Member # 4502
***NEW*** Universal Resevoir Mounts -------------->
Poly Performance Universal Weld/Bolt-On 2.0" Reservoir Mount
Poly Performance Universal Weld-On 2.0" Reservoir Mount Poly Performance Universal Weld/Bolt-On 2.0" Reservoir Mount (Pair) Description: * (2) Reservoir Mount Tabs for Fox 2.0" threaded and smooth body shocks * Designed to be welded or bolted on to vehicle chassis or sheet metal * (4) Stainless Steel size 40 hose clamps included Poly Performance Universal Weld-On 2.0" Reservoir Mount (Pair) Description: * (2) Reservoir Mount Tabs for Fox 2.0" threaded and smooth body shocks * Designed to be welded or bolted on to vehicle chassis, extra material can be trimmed down for custom mounting applications * (4) Stainless Steel size 40 hose clamps included Poly Performance Universal Weld/Bolt-On 2.0" Reservoir Mount ![]() ![]() Poly Performance Universal Weld-On 2.0" Reservoir Mount ![]()
Click the sig for everything you need to build a tube car www.SynergyMFG.com Cool stuff for your buggy, Jeep, Dodge 2500/3500 www.4130Clothing.com
A unique apparel line geared for the off-road enthusiast |
Member # 138129
Looks like a cool way to mount reservoirs! Do you guys have any pics of them in use? I've got a jeep with an 11" fox reservoir so I want to know what the length between the mounts are? I would like them loNg enough to not cover up the middle sticker. Thanks!
