Member # 4502
***NEW*** Dana 30, Dana 44, Dana 60 Ball Joints From Synergy Suspension------------->
Synergy Suspension introduces the Jeep® JK Heavy Duty Front Ball Joint Set, designed to replace the factory ball joint that is prone to premature wear on lifted 2007-Current Jeep® Wrangler JKs with large off-road tires. Engineered and manufactured to outperform the factory ball joint assembly, a fully greasable sintered metal-on-metal bushing design promotes high wear resistance by eliminating problematic plastic liners found in OEM ball joints. Each ball joint boot is made from tear/wear resistant polyeurethane and includes all necessary hardware for installation. Synergy Suspension brings a complete set of 4 to market for only $250 MSRP. Yes, that’s a complete set of 4 for only $250 US dollars!
The Jeep JK Dana 30/44 units will be shipping this month. The other applications are still currently in R&D and will be available soon!!!! CLICK HERE FOR MORE INFO ONTHE JEEP JK UNITS Additional applications will be available soon: DANA 30 Part# 4120 Full Set (4) – Jeep XJ 1984-2001 – Jeep YJ 1987-1995 – Jeep ZJ 1993-1998 – Jeep TJ/LJ 1997-2006 – Jeep TJ/LJ Rubicon (Dana 44) 2003-2006 DANA 44 Part# 4121 Full Set (4) – Jeep CJ (Dana 30) 1972-1986 – Jeep Cherokee/Wagoneer/J10/J20 1972-1986 – IH Scout 1971-1980 – GM 1/2 Ton-3/4 Ton 4X4 1970-1986 – Ford Bronco, F150, F250 1971-1996 – Dodge 1/2 Ton 1972-1993 DANA 60 Part# 4122 Full Set (4) – Dodge 2500/3500 1994-1999 – Ford F-350 1992-1997 – Ford F-250/350 Super Duty 1999-Current – Ford F-450/550 Super Duty 1999-2004 – Ford Excursion 2000-2005 – Dynatrac, Currie, Tera Dana 60 Front Axles DODGE AAM 9.25 Part# 4123 Full Set (4) – Dodge 2500/3500 2003-Current ![]() ![]() ![]() ![]() The problem.....
Click the sig for everything you need to build a tube car www.SynergySuspension.com Cool stuff for your buggy, Jeep, Dodge 2500/3500 www.4130Clothing.com
A unique apparel line geared for the off-road enthusiast |
#5 (permalink) | |
Member # 4502
A realistic date on the other applications we are working on is prob about 6 months till we are actually shipping parts. These are still in the design and testing phases... YES!
Member # 80862
I need a set for 60 like now. I hope their out sooner than later.
www.facebook.com/EckoMotorsports www.partsmike.com www.savvyoffroad.com www.trail-gear.com |
#9 (permalink) | |
Member # 4502
That's the 1 application we skipped due to that fact that part was only on those trucks for 2 years. In order to make these parts and to sell them near the listed price points above we have to make 1000 sets per part #. We are just to not sure there is enough demand. If we start getting alot of requests for them we will make them...
Might want to look at some factory replacements if you need a fix now.
#12 (permalink) | |
Member # 4502
Working as fast as we can man!
#13 (permalink) |
Member # 150595
Good to see a company finally getting somewhere. Ballistic has still got there head up there ass, and has had for a while.
Nat http://www.pirate4x4.com/forum/showt...831074&page=19
Nat_sters Haul All [url]http://www.pirate4x4.com/forum/showthread.php?t=1004576[/url] Last edited by nat_ster; 01-10-2011 at 10:29 PM. |
#14 (permalink) | |
Member # 4502
#21 (permalink) | |||
Member # 4502
Right on! ![]() Quote:
Me too..... ALWAYS!
#22 (permalink) |
Member # 15557
I'd be willing to test a set too...... I'm about to build a 44HP with Chromos and 38's I bet ball joints are gone be the next week point.
[url]www.centexoffroad.com[/url] |
#24 (permalink) |
Member # 104351
Just replaced mine on an '05 Rubicon running 37's with 1.25" wheel spacers. Based on what I read here, I may be replacing them within 7K miles. Do you think your new design will hold up a lot longer with the exaggerated offset and 37" tires on a stock Rubi D44?
JK
05 Rubicon - 6" RE extreme LA - 37" MTR Kevlars - 4.88's and lots of other stuff |
#25 (permalink) |
Member # 77571
Mr.Pig,
without you divulging proprietary secrets. What is going to make your ball joint better then a commonly available unit ? Yes we can see the "plastic" removed from the design. Plus a grease fitting and channels for lubrication. What about the ball and socket itself ? Special materials (say Ampco) for instance or a powdered metal finish or ?? Will the design allow for the boots on RCV`s ? Shaft and threaded portion ? Preload adjustment if any ? Just wondering..........Hopefully you guys can score a home run with these. Have a set of Reid`s 44 knuckles that are just waiting for install. But not till a new and improved BJ (is there such a thing as an improved BJ ? ) 4121 is available.
