Member # 4502
***NEW*** Monotube Steering Stabilizer:
Well, not that new but still pretty new............
Description: -High quality polyurethane bushings -Linear piston (both comp & reb sides) -Valved specifically for steering applications -Large 46 mm piston for more consistent damping -Tube ends are rolled closed for leak-free construction -Upgraded polyurethane extension bottom-out bumper -Nitro Steel stabilizer shafts won’t chip or flake like chrome -Low pressure Nitrogen charged mono-tube steering stabilizer -Anodized aluminum seal carrier bump cap for extended seal life -External schrader valve assembly for easy pressure adjustments -Welds done with robotic projection welder for accuracy and quality -Durable black powdercoated finish for the best corrosion resistance -Viton seal and low friction piston rod bearing for long life and no leaks -Internal floating piston (IFP) that dissipates heat more effectively for increased seal life and durability -Limited Lifetime Warranty Description: 2.0" Dia. Steering Damper Part # PPM-6001 Price = $125 Colapsed Length = 18.25" Extended Length = 27.75" Travel = 9.5" ![]()
Click the sig for everything you need to build a tube car www.SynergySuspension.com Cool stuff for your buggy, Jeep, Dodge 2500/3500 www.4130Clothing.com
A unique apparel line geared for the off-road enthusiast |
