AX10 - RTR - front locker doesn't fit? - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Radio Controlled Cars
Old 12-22-2008, 11:18 AM   #1 (permalink)
Administrator
Lance's Avatar
Member # 1
Send a message via Yahoo to Lance
Ok, I finally got one of these for Xmas (bought it for myself ) and am in the process of installing the front locker. What am I missing here? The "pins" on the locker are larger (square edged) than the openings in the carrier (which are rounded). Do I need to grind/file them down to fit, or am I missing somethign here?
Lance is offline   Reply With Quote
Old 12-22-2008, 11:52 AM   #2 (permalink)
4x4 Consultant
UGET IT's Avatar
Member # 227
Ahh Ha.....................I am stumped too??
Also the Link Kit needs more parts too.................I dont see how they install....
Method Motorsports
Follow Me Here: /forum/competitions-events/1057582-md-ca-ina-jk-america-get-trip.html
Email: kevin@methodmotorsports.net
WWW.METHODMOTORSPORTS.NET
UGET IT is offline   Reply With Quote
Old 12-22-2008, 12:33 PM   #3 (permalink)
Administrator
Lance's Avatar
Member # 1
I got mine in... Need a little love. I think you do need more parts for your links. I was doing a little reading, on the locker, and came across a dude who was sad he needed the rod end "kit" to install the links.
Old 12-22-2008, 12:49 PM   #4 (permalink)
Member # 3761
Send a message via ICQ to jeepik Send a message via AIM to jeepik
i dont have an RTR,
mine started as the regular kit
but i just put the Axial lockers in place of the factory green POS locker, and mine fit without any issues, slipped right in
I did dip the locker in grease prior to install ( a little grease never hurts)
Commy Bastid!!!
jeepik is offline   Reply With Quote
Old 12-22-2008, 01:00 PM   #5 (permalink)
4x4 Consultant
UGET IT's Avatar
Member # 227
Yep......Locker and motor upgrade will happen today. Pretty surprised at how well it does just out of the box....... I am folding the lower rear links when there is traction or bound up.......
Of course I left the owners manual at Rounds......
Method Motorsports
Follow Me Here: http://www.pirate4x4.com/forum/showthread.php?t=1057582
Old 12-22-2008, 04:46 PM   #6 (permalink)
TraxFD's Avatar
Member # 28771
I got the RTR during the summer. It did well but as the saying goes I wanted more. Yes those stipid plastic links suck(torque twist). As it sits now it has 55t motor, new esc, new servo, new tires, new weighted wheels, memory foams, aluminum links (upper-lower/front-rear/steering), hi-clearance steering knuckles, saddle batteries, new MIP drivelines, new '80s chevy body-cut fenderwells. These are just as bad as the real thing in adding new part to them. I still want new axles too.
Edit: oh yeah new shocks, and four link rear.
Hey God, Thanks for everything. Truly.
TraxFD is offline   Reply With Quote
Old 12-22-2008, 05:58 PM   #7 (permalink)
Deezul's Avatar
Member # 66238
it should fit w/out issue......i think it only goes one way. i am thinking of putting mine in....its a bit of a rock racer
Rally post #422
Deezul is offline   Reply With Quote
Old 12-22-2008, 06:48 PM   #8 (permalink)
Just ask'er out!
Grind's Avatar
Member # 86289
I don't know what you mean by square edge, could you possibly post a picture of what you currently have set up now? I've never heard of anything that needs to be ground down to fit into the carrier itself, it's usually the half circle then flat side.
Good luck.
Grind is offline   Reply With Quote
Old 12-22-2008, 07:20 PM   #9 (permalink)
DuCaTi MoNsTeR
Booger Weldz's Avatar
Member # 2931
weird?? my six year old put his front locker in his rtr after i cracked the 4 housing bolts loose for him...you want me to ask him for you kevvy???
Amongst the best of the toyota vendors:
Www.4wheelunderground.com
Www.addictedoffroad.com
Www.hellfire-fabworks.com
Booger Weldz is offline   Reply With Quote
Old 12-22-2008, 10:31 PM   #10 (permalink)
4x4 Consultant
UGET IT's Avatar
Member # 227
No prob for me....it was lance with the issue
Put that in ans the 55 Motor..........allot better. Cut some coat hanger wire and tape it to the links for some strenght......worked like a charm
Some foam cutting and tire grooving next..........
Yeah I needed another money pit hobbie..............like I need a shotgun to the mouth.........
Method Motorsports
Old 12-23-2008, 04:44 AM   #11 (permalink)
samb.'s Avatar
Member # 92335
there is a white seal around it you have to get off before the locker will slide in
EDIT you got your answer on RCcrawler so nvm
samb. is offline   Reply With Quote
Old 12-23-2008, 01:32 PM   #12 (permalink)
Member # 33206
You can fab new bottom links pretty easily. Get some Traxxas rod ends, 6-32 all thread, and 3/16 brakeline tubing, and go nuts. Cheap n EZ
The Modfather is offline   Reply With Quote
Old 12-23-2008, 05:35 PM   #13 (permalink)
Deezul's Avatar
Member # 66238
just buy the bent links.........not exactly a wallet buster
Rally post #422
Old 12-25-2008, 07:35 AM   #14 (permalink)
White Trash Fab
smewhtguy's Avatar
Member # 100827
Send a message via AIM to smewhtguy
$16 for the strc bent links,cheap and easy.
"If you are gonna live life on the edge you better have good balance"
06 Tundra DC
The "Trifecta" 3 seat yota buggy
http://pirate4x4.com/forum/showthread.php?t=1027210
http://www.AddictedOffroad.com/
www.ruffstuffspecialties.com
http://f-o-a.com
smewhtguy is offline   Reply With Quote
Old 12-26-2008, 07:14 AM   #15 (permalink)
cannoncrawler's Avatar
Member # 57161
amen to that!
I picked this up thinking it would be a fun cheap way to get me throught the winter till next year when I can bash the 1:1 again.
now I'm sinking money into this pile!
gawd this little thing is fun. (that's what she said)
" Prudence, indeed, will dictate that Governments long established should not be changed for light and transient causes....But when a long train of abuses and usurpations.... it is their right, it is their duty, to throw off such Government, and to provide new Guards for their future security."
cannoncrawler is offline   Reply With Quote
Old 12-26-2008, 09:59 PM   #16 (permalink)
2JSC's Avatar
Member # 118939
The rod end pack is needed if using the available aluminum links. The RTR has solid plastic links that incorporate the end for the swivel ball to sit in. The aluminum links need the rod ends threaded on.
I'm sure there are PLENTY of people with stock piled stock links and rod ends. I got a complete set from someone for ~$10 for my project.
2JSC is offline   Reply With Quote
Old 12-27-2008, 07:47 PM   #17 (permalink)
Deezul's Avatar
Member # 66238
or you can run du-bro rod ends
Rally post #422
Old 12-30-2008, 11:17 AM   #18 (permalink)
Member # 29
Lance, PM me if you want some better links. I may be able to send some out to you.
Dima
1974 FJ40 in the works
2006 F250 crew cab longbed powerstroke for towing duties
Flatty is offline   Reply With Quote
