***NEW*** Dana 30, Dana 44, Dana 60 Ball Joints From Synergy Suspension-------------> - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Poly Performance
Old 05-10-2012, 04:24 AM   #151 (permalink)
danf150's Avatar
Member # 52766
Originally Posted by zuk1988 View Post
Is there supposed to be some minor play in the 4121 when installed?I feel a slight wiggle and it is coming from the ball joint,I got the wheel bearing as tight as ca be but I feel movement from the ball joint,please help.
Is the threaded sleeve fully seated & torqued on the top ball joint?
http://synergysuspension.com/instruc...BALLJOINTS.pdf
May God's Grace Bless You
78 BRONCO: 508",MPFI,LentechAOD,AtlasII,lockers,hydroboost,ram-assist,35s
danf150 is offline   Reply With Quote
Old 05-13-2012, 09:19 AM   #152 (permalink)
Member # 93886
I had them at 50 ft.lbs. The good people at Synergy are sending me a new set and inspecting these.
88 Samurai D44,Spider 9",Detroits,33 TSL's
zuk1988 is offline   Reply With Quote
Old 05-13-2012, 01:17 PM   #153 (permalink)
PIG
PIG's Avatar
Member # 4502
Originally Posted by jedrattle View Post
Soon I hope!! my truck is sitting dead because of ball joints!
Trust me man... We want these released just as bad as you do!
Originally Posted by willysman07003 View Post
do they make these for a 01 wj
Yes! Its the same as the Jk application.
WJ BJ's!
Originally Posted by ATVracer76 View Post
the 4121s still being released and shipped today?
Shipping now!
I got my 4121's last week
hey, thanks for the heads up... just placed my order!
Glad we got a solution worked out for you.
Click the sig for everything you need to build a tube car
www.SynergyMFG.com
Cool stuff for your buggy, Jeep, Dodge 2500/3500
www.4130Clothing.com
A unique apparel line geared for the off-road enthusiast
PIG is offline   Reply With Quote
Old 06-11-2012, 03:32 PM   #154 (permalink)
hurleygo3's Avatar
Member # 80862
Are the 4122's shipping?
www.facebook.com/EckoMotorsports
www.partsmike.com
www.savvyoffroad.com
hurleygo3 is offline   Reply With Quote
Old 06-12-2012, 01:49 AM   #155 (permalink)
danf150's Avatar
Member # 52766
Question: I realize the bushing & ball socket are obviously stronger, but is the stud made of a stronger material than OEM?
http://www.polyperformance.com/shop/...s-p-26182.html
Originally Posted by PIG View Post
The problem.....
Old 06-13-2012, 04:21 PM   #156 (permalink)
PIG
PIG's Avatar
Member # 4502
Not yet but should be before the end of the month.
www.SynergyMFG.com
Old 06-13-2012, 04:22 PM   #157 (permalink)
PIG
PIG's Avatar
Member # 4502
www.SynergyMFG.com
Old 06-13-2012, 11:35 PM   #158 (permalink)
danf150's Avatar
Member # 52766
I take that as a yes...but would you please be more specific?
What material are the auto parts store replacements made out of?
What material are the Poly Performance ball joints made out of?
Old 06-19-2012, 11:09 PM   #159 (permalink)
PIG
PIG's Avatar
Member # 4502
Yes, the Synergy studs are manufactured from heat treated 4140 chromolly material... The stud material that the auto parts stores use I am sure vary between suppliers but most should be made from some sort of heat treated material but am not 100% sure. The BIG advantage to the Synergy parts are the fact that they don't use a plastic liner.
www.SynergyMFG.com
Old 06-21-2012, 03:51 PM   #160 (permalink)
Member # 219137
Have you done actual strength tests on these ball joints and tested the stock, MOOG, and Spicer joints as well?
As in putting them in presses at different angles to see where they pull apart? If so, how much stronger are they then stock and standard aftermarket joints? 10%, 25%, etc..
I am truly interested in these and think they "could" be a GREAT product if they do indeed offer significant strength increase over stock and current aftermarket joints!
I think of a 44 joint that is a strong as a stock 60 joint or close to it and say wow! Why hasn't someone done this before, just genius!
CZDiesel is offline   Reply With Quote
Old 06-22-2012, 11:30 AM   #161 (permalink)
PIG
PIG's Avatar
Member # 4502
We are actually in the middle of working on making a ball joint tester that follows SAE specifications. It is a project that we are working on with some engineering students at our local university, Cal Poly SLO. But to answer your question, no we have not done any actual strength tests to get a comparison to other BJs out there. You have to understand MOST of the issues guys are having are issues with wear and how much milage guys are getting out the parts. I'd say that MOST of the BJ's out there being supplied by other manufactures are going to be fairly close in overall strength but will vary tremendously in how fast they wear out under regular use. Thats where the Synergy parts really shine... Stay turned for the ball joint tester build!!!
www.SynergyMFG.com
Old 06-22-2012, 12:08 PM   #162 (permalink)
Member # 219137
Very cool.. Looking forward to it!
I would think you could just pull them apart in a hydraulic press and check to see the ft lbs it takes to do it to check for strength? It might not be SAE but you could call it independently verified tests
Anyway, as I said genius! Pure genius these are
Old 06-27-2012, 08:01 PM   #163 (permalink)
PIG
PIG's Avatar
Member # 4502
The testing device we are working on will be able to do a pull test as well along with a test that follows SAE standards.
www.SynergyMFG.com
Old 06-27-2012, 08:01 PM   #164 (permalink)
PIG
PIG's Avatar
Member # 4502
4122 parts are now in stock!!!
www.SynergyMFG.com
Old 07-08-2012, 05:06 AM   #165 (permalink)
jrodxj's Avatar
Member # 118176
jk dana 30 BJ's shipped to 26764
00' dakota 44/9 4.10's 36" sx's H1s double beadlocks
95' f-350 4dr longbed PSD
jrodxj is offline   Reply With Quote
Old 07-10-2012, 03:54 AM   #166 (permalink)
danf150's Avatar
Member # 52766
Yes, the Synergy studs are manufactured from heat treated 4140 chromoly material... The stud material that the auto parts stores use I am sure vary between suppliers but most should be made from some sort of heat treated material but am not 100% sure. The BIG advantage to the Synergy parts are the fact that they don't use a plastic liner.
Thanks for the response. I actually purchased these because I wanted stronger ball joints. As you know, a broken ball joint can do a lot of damage. I don't have a problem with premature ball joint wear, however, it's nice to know they'll last longer.
Old 07-29-2012, 03:04 PM   #167 (permalink)
Member # 219137
I started a thread here looking for some real world use and feedback..... One of the responses said that the joints need to be greased weekly? Is this correct?
If so do you recommend these as a off road only joint?
Old 07-30-2012, 04:53 AM   #168 (permalink)
jsawduste's Avatar
Member # 77571
x 2 on the maintenance schedule.
Sent with smoke signal.
jsawduste is offline   Reply With Quote
Old 07-30-2012, 09:03 AM   #169 (permalink)
danf150's Avatar
Member # 52766
The Synergy Suspension Heavy Duty Ball Joint instruction manual states,
"Lubricate the ball joints at every oil change using quality extreme pressure moly grease."
However, it's general knowledge to also grease the vehicle after every off-road outing.
Old 07-30-2012, 04:09 PM   #170 (permalink)
PIG
PIG's Avatar
Member # 4502
There is the correct answer. FYI, we are almost done with working out some grease to offer guys that is formulated specifically to be used with the Synergy ball joints?
www.SynergyMFG.com
Old 08-08-2012, 10:35 PM   #171 (permalink)
Weasel's Avatar
Member # 5639
Special grease? I currently use redline synthetic cv grease for everything. I'm taking apart my front axle in the next week for new axles and will be getting a set of these to replace the existing ball joints?
Just Add Lightness
I'd rather be simple-and-wrong than complicated-and-wrong.
Weasel is offline   Reply With Quote
Old 08-08-2012, 10:42 PM   #172 (permalink)
Weasel's Avatar
Member # 5639
Ah crap shipping late this month for XJ joints? Any idea how late? Need my axle back in by atleast the last weekend of the month.
Just Add Lightness
Old 08-09-2012, 07:55 AM   #173 (permalink)
PIG
PIG's Avatar
Member # 4502
We have our own formula for BJ/Chassis/Suspension grease about to be released. It has been in testing for quite awhile with VERY good results... Stay tuned!
Depends what year XJ's you are looking for... The 4121's are instock and the 4129's will be in by the end of the month.
www.SynergyMFG.com
Old 08-09-2012, 11:51 AM   #174 (permalink)
Weasel's Avatar
Member # 5639
89 Xj part number 4120 I think.
Just Add Lightness
Old 08-18-2012, 11:57 AM   #175 (permalink)
Member # 125322
Can I get a price on full set 4121 to 97420..... Thanks
hammerd is offline   Reply With Quote
