Member # 125378
Scaled down Fun Buggy
Thought I would share this with you 1:1 builders over here now that I noticed Pirate4x4 has an RC area. I started this a few months ago and had my build thread over at RCCrawler.com.
I was breezing through Petersons site one day looking for ideas when I found Freds Fun Buggy in his blogs. After looking through his build pictures I knew this was the project for me. ![]() My Eritex Atlas Transfer case. ![]() ![]()
Member # 125378
my first hump was getting these made with out a cnc machine or welder
![]() so I measured up, drew it out on cardboard, traced it onto my steel, fired up the band saw, gouged out 4 pieces then put a drill bit through each one to come up with these. ![]() also tagged each frame hole with a slight counter sink to give the effect like the originals. ![]() for the top pieces just cut 2 thin slices and whacked some holes through them. ( even center punching my marks it seems i couldnt keep them straight :-( ) ![]() bolted in a couple of pillow balls ![]() and threw a couple pieces of stainless through them ![]() ![]() fired up the Mapp gas ![]() ![]()
Member # 125378
once the steel changed back to its normal color the filing and sanding began and whalla my first obstacle was done.
![]() ![]() ![]() hump 2 was gonna be the front shock mounts and keeping as close to original as i could. ![]() so i cut up some inner and outer pieces and brased them up the same width as a normal pillow ball. ![]() cut and trim a blank piece for the top ...... can even say i put my blood into this one lol ![]() blew some holes in them and sanded every thing down. ![]() ![]() ![]()
Member # 125378
little stunt shot for mock up and thinking
![]() ![]() ![]() just some more forming frame work ......... ![]() ![]() ![]() ![]() ![]() and as if overcoming the first 2 humps wasnt fun enough .......... now its time for another, the rear shock mounts.
Member # 125378
well i washed her up just to clean what was done and i started on the front bumpstops.
pics of my trusty bender. ![]() now for the rig ![]() ![]() ![]() Servo mount ![]() ![]() Eritex Atlas Transfercase mount ![]() ![]() Rear limiting strap ( in place for the real rigs winch ) ![]()
Member # 125378
well i got the motor almost done. i started building it the Hemi way but just wasnt happy with it, even built a matching manifold to the original.
![]() ![]() ![]() the dist up front wasnt doing it for me when trying to match the original so i pulled it out and went the GM way. ![]() ![]() still got a bit of work to do on the pulleys and the fuel injection/fuel pump ![]()
Member # 125378
got some styrene work done over the past week.
firewall is in ![]() got the radiator ![]() fuel tank and radiator built ![]() worked on my engine belly pan ![]() little dash work ![]() tank and radiator mocked up ![]() ![]() ![]() interior floor with shifter/switch in ![]() pedals done
Member # 125378
radiator and fuel tank painted up
![]() ![]() and some mock ups of it all together ![]() ![]() ![]() ![]() cant forget the juice .... little Optima should do it ![]() ![]() dash done with gauge pots in ..... just waiting on the gauge faces to show up
Member # 125378
got my gauges in the dash pots
![]() ![]() just have to install the GPS and the rest of the welder parts plus find where the keys went :lol: so i got my shocks in and started wrenching on the bottom. chewed out some shock mounts ( they'll get died black once done ) ![]() ![]() pretty darn close to looking like the real thing? ![]() ![]() and the front ![]() also got my pan rod setup
#12 (permalink) |
Member # 125378
now for some brain usage ....... how do i get this steering down to an inch?
![]() found some lever thingy for airplanes to use for mock up ![]() drilled some holes ![]() chopped it up, added some bushings and ball ends ![]() and i got something like this ![]() ![]() ![]() ![]() ![]() this is just the mock up piece, the finished piece is aluminum and a about 3mm longer allowing me more throw. so for the rear axle i dug out a block of the good stuff
#13 (permalink) |
Member # 125378
after a few hours of sawing, gnawing and chewing the fat off
![]() ![]() and after a little clean up ![]() ![]() camera batteries died before i could get mocked up pictures :roll: but they'll be soon. well thats about it for now. she did stand overnight on shocks with about 4'' of belly clearance :roll: 110mm i got are just a bit too tall so gonna grab some 90mms this week. but she is painted .................................................. ............... ![]() ![]() ![]()
#14 (permalink) |
Member # 125378
After I painted it I noticed some weird effects in the paint and that it wasnt sticking to well. I painted the frame the same way I did my FJ project but something wasnt right. My Fj has rubbed some rocks well and didnt chip on me but this was chipping with my finger nail just to easy, I believe my black paint was just old and didnt bake well into the primer. Well I stripped it all back down with Purple power (this stuff is great) and found a member of another club that was willing to sandblast it again for me so now I sit patiently waiting for that then its off for a better paint job.
teaser shot of it sitting on suspension ![]() I just had to send my engine back to the builders to finish the injector lines and fuel rail. ![]() ![]() ![]() got my overflow tank built ![]() and redid my rear air tank and battery hold down ![]() also got my Optima wired up ![]() luggage rack/light bar all made up ![]() ![]()
#15 (permalink) |
Member # 125378
cant skimp out now ...... made my headlights (this i wouldnt wish upon even my worse enemy, took some brain work and the right model parts)
draw ![]() fit the light bucket ![]() cut and file ![]() twice :shock: ![]() wire ![]() and finally paint ![]() ![]() and the lovely windwhield
#16 (permalink) |
Member # 125378
and window sealer
![]() ![]() got curious about aluminum steering blocks and noticed the resemblance in the RC4WD ones and some stock TLT ones. i just knew this would be a weak spot for me so better to fix it now then after i break one.:roll: measured up the stock ones ![]() measured up some TLT ones from TCS ![]() perfect match! ![]() ![]() ![]() well theres definitely more to come ............ thanks for watching |
#17 (permalink) |
4x4 Consultant
Member # 227
Jesus..................
Method Motorsports Follow Me Here: /forum/competitions-events/1057582-md-ca-ina-jk-america-get-trip.html Email: kevin@methodmotorsports.net WWW.METHODMOTORSPORTS.NET |
#19 (permalink) | |
Member # 97119
You should build a real truck, you have so much work into that r/c that you could have your own fun buggy real scale lol
91 Ford F 350 24v Fummins Tow Rig FUMMINS FOR SALE http://www.pirate4x4.com/forum/showt...006&highlight= Quote:
Oh how the tables have turned Slitty
#21 (permalink) |
Member # 52488
That is completely SICK!!! I'd be in a padded room by now trying to get all that small tube work and detail done on that scale.
Feel free to send it to me till you get your sanity back. I'll take GOOD care of it for you. lol
87 YJ, 4:56s 1tons, 383/350, 205 T-case. "If you don't want it broke it, DON'T Let me drive it"!!! |
#23 (permalink) |
Member # 28604
![]() Is there some special "not finished" detail I'm noticing about this diff cover versus the other pics of the RC axle??? EDIT: I'm looking at the 1:1 axle pics in post #1, compared to the RC axle in post #13, versus the look of the cover pictured above... Hmmm? Last edited by Rerock; 01-21-2009 at 10:31 AM. |
#24 (permalink) |
Damn! I'm not sure if I'm more impressed with the 1:1 build or the scale build...
GET INVOLVED - Join the Blue Ribbon Coalition SIGN THE PETITION - SAVETHEHAMMERS - #85 '93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K '85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild) |
