4-link bracket dimensions - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Poly Performance
Old 07-08-2010, 07:08 AM   #1 (permalink)
toyjoeta's Avatar
Member # 38006
I was wondering if you had some specific dimensions of these brackets?
http://polyperformance.com/shop/Univ...ts-p-1988.html
The distance from the top mounting hole to the bottom one, and the distance from the bottom hole to the frame mounting surface?
Better to have it and not need it, than need it and not have it.
toyjoeta is offline   Reply With Quote
Old 07-08-2010, 04:34 PM   #2 (permalink)
slowtrucks's Avatar
Member # 92430
This should help....
PPM-500601 Universal 4 link Bracket
polyperformance.com
SynergySuspension.com
[CENTER][URL=http://www.synergysuspension.com][SIZE="4"][COLOR="Red"][FONT="Arial Black"]www[COLOR="White"].[/COLOR][I]SynergySuspension[/I][COLOR="White"].[/COLOR]com[/FONT][/COLOR][/SIZE][/URL] ----> Click and download the new catalog!!![/CENTER]
slowtrucks is offline   Reply With Quote
Old 07-08-2010, 09:02 PM   #3 (permalink)
toyjoeta's Avatar
Member # 38006
Thanks That's awesome!
Old 07-16-2010, 09:26 AM   #4 (permalink)
toyjoeta's Avatar
Member # 38006
What about this one?
http://www.polyperformance.com/shop/...et-p-1701.html
Thanks.
Old 07-16-2010, 01:52 PM   #5 (permalink)
slowtrucks's Avatar
Member # 92430
3109 Track Bar Bracket
Here you go.
polyperformance.com
Old 07-16-2010, 03:02 PM   #6 (permalink)
toyjoeta's Avatar
Member # 38006
Thanks again!
Old 04-29-2011, 01:49 PM   #7 (permalink)
toyjoeta's Avatar
Member # 38006
How about these ones?
http://www.synergysuspension.com/Syn...ube-p-689.html
http://www.synergysuspension.com/Syn...ded-p-698.html
Old 04-29-2011, 04:27 PM   #8 (permalink)
Member # 14395
Im no suspension engineer, but is 5.5 inches of max vertical seperation enough? Isnt the vertical seperation going to be somewhere closer to 8 inches on the diff side? just cant get my head around how well that works or doesnt.
Definition of disappointment: Running into a wall with a boner and breaking your nose first.
lumpy85 is offline   Reply With Quote
Old 04-30-2011, 06:32 AM   #9 (permalink)
toyjoeta's Avatar
Member # 38006
It all depends on how the rest of the set up is. There are allot of people running this set up and it works great. Some people don't run any separation at the frame end (radius arms).
Old 05-01-2011, 11:44 AM   #10 (permalink)
Member # 14395
and radius arms arent a good suspension design, especially in the back.
How do these bracket fair when you talking about 26 inch long arms?
Old 05-01-2011, 02:58 PM   #11 (permalink)
mj
Member # 1919
5.5 and 8 sounds pretty good to me depending on the lengths
mj is offline   Reply With Quote
Old 01-28-2012, 09:57 PM   #12 (permalink)
toyjoeta's Avatar
Member # 38006
Bump, bringing this back. Still curious about the these.
Thanks
