Member # 217385
What do you guys think about this truck? I'm not new to the RC world but I'm getting away from the fast nitro stuff and getting into the crawling. I picked one of these up because it was cheap enough and will allow me to see if I really want to dip into this part of the hobby.
Give me your thoughts on the Redcat ROCKSLIDE RS10 XT and also what part brands are compatible with this for upgrades? Thanks |
Mini Jimmy's
Member # 100585
It may give you a glimpse into the world of crawling but you'll have to understand it is far from a quality crawler. If you like it you should look into getting into something of a better quality.
~ Team Futaba ~ Team Vanquish Products ~ Team Holmes Hobbies ~ Team TCS ~ Axial Racing ~ ~ Team * ~ The DMG ~ Freq E Dezigns ~ RC Jimmy's 4x4 ULTRA4 RC Goat Built IBEX |
Member # 217385
Right on, I just wanted to see if it will be of any interest and if I would even want to dive into it further. My big thing is, I want to get out of the nitro stuff just because it's a pain anymore dealing with the engines.
What would a "quality" rig be to start with if I am to dip further into this realm? |
#5 (permalink) | |
Mini Jimmy's
Member # 100585
For messing around out on the trails and such, the Axial Wraith or Axial SCX10 are great. Just go to www.rccrawler.com and start reading.
~ Team Futaba ~ Team Vanquish Products ~ Team Holmes Hobbies ~ Team TCS ~ Axial Racing ~ ~ Team * ~ The DMG ~ Freq E Dezigns ~ RC Jimmy's 4x4 ULTRA4 RC Goat Built IBEX Last edited by Harley0706; 05-07-2012 at 01:31 PM. |
#6 (permalink) | |
dick tater
Member # 187534
I hear those things don't like skateparks
dick tater
Member # 187534
http://cgi.ebay.com/ws/eBayISAPI.dll...m=170828265555
Also this thing is pretty sweet for the price and I've heard parts are interchangeable with axial. My buddy has a Axial Wraith and every time I talk to him he has busted something |
dick tater
Member # 187534
for those that don't like links
$359.00 RTR crawler High quality rc rock crawler features common componentry for easy interchangeability and upgradeability as well as ease of adaptability to other vehicles. For exmaple our axles will fit many other vehicles such as the Tamiya High Lift series, Axial AX10, HPI Wheelie King, as well as almost any other vehicles that uses a separate axle design. Axles are a realistic looking, string metal design with solid construction for added weight and durability. They feature 4 gear differential for maximum strength and power transfer. Also included are locking pins to lock the differential for extra traction when needed. The axle features multiple mounting points that can accommodate leaf springs as well as a multitude of link attachments. At the ends of the axle there are simulated brake drums that can be modified to look like disk brakes. The drive hexes incorporate a set screw that holds them on the axle when wheel is not attached. Full ball bearings are included with each axle. A CNC cut steel ring and pinion gear are the heart of this durable and rigid axle. Like the rest of the parts on these vehicles these axles lend themselves to the custom builder because of their flexibility of installation and extreme quality. CNC MACHINES ALUMINUM Chassis is a class leading design. Our chassis is a sturdy 6061 aluminum ladder frame design that is CNC cut to our rigid specifications. The 6mm thick chassis rails can accept leaf springs as well as virtually any axle and transmission design currently offered for maximum adaptability. There are 3 cross members made of 6mm think 6061 aluminum. The battery mounting cross member incorporates a proven ventilation slot design for lower battery operating temperatures and longer run times. The other cross members are 6mm thick for maximum strength. The cross members are secured with countersunk flat head 3mm screws for a clean look and less chance of hang up. There are 5 points to mount shocks to for maximum flexibility. The chassis is 17 1/8 inches long and 3 3/8 wide all holes are 3mm. Our chassis alone is an excellent starting point for any custom built RC scale truck project. SHOCKS shocks have realistic looks. Features include an internal spring, CNC aluminum bodies with aluminum rod ends. They also can be painted for a more custom look. Komodo shocks are offered in a 120mm and 90mm length. The 120mm shock compresses to 85.5mm and the 90mm shock compresses to 70mm. The rod end and shock cap feature a 3mm pivot ball for direct bolt on compatibility with most other vehicles. LINKS Links are CNC cut from 6061 aluminum and polished to a shine. They are 6.3mm in diameter. Komodo links come in pairs and can be usefully applied to other vehicles. |
#10 (permalink) | |
Mini Jimmy's
Member # 100585
The Wraith is the most fun I've had in a long time. The Slash got boring in a hurry and the Summit was about the same. The Wraith NEEDS upgrades but after that it amazing.
Member # 64145
The Wraith needs about $300 in upgrades before it can actually be abused.
I spent that before I even got through a complete pack, but now it's quite a bit of fun. I would not recommend it as an introductory crawler as you'll spend more time working the bugs out than driving it for quite a while. The SCX is more durable stock, cheaper, and still quite capable. The smaller tires reduce the total capability, but they make more terrain challenging and reward more precise driving. The small tires also essentially add durability to the axles which were originally designed for larger 2.2 tires. If you can find a used AX-10 then that'd be a good start as well. |
#12 (permalink) |
Member # 939
"EVERYTHING" Needs upgrades ! The RS10 is a great lil starter rig. Yes, it needs upgrades, so dose the Wraith ! I have an upgraded RS10 and it runs great and gives me many smiles on my lil back yard rock pile. Comping is NOT the end all, be all, to everything ! Just bashing around on the rocks is fun too !
![]() Run what ya brung and have fun !
I am a Sheep Dog, ... Wolves Beware ! |
#14 (permalink) |
Member # 78101
Keep in mind the wraith only needs upgrades because the buyer will ultimately want to upgrade it for better performance. Better performance often means more power that leads to broken parts.
I have several $100 into mine but because I love the truck. Friends of mine have had great luck with there stock wraiths. I've owned over 30 rc's and the wraith is my favorite by far! |
#15 (permalink) |
Always Busted
The red cats are fine if you tweak them a little. I've been happy with mine with the little improvements that i've made. For 150 bucks you cant really beat them, just upgrade as you go. Everyone says that the stock electronics are junk but after dropping off a ledge and being completely submerged in water, a days worth of drying out later and its perfectly fine. Not saying I wont upgrade in the future but they're not bad.
Fawk yea, redline that shit |
#16 (permalink) |
Member # 156136
I love my redcat! I know it's not a fancy comp rig or anything, but I can crawl wit the best of em. And I have FAR less money in it than all my friends wit axials and bergs. I've ordered most my parts from ZNO RC I believe it's called. The main thing is to lower the suspension, get the hardened pins for the spur gear and buy a good servo.... and get rid of rear steer, just more junk to deal with and fix!
#17 (permalink) |
Member # 222332
Looking @ owning a Redcat RS10 XT...
I've been doing a lot of reviewing on the newer XT but have heard many pros and cons. Can anyone give me a good solid review and arrows in the direction of mods? I'm thinking about doing the BTA steering on the front, TSL Super Swampers, steel gear high torque servos, steel differential gears and possibly lipo. And is the review I heard about the rear axle "lagging" actually true? And is that because of redcat's ESC?
#18 (permalink) |
Member # 216268
Check the Venom Creeper out. Great starting point and crawls really well.
https://www.ckrccrawlers.com/venom-c...en-p-1406.html |
#20 (permalink) | |
Member # 216268
If you're going to buy a cheap Chinese crawler, don't spend $359 on eBay. Order from the factories. http://store.rc4wd.com/Subzero-110-S...-RTR_p_15.html or http://www.alibaba.com/product-gs/42...k_Crawler.html I've had a Creeper for over a year and done a LOT of crawling with it, at the same time had an AX10. Venom crawled better, has less torque squat and is simple to maintain. Guess everyone has their own experiences. Last edited by marc.; 06-28-2012 at 06:41 PM. |
