Check out the new Axial Bomber! - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Radio Controlled Cars
Old 03-10-2017, 09:37 AM   #26 (permalink)
Member # 169788
Originally Posted by non-OP View Post
Holy crap, this thing needs a sway bar bad. I like the look of the Currie licensed version.
Yep, the torque twist is pretty impressive out of the box! I currently have the Axial "soft" sway bar on mine, but think I'd like to find something "softer"...
Another thing I would upgrade immediately (as mentioned earlier in this thread) is the servo horn, get an aluminum clamping 25t version, you will strip the stock plastic one in no time, probably why Axial provides 2 or 3 replacements in the box!
COcamper is offline   Reply With Quote Quick reply to this message
Old 03-10-2017, 09:43 AM   #27 (permalink)
Member # 397210
I have the Axial horn already. Once I break the stock on, i'll swap it over.
Also I really need to the pull the cage and change the drag brake to 50%. The 100% drag brake is a PITA to slow for corners
non-OP is offline   Reply With Quote Quick reply to this message
Old 03-11-2017, 08:23 PM   #28 (permalink)
Member # 397210
Took it out today and ran it for a a bit. Bone stock, even the front servo horn. Two massive crashes/tumbles and the thing is unhurt. Even the steering trim is fine, so no jumping teeth.
Sorry for the FB video links. Super steep hillside. Pretty far up there too
https://www.facebook.com/jason.bryng...11352915340800
https://www.facebook.com/jason.bryng...05005470483980
Old 03-11-2017, 10:48 PM   #29 (permalink)
Member # 121426
Love my bomber. Just scored on e on CL rtr for 225 with charger. Bought a 3s batt and commenced to wheelin. Having fun. Def beeds a sway bar though!
Sent from my SAMSUNG-SM-G890A using Tapatalk
85 Xcab Duals Longs 39.5's, ETC ETC..... Let's roll!
huntinrod is offline   Reply With Quote Quick reply to this message
Old 03-13-2017, 03:27 PM   #30 (permalink)
Member # 137692
This is the one thing I bought for mine fairly quickly. Helps with the torque twist a lot, definitely limits the rear articulation a ton but I'm not so sure that's a bad thing yet with my little bit of playing with it.
I am running the stock links, it probably needs shorter ones at some point but it does barely clear the cage.
About to order up a 3S battery as this thing definitely needs some more speed.
Everyone is recommending the Mamba Monster X + Holmes Puller Pro which closes in on $280 which i'm not dying to spend on this thing at the moment, especially when it will require new ring & pinions at a minimum and probably new drive & axle shafts.
Dude. He insulted me on the board and never answered for it.
75' Forty is offline   Reply With Quote Quick reply to this message
Old 03-27-2017, 10:14 AM   #31 (permalink)
Fabster
Randy's Avatar
Member # 3069
Glad you guys are enjoying the Bomber RC.
Bomber Kits and RTR's are in stock.
Bomberfab.com
Thanks for the support
Currie Enterprises
PSC Steering
BFGoodrich Tires
Reid Racing
King Shocks
Trail Ready Wheels
Baja Designes
K&N
CBM Engines
Bulldog Winch
Spidertrax
Maximum Trans
CBR Radiator
PRP seats
Steinjager
PCI
208 Motorsports
2015 KING
2013 KING
Randy is offline   Reply With Quote Quick reply to this message
Old 04-15-2017, 07:58 PM   #32 (permalink)
Member # 687570
first thing i did with mine was lower metal links and an extra set of shock all the way around. It worked great as a crawler and had tone of power on 3s. Got crazey and swapped in a 3900 brushless and mamba max esc. Lots of crazey speed, but definately needed the sways bars for sure at that point
Skinanboness is offline   Reply With Quote Quick reply to this message
Old 04-24-2017, 10:12 AM   #33 (permalink)
Member # 397210
Just added a bunch of parts, including metal drag link/tie rod, wider tires and heavier wheels. Broke the RTR servo internals after about 300 yds of running. Not that it was not unexpected but I was not even really bashing on it. Oh well. New mid-grade servo and a BEC just to get back up and running. I'll look into a better/stronger servo later
Old 04-25-2017, 05:40 AM   #34 (permalink)
Member # 137692
I think I did the same a couple days ago when I finally got mine running again.
Put a Holmes Hobbies Puller Pro and Mamba Monster X in mine with a 3 cell battery.
Thing is much quicker now, however seems extremely easy to topple over.
Need to fiddle with getting the throttle set up better for crawling now, but it should be a fun little basher while out walking my dog in the trails once it's got the weak links worked out.
Old 04-25-2017, 06:32 AM   #35 (permalink)
Member # 397210
More weight down low and reducing the drag brake made during much better. I also softened up the shock preload. It's better but will still flop over on occasion
Sent from my SM-G930V using Tapatalk
Old 04-25-2017, 11:51 AM   #36 (permalink)
Member # 86724
do you have a castle link?
get one. You can program throttle curves in the ESC.
Old 04-25-2017, 12:24 PM   #37 (permalink)
Member # 137692
I think i can switch the drag brake on/off with my remote. I just didn't have enough time to screw with it before I broke it
Not yet. The ESC came with a coupon for it, just haven't gotten around to it yet.
It should be a fun little car, but it does get expensive quick
Old 05-04-2017, 12:40 PM   #38 (permalink)
Member # 397210
What servos are you guys using for this thing? I broke the RTR one after upgrading to metal links with a metal horn. Took all of 200 yds of crawling big rocks.
Replaced it with Savox 231NG and it broke yesterday. Do i need to start looking at $100-150 titanium gear, digital coreless stuff?
Old 05-04-2017, 12:54 PM   #39 (permalink)
Member # 169788
I upgraded to the Savox SA-1283SG. So far it has been working great, it's quick and strong, and looks good too with a full aluminum housing...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 05-04-2017, 01:00 PM   #40 (permalink)
Member # 397210
Have metal draglink/tierod? Metal servo horn?
Old 05-04-2017, 01:07 PM   #41 (permalink)
Member # 169788
Yes, I've upgraded a ton of shit on this damn "toy"!! Metal servo horn, metal steering rods, metal links, metal driveshaft, replaced the lockers with spools, new axles front and rear, etc.
Old 05-04-2017, 01:11 PM   #42 (permalink)
Member # 397210
Thanks, just checking on the steering swap.
And yes I feel ya' on the upgrades. I've upgradded tires, beadlocks, two stage foams, metal links, swaybar, lightbars and in route are new aluminum skins and I just painted the cage.
Old 05-04-2017, 01:15 PM   #43 (permalink)
Member # 169788
Tires, wheels and foams are on my next upgrade list. What combo did you go with?
Old 05-04-2017, 01:28 PM   #44 (permalink)
Member # 397210
Pro-Line Flat Iron XL
Vanuqish KMC Enduro (these use SAE hardware, so your normal RC metric tools don't fit. I had to go dig up a hex wrench that worked)
SLW 350 hubs
Double Deuce foams. 5.5 medium in front without the thin outer and 6.0 medium in rear with all the included bits.
The tires are wide (XL) so it takes some effort to mount them with the DD foams. But once mounted, they are cool.
The fronts are about as soft as the RTR setup, but only until you hit the closed cell inner. They wrap and grab really well but don't totally fold over on a side hill. The rear are fairly firm, soft to about 1/4" then start to firm up
Old 05-04-2017, 02:40 PM   #45 (permalink)
Member # 169788
SLW 350 hubs
Cool, thanks for the info, I'll check those out.
Old 05-05-2017, 04:09 PM   #46 (permalink)
Member # 397210
my skins came today
Old 05-19-2017, 03:02 PM   #47 (permalink)
Member # 232400
I have a kit version, the thing is an amazing amount of fun! Im running a 3800kv motor on 3s and a 2 speed trans. Run stock tires for bashing around and Swamper XL for crawling. Only thing i managed to break were 2 6230 spectrum servos, I have replaced with a Hi-Tech titanium gear servo. Defiantly needs a sway bar if you drive any faster than crawler speed!
rocketron is offline   Reply With Quote Quick reply to this message
Old 05-31-2017, 02:26 PM   #48 (permalink)
Member # 757361
my skins came today
holy hell that thing is sweet. Just curious how did you change the color of the "chassis" with it being plastic? I would love to do that to mine.
cummins95 is offline   Reply With Quote Quick reply to this message
Old 05-31-2017, 04:47 PM   #49 (permalink)
Member # 397210
Took it apart totally, wiped with alcohol, good coat of white primer, 4 coats of matte orange, 2 coats of hammered clear. Took a week with dry time due to humidity.
It still scrapes off pretty easy so I'm not expecting much life. Broke the servo again so I haven't really run it to know for sure
Next time I'll order a new chassis (outer sides only should work) and paint then with the plastic specific stuff.
