Member # 102365
beadlock rings: how to
ok so i got bored today and decided that i needed more weight in my wheels
so i set out on a mission to build a set of beadlock rings first off i removed the stock wheels and BL ring ![]() ![]() next i measured the stock ring and new aluminum ![]() ![]() this is the material i am using
MOLON LABE Last edited by urbanmuddboger; 01-03-2009 at 05:09 PM. |
Member # 102365
next i got out a 2.5 inch hole saw and cut four circles out
![]() ![]() after i cut all the circles out i needed to find a drill bit so i cuold drill the center hole out so my nut driver would fit through the new ring it truned out to be a 1/2 inch ![]() then drill out the center hole and it will look like this
MOLON LABE |
Member # 102365
next you need to clean up the edges i used a a belt sander
![]() then i clamped the old ring onto the new one and drilled out the holes with a 5/64 drill bit ![]() be careful those little bits like to break ![]() now bolt um all together and go crawling ![]() then pull them all off and paint them
MOLON LABE Last edited by urbanmuddboger; 01-06-2009 at 11:15 AM. |
Member # 102365
i dont know the exact amount but they are alot heaver
i tryed to measure them with a fish scale but it did not read i need to find a digital scale so i can weigh them
MOLON LABE Last edited by urbanmuddboger; 01-03-2009 at 05:45 PM. |
Member # 105183
those came out pretty sweet..
one of the local guys makes some sweet ones out of bronze you can check em out here http://nostr.net/forums/showthread.php?t=328 I couldnt believe how heavy they were plus they look pretty sweet.. myself I just add led stick on weights inside the tires.. |
Member # 102365
ya i did add lead inside the tire
i just thought i needed more weight also i have a sheet of yellow brass about 3/16 inch thick that i was going to use but i thought that the alum looked better
MOLON LABE Last edited by urbanmuddboger; 01-03-2009 at 07:41 PM. |
White Trash Fab
They look cool but it has to be a pain in the ass if you drop the nut in there.
"If you are gonna live life on the edge you better have good balance" 06 Tundra DC The "Trifecta" 3 seat yota buggy ![]() http://pirate4x4.com/forum/showthread.php?t=1027210 http://www.AddictedOffroad.com/ www.ruffstuffspecialties.com http://f-o-a.com |
Nice looking rings
![]() We had a guy in our club that made a bunch out of stainless steel washers, that had beveled edges and countersunk holes for the bead lock screws. I don't know how heavy they were, except they were plenty heavy I'll look to see if I still have a set and post some pics...
Live Free Or Die! |
Member # 46308
i did this yesterday and i think it turned out great. my 2.5 holesaw was cutting the rings too small so i bumped up to the next size. im going to take them back off and put some swirl patterns in it tomorrow.
Bangin Bible Holla |
