So what is the deal with Bruiser axles?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Radio Controlled Cars
Old 01-13-2009, 10:09 PM   #1 (permalink)
Member # 50177
I have a set of bruiser axles that I plan on building a buggy around but you don't see them much except under truggy's. I think they are the early style, they are metal housings with a one way bearing setup on the front wheel hubs. Is there any reason not to use them besides avaliabilty? I have seen aftermarket front wheel hubs to get rid of the one way bearing and in my search here I found a couple of referances to some mods by a guy named Rick.
One other question. I measured the wheels that came with the axles and came up with 1.19 at the bead seat so I would assume 2.2 tires fit the stock wheels????
Toyota Link Suspension Systems, Weld On Beadlocks, Custom Fabrication, and More
www.MayhemMetalWorks.com
________________________________________________
05 GMC 2500HD d-max, 87 4runner, X chassis rock buggy
my buggy build
http://www.pirate4x4.com/forum/showt...e33fc&t=488938
am4x4 is offline   Reply With Quote
Old 01-15-2009, 01:14 PM   #2 (permalink)
Member # 81026
I'm pretty familiar with the bruiser axles. I'm probably the guy you're referring to that does the bruiser axle mods.
There are actually quit a few flaws with them in stock form when it comes to perfermance. They are extremely wide and they have a special hub used on them so you can only use the rims that came with it. The steering setup is a poor design that has poor tolerances so after a little use it gets pretty sloppy. It's pretty difficult to get a good shim on the ring and pinion gear because of axle design and the ring gears aren't that strong to begin with. Gear reduction in the axle is also pretty poor since the ring gear is so small. Sorry, hate to point out all this bad stuff..... Then you have to factor in price. These axles are vintage and aren't made anymore. The only stock replacements you find are used and worth a pretty penny. They're also pretty tricky to setup with out using leaf springs.
Seems like there is no positives huh? They are one of the best looking axles in my opinion. Here's a thread of my truck and I'm running bruiser axles front and rear. I machine the rear axle to add a supporting sleeve and bearing, narrow the track and accept universal 12mm wheels. The front axle gets the old steering knuckles hacked off and replaced with an aluminum Axle C that I have machined which allows parts from a Tamiya TLT axle to be used. A lot stronger, smoother and allows universal 12mm wheels. Downfall is that it's $$$$$$$. I don't recommend them for a truck that'll be driven a lot or driven hard.
http://pirate4x4.com/forum/showthread.php?t=748219
If you'd like some pics let me know. Here is a longer build thread on the truck.
http://rccrawler.com/forum/showthrea...rummy%27s+yota
nickrummy is offline   Reply With Quote
Old 01-15-2009, 06:03 PM   #3 (permalink)
Member # 14783
I guess I should have got more money out of you for the 2 pairs you got from me!!!
Nick knows his stuff on the bruiser axles. Almost wish I had a set of his modded ones but my pig of a truck would hurt them.
88 2wd MJ!
It used to be a jeep thing...till all that shit broke!
jeep94xj is offline   Reply With Quote
Old 01-17-2009, 03:46 PM   #4 (permalink)
Member # 50177
Thanks for the input. I think I have changeed my mind about using the bruiser axles and I am going to hack up my T-MAXX to build a crawler out of.
Any idea how much the Bruiser axles, wheels, and tires are worth??? I also have a frame with leafs, shocks, motor, and a tranny that is missing some parts, any idea what that stuff is worth?
my buggy build
Old 01-17-2009, 05:56 PM   #5 (permalink)
78FORD4x4's Avatar
Member # 125311
Location: Sittin' here doin' my part to make sure the welfare checks cash.
look on ebay all of the bruiser parts are selling high
78FORD4x4 is offline   Reply With Quote
