Second Gen (84-88) Toyota Pickup Model - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Radio Controlled Cars
Old 09-16-2008, 10:23 AM   #1 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
Asked this in the "Post Your Crawlers" thread, but does anyone know of a second gen Toyota pickup (84-88) or first gen 4Runner (84-89) model of any sort?
There are first gen pickups and third gen pickup / second gen 4Runners available, but nada that I have found for the square wheelwell type. I've looked a bit in the aftermarket shells, but I'm not sure if I am missing something somewhere.
Would prefer a 1/24 or 1/25 scale model, but would consider just about anything - well, larger than a Matchbox...
94 GMC 6.5TD K1500 Yukon SLE / 93 Chevy 6.5TD K2500
85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 09-16-2008, 06:01 PM   #2 (permalink)
jalbrecht42's Avatar
Member # 52989
One that I remember (late 80's-early 90's vintage) was the Kyosho Big Brute. It was a 1/10th scale if I remember right.
Found this on google images...
http://image05.webshots.com/5/3/41/5...4JQePWC_ph.jpg
Probably hard to find a spare body for one but you never know.... Ebay has one for $500!
'47 Willys CJ-2A -- www.pirate4x4.com/forum/showthread.php?t=690670
jalbrecht42 is offline   Reply With Quote Quick reply to this message
Old 09-16-2008, 11:11 PM   #3 (permalink)
Member # 105183
if you want 1/24 I am pretty sure aoshima made a hilux from the mid 80's ..
if you want around 1/12 scale radio shack had one..
should be able to find them on ebay
sloppy12 is offline   Reply With Quote Quick reply to this message
Old 09-17-2008, 10:09 AM   #4 (permalink)
PAToyota's Avatar
Member # 37600
Ok, since nobody seems to understand the "generations" of Toyota pickups - one of these:
Squared out wheelwells instead of the rounded ones of the earlier eighties ('79 to '83) and later ones ('89+).
Standard cab, extended cab, or '84-'89 4Runner doesn't matter.
The Big Brute sort of has the right look, but isn't detailed enough.
Old 09-17-2008, 10:41 AM   #5 (permalink)
Member # 105183
oo you should have said you want a blue one from the start..
aoshima made that body style, I know I have seen one before I could be wrong on aoshima, or it could be long discontinued and impossible to find..
Old 09-17-2008, 11:17 AM   #6 (permalink)
PAToyota's Avatar
Member # 37600
Smartass...
Have to check on Aoshima.
Old 09-17-2008, 02:09 PM   #7 (permalink)
Member # 22836
go to www.rccrawler.com and search for toyota body, one of the vendors there is making them.
nosduj is offline   Reply With Quote Quick reply to this message
Old 09-17-2008, 05:11 PM   #8 (permalink)
Member # 100827
Send a message via AIM to smewhtguy
If I can find a 85- 89 runner body I am going to by an ax10.
I do math and stuff, on a professional level.
smewhtguy is offline   Reply With Quote Quick reply to this message
Old 09-19-2008, 06:30 AM   #9 (permalink)
PAToyota's Avatar
Member # 37600
Hmmm... Searched what I could on the RCCrawler site with Google. But even then kept running into "you need to sign up" when I'd try to follow links.
Still not finding much of anything except that there are even more third gens and first gens out there than I previously realized.
Old 09-19-2008, 01:44 PM   #10 (permalink)
Member # 69594
Unless you build it, there isn't a detailed 2nd gen truck body out there.
This guy is building a 1st Gen runner out of a Tamiya hilux body. There is a serious amount of talent going on here.
http://www.scale4x4rc.org/forums/showthread.php?t=24531
As far as I know, Aoshima never made a 2nd gen either, unless sloppy is referring to a 2nd gen Runner. IF they had made one, I would have found one and bought it when I was building a 1/24 scale rig.
Nothing happens when you die.
TrikeKid is offline   Reply With Quote Quick reply to this message
Old 09-19-2008, 02:45 PM   #11 (permalink)
PAToyota's Avatar
Member # 37600
Yeah, from the searching I've done I was pretty sure that none of the main mfgs had made one - but wasn't sure if anyone was making aftermarket bodies in small runs that I had missed.
Here is a guy who did a 4Runner out of a first gen pickup: http://www.rccrawler.com/forum/showthread.php?t=126772
Did a pretty nice job on the shell. Might have to follow the guy on the link you posted to see how his comes together. Although, after getting the body right he should do resin casts from it. There seems to be enough of a market for it.
Old 09-26-2008, 02:00 PM   #12 (permalink)
HighToy's Avatar
Member # 1983
Send a message via Yahoo to HighToy
holy crap those builds are awesome. Can't wait to see the final product on the square fendered 4runner.
Ryan
The Original Techno Hick.
HighToy is offline   Reply With Quote Quick reply to this message
Old 11-02-2008, 02:26 PM   #13 (permalink)
Member # 47016
here ya go. found a guy in canada that had some.
**TTC2013**
Spotter for SKOPs "Green Bastard"
Lil' lucifer is offline   Reply With Quote Quick reply to this message
Old 11-03-2008, 06:17 AM   #14 (permalink)
Member # 69594
Those aren't SECOND generation Toyotas! We know 1st Gens are easy to find.
Old 11-03-2008, 02:50 PM   #15 (permalink)
PAToyota's Avatar
Member # 37600
Thanks - seems everyone wants to point to first or third gen to "help" me out...
Old 11-03-2008, 04:32 PM   #16 (permalink)
Member # 100827
Its sucks I have searched my ass off and Came up with nothing also.
Old 11-04-2008, 07:31 AM   #17 (permalink)
PAToyota's Avatar
Member # 37600
I'm thinking that if one of those guys building the second gen cabs would pop a mold when he has it finished he'd have a ready market for them.
Old 11-15-2008, 07:48 AM   #18 (permalink)
Member # 92476
This guy started with a 1st gen body and turned it into a 4runner. Same process could be used for a pickup.
Hope that helps?
NluvwithXLR8ing is offline   Reply With Quote Quick reply to this message
Old 11-15-2008, 09:18 AM   #19 (permalink)
PAToyota's Avatar
Member # 37600
If you'll pay attention to previous posts, there are two other threads posted that did just that.
Old 12-07-2008, 01:20 PM   #20 (permalink)
Member # 52989
This is another modified bruiser/mountaineer/hilux (1st gen) into a 2nd gen. Doesn't really help the OP in his search, but is another example of how to make a 2nd gen out of something else. After reading this, I just have to say WOW.
Clampy (tribute) Build thread: http://www.rccrawler.com/forum/showthread.php?t=130383
Old 12-08-2008, 04:47 PM   #21 (permalink)
Member # 100827
Some of these guys have way to much time on there hands.
Old 12-08-2008, 10:06 PM   #22 (permalink)
Member # 105183
that could be said of any hobby
Old 12-09-2008, 09:10 AM   #23 (permalink)
PAToyota's Avatar
Member # 37600
Ain't that the truth!
Unfortunately, it never seems like you have enough time to do the things you want to...
Old 12-09-2008, 10:14 AM   #24 (permalink)
uda
Member # 34713
what about a 1/18 scale 4runner( some type of metal material )? I was told it wasn't FULLY detailed to look like a true 4runner but thats what it was labeled as.....I can get some pics in a few days if you PM me a email address.... Its my brothers, so I gotta ask him hopw much he wants for it...
PM me if interested so I can get some pics.. In Sacramento....
uda is offline   Reply With Quote Quick reply to this message
Old 12-09-2008, 11:11 AM   #25 (permalink)
PAToyota's Avatar
Member # 37600
Thanks, but looking for something fairly accurate.
