Member # 127709
Can anyone help
I under stand the pro's of fliping the tranny in my ax10. but I was hopeing someone could give me some simple directions to do so. I love this ax10 it is so much fun, I have done a bunch of mods and I think fliping the tranny might be next
![]() I have pretty much done all the mods that CK crawlers say make it a stage 3, but I am still looking for more mod to do so I would also apriceate any other suggestions. thanks in advance.
Member # 113332
if you search on rccrawler.com you will find full right ups...
Basically you just assemble the trans backwards and flip the needed stuff around. Its actually simple mod. |
Member # 127709
thanks, one more question I see some people running with the bent lower links turned around on the rear. any advantage, I guesss I thaught that there would be an interferince issiue with upper three link. any one tryed this?
Lets think about this--whats a BIG advantage? Clearance....... So yes bent links help
Why is it we all are for doing the same thing--but yet we can not work together to achieve it Mike Crash Kash The new live streaming video crashfab |
Member # 113332
but they also allow your DS's to come in contact with the rocks more. On my shafted rigs I always ran straight links so that they would act as rock sliders. With stock shafts or even jato shafts you run the risk of tearing 1 off. If it was me, I would upgrade to punishers if you plan to run bent links.
White Trash Fab
You can do it the ghetto way and just swap your axles around and then use your rx to reverse the speed control direction. Ghetto but it works.
"If you are gonna live life on the edge you better have good balance" 06 Tundra DC The "Trifecta" 3 seat yota buggy ![]() http://pirate4x4.com/forum/showthread.php?t=1027210 http://www.AddictedOffroad.com/ www.ruffstuffspecialties.com http://f-o-a.com |
#8 (permalink) | |
But you gotta look at it like this Here is a rig with straight links as far as the width \____/ And a rig with bent links \__/ Same theory can be said about how wide your chassis is. These are just things I have learned by building numerous crawlers and compeeting for some time now--addicting
#9 (permalink) | |
Member # 127709
