crawler done the urban way - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Radio Controlled Cars
Old 01-07-2009, 09:54 PM   #1 (permalink)
Member # 102365
well mabye not "badass" but it crawls like no other crawler i have owned(this is the first)
specs
axial ax-10
novak 55t
novak crawler ESC
axial ar-1 reciver
axial servo
aluminum stnc skid plate
bent links all around
mirroed tranny
weighted wheels 7 oz each in the front and 4 in back plus super sweet BL rings
home built link plates for ESC and reciver
and a secret weapon
MOLON LABE
urbanmuddboger is offline   Reply With Quote
Old 01-07-2009, 09:58 PM   #2 (permalink)
Member # 102365
you can see the secret weapon in this pic its a pen tube slid over the steering links to act as a roller
MOLON LABE
Old 01-08-2009, 08:08 AM   #3 (permalink)
Just ask'er out!
Grind's Avatar
Member # 86289
Do you have stiffer coils on one side of the chassis? it looks like there coil'd tighter on the passenger side. Torque twist elimination?
Grind is offline   Reply With Quote
Old 01-08-2009, 10:22 AM   #4 (permalink)
Member # 102365
it is the same stifness i just cut the coil and streched it out for tourqe lean
it works alright
but i think the mirrored tranny helps the most
MOLON LABE
Old 01-08-2009, 10:29 AM   #5 (permalink)
Member # 85796
A little tuning and you would have a great crawler. Any reason your front shocks are on upside down?
BIGJOEDUCKSLAYER is offline   Reply With Quote
Old 01-08-2009, 04:13 PM   #6 (permalink)
Member # 102365
to put the weight of the oil at the lowest point?
idk i thought they looked mo betta this way
MOLON LABE
Old 01-08-2009, 10:42 PM   #7 (permalink)
Just ask'er out!
Grind's Avatar
Member # 86289
Mirrored tranny? is that another term for flipped or something?
Old 01-09-2009, 12:38 AM   #8 (permalink)
Member # 102365
yes its fliped (motor on the other side )
but the gears are still in the back
you have to pull the tranny apart and switch the in put shaft (were the spur gear goes)
its pretty stright forward
MOLON LABE
Old 01-09-2009, 08:01 AM   #9 (permalink)
Just ask'er out!
Grind's Avatar
Member # 86289
That's cool, never heard of that being done before. I have an R2 dig trans though. Don't think that would work right. Or maybe?
Old 01-09-2009, 05:15 PM   #10 (permalink)
Member # 22060
I'm really new to this rc crawler stuff. How would mirroring the tranny help? You are still twisting a drive shaft to transmit power. The action of turning that shaft will have its effects on the chassis no matter where you spin it from.
I must be missing something. How does it alleviate some of the twist?
A lower ratio in the diff - now that could eliminate some of the strain required to spin the shaft eliminating some of the twist. Too bad they're not available.
You've got a bad ass rig there. I have the RR as well and I've only made it to the fabbing up some decent links stage. Where did you get that belly pan?
sparky2 is offline   Reply With Quote
Old 01-09-2009, 05:48 PM   #11 (permalink)
Member # 113332
flipping the trans will put the weight of the motor toward the front of the center line. This helps in steep climbs. Running the shocks upside down is common but, stock axials will leak horribly though.
Drop that battery down off the top, there are several trays available to replace the front servo mount and hold your battery. It will be the single best thing you can do to improve the truck.
You have a great start, keep crawling!
RCCjetboat is offline   Reply With Quote
Old 01-09-2009, 07:49 PM   #12 (permalink)
Member # 102365
i got the belly pan at a local hobby shop but if you go to
http://www3.towerhobbies.com/cgi-bin...AdvancedSearch
there is also a ton of shit at rccrawler.com
edit RCjetboat hit the nail on the head i transfers the weight of the motor to the side that needs it
MOLON LABE
Old 02-11-2009, 12:06 AM   #13 (permalink)
Member # 102365
i did a little more to it today i will post up tomarrow
i figured out how to get better steering angle out of the stock "drive cups"
and some more stuff
MOLON LABE
