air bump stops to their truck or buggy, but can't afford the shocks yet. The 3 snap ring grooves are used for air bump stop mock up when you are positioning the air bump can mounts. When the bump can mounts are positioned, the part can be used as a bump stop with poly or foam bump stops. When you have the ability to add air bump stops, your rig is ready to go.
Features:
-Manufactured from Solid T-6061 Aluminum
-Designed to Mimic a Hydraulic Air Bump Stop at a Fraction of the Cost
-Spiral Snap Ring Offers 3 Positions of Adjustment
-Position 1: Stock TJ Front Bump Stop Cup and Foam Bump Stop
-Position 2: Daystar DS-KU09006-BK and DS-KU09014BK Poly and EVS Foam Bump Stops
-Position 3: Used for Mock Up of Hydraulic Air Bumps
Bump Can Options:
-2.0 Air Bump Can (PPM-3402)
-2.0 Air Bump Can w/ Single Pinch Bolt (PPM-3405)
-2.0 Tall Air Bump Can (PPM-3403)
-2.0 Air Bump Can w/ Fox Logo (PPM-3404)
Bump Stop Options:
-Urethane Bump Stop (DS-KU09006-BK)
-Daystar Single Stud Competition Style Bump Stop (DS-KU09014BK or DS-KU09009BK)
Bump Pad Options:
-Poly Performance Bump Stop Axle Pad (PPM-3121)
-Poly Performance Offset Bump Stop Axle Pad (PPM-3122)
Note: Bump Cans, Bump Stops, and Pads sold separately
Click the sig for everything you need to build a tube car
www.SynergyMFG.com
Cool stuff for your buggy, Jeep, Dodge 2500/3500
www.4130Clothing.com
A unique apparel line geared for the off-road enthusiast
PIG is online now   Reply With Quote
Old 06-11-2010, 04:42 PM   #2 (permalink)
PIG
PIG's Avatar
Member # 4502
www.SynergyMFG.com
Old 06-11-2010, 06:57 PM   #3 (permalink)
Member # 129208
Great idea, might have to get a set for the rear of my rig
On a side note, do you guys carry schrader valves for the remote resi's on Fox C/O's? I heard there are 2 kinds, with O-rings and without. The threads stripped out on the cap side and not sure which style I need.
97 SAS'd Ranger
DB_1 is offline   Reply With Quote
Old 06-11-2010, 09:25 PM   #4 (permalink)
Member # 26450
these would also be good for F toy guys who cant run airs in the class to be legal, but would like to run them when playing around out side of comps. cool guys !
Panos is offline   Reply With Quote
Old 06-14-2010, 10:19 AM   #5 (permalink)
PIG
PIG's Avatar
Member # 4502
Not sure what you got on there now but they are probably the O-Ring style.
Here is a link for purchasing info.
www.SynergyMFG.com
Old 06-14-2010, 10:22 AM   #6 (permalink)
PIG
PIG's Avatar
Member # 4502
Yup....
www.SynergyMFG.com
Old 06-14-2010, 12:12 PM   #7 (permalink)
GOAT1's Avatar
Member # 5969
You can use the factory TJ or JK bump stop cups and the factory foam bumpstops, these work well.
GOAT1 is offline   Reply With Quote
Old 06-16-2010, 06:54 PM   #8 (permalink)
Member # 129208
Thanks, i'll give you guys a call once I get a chance to pull it off my rig.
97 SAS'd Ranger
Old 07-13-2010, 04:20 PM   #9 (permalink)
65Chevy4x4's Avatar
Member # 37016
Thanks for the orders so far guys. Keep them coming.
WWW.POLYPERFORMANCE.COM
Thanks to my Sponsors
www.yukongear.com
65Chevy4x4 is offline   Reply With Quote
