my pirate inspired scaler - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Radio Controlled Cars
Old 09-24-2008, 11:36 AM   #1 (permalink)
Member # 113332
Inspiration:
dont have a clue who's buggy it is, if you know I would like to get in touch with them....
I blew up the pics of the buggy until the tubing matched sizes. By my calculations 1/10 scale makes 1.5"/1.75" = 3/16". The buggy will have an r2d (with dig) 55t brushed motor and BTA steering when finished.
Axial axles
Jet Designs prototype BTA
55t
rc4wd r2d
1.9 rockstompers
hs 645mg (steer)
hs 81 (dig)
RCCjetboat is offline   Reply With Quote
Old 09-24-2008, 01:28 PM   #2 (permalink)
fordman1978's Avatar
Member # 83545
Send a message via Yahoo to fordman1978
looks great so far! i just started the cage, bumpers, and tire carrier for my bronco last night.
fordman1978 is offline   Reply With Quote
Old 09-24-2008, 05:19 PM   #3 (permalink)
Just ask'er out!
Grind's Avatar
Member # 86289
Sweet chassis, and trans!
Grind is offline   Reply With Quote
Old 09-24-2008, 10:40 PM   #4 (permalink)
I LYKE TRUX
OregonYO's Avatar
Member # 80235
Thats bad ass.
What axles are u using?
Also Im wanting to make some rock sliders, what brazing rod did you use?
Found out today oven cleaner will remove anodized color on aluminum.
I did my ax10 beadlocks.
MOLOTOV 2 Build
95' X-cab 4.3 Vortec, duals, SAS, CUSTOM
/forum/toyota-truck-4runner/657455-molotov-ii.html
OregonYO is offline   Reply With Quote
Old 09-24-2008, 10:56 PM   #5 (permalink)
Just ask'er out!
Grind's Avatar
Member # 86289
He's using Axial axles.
Old 09-25-2008, 06:24 AM   #6 (permalink)
Member # 113332
oven cleaner works pretty good at getting that ugly green off.
I used Harris safty silv 45 for all the brazing. People say you need oxy/mapp for it but I find that with straight Mapp and a turbo torch I get it plenty hot enough and Im not running out of o2 every 5 min.
I find that doing the 1/10 version works great as a sim for building in full scale. It realy allows you to work out some problems you cant see on a piece of paper or even a computer screen.
Old 09-25-2008, 10:05 AM   #7 (permalink)
Member # 83545
thats what i was thinking im doing small scale to get ideas for my fullsize shit.
Old 09-27-2008, 12:18 AM   #8 (permalink)
Member # 119125
Send a message via MSN to SnoopMaxx
I am watching this one
c",)
SnoopMaxx is offline   Reply With Quote
Old 09-29-2008, 09:36 AM   #9 (permalink)
Member # 113332
Took the scaler to a 1:1 wheelin buddies house for a BBQ... he has a "small" crawling course in his backyard. After a couple hrs of playing and several falls from the top of the course (about 6'). Now I need to get the body panels made.
Old 09-29-2008, 10:29 AM   #10 (permalink)
Just ask'er out!
Grind's Avatar
Member # 86289
Is that the behind the axle steering kit you buy or did you make that?
Old 09-29-2008, 12:36 PM   #11 (permalink)
Member # 113332
Thats the original prototype for 1 I will be selling over on RCcrawler... The final version will have a cleaner look and has the servo sitting straight versus at an angle.
With the 1.9" tires BTA was almost manditory
http://www.rccrawler.com/forum/showthread.php?t=136955
