**New** Synergy Suspension Jeep JK Fixed Length HD Lower Control Arms---------> - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Vendor Forums > Poly Performance
Old 05-31-2011, 07:52 PM   #1 (permalink)
PIG
PIG's Avatar
Member # 4502
Description:
-Synergy Suspension Fixed Rear Lower Control Arm for Jeep JK.
-Suspension components feature an abrasive resistant powder coat finish for maximum durability and corrosion resistance
-Made from high quality crush resistant 1 3/4" X .188 Wall 1026 DOM tubing
-Arms are bent up for added ground clearance
-Features an OEM style bushing on both ends for extended permanence & minimized road vibration
-Arms are 1/2" longer than stock
-100% bolt on components assures an easy, trouble free installation with the use of basic hand tools
-Sold in pairs
Note: This length works well when using the stock length upper control arms and for longer upper control arms when using a CV style rear drive line and 3-4.5" of lift. If using a CV style rear drive line and you need the pinion pointed up towards the output on the t-case, we recommend these arms to be used in conjunction with PPM-8054 JK REAR ADJ UCAs for optimum drive line angles.
Lift/Caster Measurements
Stock---->6.5 Degrees
2" Lift---->5.5 Degrees
3" Lift---->5.0 Degrees
4.5" Lift---->4.5 Degrees
Click here to order the fronts!
Click here to order the rears!
Click the sig for everything you need to build a tube car
www.SynergySuspension.com
Cool stuff for your buggy, Jeep, Dodge 2500/3500
www.4130Clothing.com
A unique apparel line geared for the off-road enthusiast
PIG is offline   Reply With Quote
