New LOSI Crawler - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Radio Controlled Cars
Old 12-09-2008, 04:20 PM   #1 (permalink)
Member # 49733
New LOSI Crawler
i don't know how many of you have seen the new comp. crawler LOSI is releasing after the first of the year check it out you haven't:
"Team Losi Racing’s Comp Crawler is the first rock crawling platform in the industry to offer a revolutionary front and rear “dig” transmission. The use of an optional third channel setup allows the front or rear drive axle to be disengaged, locking the wheels in place and acting as a steering brake for precise lateral movement on and over obstacles. The transmission case has been fitted with adjustable servo mounts that will allow for the use of most “mini” servos and includes an aluminum servo arm. The third channel on a 3-channel radio (such as the Spektrum DX3R) allows the full use of the DIG transmission, and also requires a micro servo installation for actuation. If you do not have a 3-channel radio system or extra servo there is no need to worry - the Comp Crawler will function with full time 4wd with our without a dig servo hooked up."
Key Features
*Compact Front & Rear Locking (DIG) Center Transmission allows the crawler to overtake obstacles with ease
*Front and Rear Solid Axle with Worm Gear Drive
*4-Link Suspension offers 70 degrees of articulation and minimizes front and rear axle swing, allowing for more precise handling
*Zero Ackerman Steering provides class leading performance with 45 degrees of steering throw
*Front and Rear locked differential provides full time 4wd
*3-Piece 2.2" Bead Lock Wheels with aluminum outer rings
*National Champion 2.2 Losi Rock Claws Tires with foam inserts
*Twin Vertical Plate Chassis with adjustable upper shock mounts
*4" Aluminum Threaded Shocks with Titanium Nitride (TiNi) Shafts allow the suspension to articulate without any binds.
*Durable, telescoping CV drive shafts allow for increased steering range
*Aluminum Upper and Lower Suspension Links for added strength
*Lexan Grappler Pro body is optimized to USRCCA Rules and allows for clearance of the tires as they articulate
*Race Roller Chassis is preassembled; simply add electronics, paint the body and go
http://www.losi.com/Products/Default...rodID=LOSA0051
looks like a bad ass crawler
Vid:
http://www.youtube.com/watch?v=5GZLQd9Xiyw
NEED ONE 16/38.5 X 16.5 Swamper TSL (20-30%)to complete set PM if you have one!?!?!?!
godyilla is offline   Reply With Quote
Old 12-09-2008, 05:43 PM   #2 (permalink)
Deezul's Avatar
Member # 66238
looks sweet but not dumping my axial anytime soon
Rally post #422
Deezul is offline   Reply With Quote
Old 12-09-2008, 10:13 PM   #3 (permalink)
Member # 105183
it is another great option for people the worm gear axles will be awesome..
sloppy12 is offline   Reply With Quote
Old 12-10-2008, 03:22 AM   #4 (permalink)
Member # 108439
i'm debating on getting this .... it would be my first RC Crawler ... what kind of electronics would i need to get to complete this? just batteries? or are we talking batteries, motor, servo's and controller?
nevermind ... found info on the "features" page ...
nckwnchstr is offline   Reply With Quote
Old 12-10-2008, 07:58 AM   #5 (permalink)
Deezul's Avatar
Member # 66238
i'm not sold on worm gears yet. My Axial is a rock racer at this point and the drag on worm gears would probably suck for that.
Rally post #422
Old 12-10-2008, 10:32 AM   #6 (permalink)
Member # 105183
I have to agree with that... I would not want these axles for a racer or a scaler... but with that said I have not tried them yet and may change my mind once I have a set
Old 12-10-2008, 01:07 PM   #7 (permalink)
Member # 76617
Yeah I will have one
Wright racing
F-TOY #22
Hi desert driveline
losi
rcp crawlers
A Samauri is not an f-toy
A samauri is not an f-toy
benttoy is offline   Reply With Quote
Old 12-11-2008, 01:19 AM   #8 (permalink)
Weasel's Avatar
Member # 5639
I may get one, I have a micro right now and it's a blast. Just got it runing after the cat chewed up the tires.
Weasel is offline   Reply With Quote
Old 12-11-2008, 06:53 AM   #9 (permalink)
Member # 76617
Are you talking about the 1.9? those things are a blast! when I got mine I chased the cat around for about 30 min. he wont come near it now
Wright racing
F-TOY #22
Hi desert driveline
losi
rcp crawlers
Old 12-11-2008, 09:26 AM   #10 (permalink)
Weasel's Avatar
Member # 5639
1/36 size, yep chased the cat last night too.
Old 12-11-2008, 10:16 AM   #11 (permalink)
Member # 76617
Pay back for the tires?
Wright racing
F-TOY #22
Hi desert driveline
losi
rcp crawlers
Old 12-14-2008, 12:07 PM   #12 (permalink)
cannoncrawler's Avatar
Member # 57161
pretty excited to be getting one of these. Well actually my sone is getting it for christmas, but I will be using it heavily
" Prudence, indeed, will dictate that Governments long established should not be changed for light and transient causes....But when a long train of abuses and usurpations.... it is their right, it is their duty, to throw off such Government, and to provide new Guards for their future security."
cannoncrawler is offline   Reply With Quote
Old 12-14-2008, 12:40 PM   #13 (permalink)
White Trash Fab
smewhtguy's Avatar
Member # 100827
Send a message via AIM to smewhtguy
Buy 2 so you can drive together I bought me a ax10 and got my 6 year old little girl a mrc for x-mas.
"If you are gonna live life on the edge you better have good balance"
06 Tundra DC
The "Trifecta" 3 seat yota buggy
http://pirate4x4.com/forum/showthread.php?t=1027210
http://www.AddictedOffroad.com/
www.ruffstuffspecialties.com
http://f-o-a.com
smewhtguy is offline   Reply With Quote
Old 12-14-2008, 12:55 PM   #14 (permalink)
Member # 57161
I might get him the smaller RTR crawler. I believe it is the 1.9
Old 12-28-2008, 09:45 AM   #15 (permalink)
Member # 126120
Send a message via ICQ to twhccss
Red face Losi MCR
Got my mini great crawler I am a nubie. Chased a big black dog, not a good idea big dog bit rite though crawler. On another note front u-joint fell apart after twenty minutes, Losi said they will send new parts. Be carefull parts are extreamly small and can disapear in an instant. It will stop the fun instantly
twhccss is offline   Reply With Quote
Old 01-10-2009, 08:40 AM   #16 (permalink)
Member # 49733
has anyone gotten theirs yet?
Old 01-10-2009, 09:05 AM   #17 (permalink)
skulltoy's Avatar
Member # 10425
Send a message via AIM to skulltoy
They are not out yet.
--Radio Controlled Rockcrawling--
Team Carnage Crew 2008 XRRA Western Champions
skulltoy is offline   Reply With Quote
Old 01-10-2009, 03:08 PM   #18 (permalink)
CMP owner
MAD MAC's Avatar
Member # 10887
Send a message via AIM to MAD MAC Send a message via Yahoo to MAD MAC
Since I grew up with Losi stuff I will be getting one
I had the Jrx T and Jrx 2 I raced pretty much every week as a kid.
Every damn dollar I earned mowing, shoveling, and anything else we could do for cash went to our cars.
I still am a Losi Nut even thought they sold out I still believe they make a good product and are always innovative.
I still have a few cars
XXX-T
LST-2 With a ton of shit on it, Nitro cost to damn much money
Micro-T With lithium, it's ungodly fast.
Mini Crawler its just a blast.
I will be buying a 1/10 as soon as they come out.
I have already put shocks, links, flipped the tranny and ordered a lipo split pack for the Mini Crawler.
Its a sick addiction.
Mac
C&M PERFORMANCE MACHINE
CNC Laser Cutting Press Braking, H1 Wheel Centers, H1 Rock Rings, 37"Goodyear MT's, 37" Goodyear MTR's, 12 Bolt, 24 Bolt Wheels, Yukon Gear Distributor, Fabrication Parts and Accessories.
MAD MAC is offline   Reply With Quote
Old 01-10-2009, 07:23 PM   #19 (permalink)
Member # 73681
I love my AX10 but wish they would hurry up and release the Losi. It looks sweet!
solar1 is offline   Reply With Quote
Old 01-11-2009, 06:56 PM   #20 (permalink)
Member # 28623
I drive for Losi's rock crawling team, I've had the privilege to take the 2.2 Losi out for a weekend outing. It crawls very well... The front and rear dig works flawlessly, the steering is killer, and axles are pretty cool. The worm gear setup allows for a ton of diff clearance and control in technical stuff.
Simply put... It flat works
Currently, Losi is ironing out a few minor problems that we found in testing it, and working on the final gear ratios. Everyone at Losi wants to be 100% sure that this rig will dominate the competition. I will keep you guys posted on a release date once I know more.
Wright Racing
Hi-Desert Driveline
F-toy #22
Lazybum is offline   Reply With Quote
Old 01-14-2009, 02:22 PM   #21 (permalink)
Member # 127332
New guy here! I was going to get this but unfortunatly doesnt come out till like march!
So i decided on axials new scaler. I will definatly try to get one of these though, when tax refund comes inD
MiddleT is offline   Reply With Quote
Old 01-14-2009, 03:16 PM   #22 (permalink)
Whitewater's Avatar
Member # 89
Send a message via MSN to Whitewater Send a message via Yahoo to Whitewater
so for crawling and my first rig would I be better to get the AX10 or this thing to start with?
"Having too many 'things', American's spend their hours and money on the couch searching for a soul. A strange species we are... If I wanted to destroy a nation, I would give it too much and I would have it on it's knees, miserable, greedy and sick." -John Steinbeck
Whitewater is offline   Reply With Quote
Old 01-14-2009, 04:18 PM   #23 (permalink)
Administrator
Lance's Avatar
Member # 1
Send a message via Yahoo to Lance
Get a car NOW!!!! Let's get it!!!
Lance is offline   Reply With Quote
Old 01-15-2009, 06:54 PM   #24 (permalink)
CMP owner
MAD MAC's Avatar
Member # 10887
Lance your getting way to far into this Rc stuff.
Old 01-15-2009, 08:35 PM   #25 (permalink)
Administrator
Lance's Avatar
Member # 1
...Says my wife!
