Hydraulic Steering Scorpion Tuber - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Radio Controlled Cars
Old 02-03-2009, 06:55 PM   #1 (permalink)
Member # 19156
Frame was built by John Boyer from 1/8 in steel rod (not tube)
Has TXT axles with full bearings
Super Rooster ESC
55 turn lathe motor mounted to GD-600 which is mounted to a TXT transmission
Maximizer solid black beadlocks with rock rings I cut on a manual mill
HPI Savage tires
Full hydraulic steering system (pump/reservoir, valves w/ Futaba micro servos, and four cylinders). System is rated at 12lbs of linear force per axle@150psi but actual pressures and steering forces vary with the load placed on the steering system.
Two cylinders per axle in a push/pull configuration.
$2,000. Shipping extra - it's a heavy fuker.
No trades. If it doesn't sell here it'll go to eBay.
A good paragraph should be like a skirt. Long enough to cover the subject but short enough to keep your attention.
ProjectTwin is offline   Reply With Quote
Old 02-03-2009, 07:38 PM   #2 (permalink)
CMP owner
MAD MAC's Avatar
Member # 10887
Send a message via AIM to MAD MAC Send a message via Yahoo to MAD MAC
I saw the steering a long time ago it has a bunch of super small shit in it, way cool though. I remember it having a potentiometer for some type of return to center I think?
Mac
C&M PERFORMANCE MACHINE
CNC Laser Cutting Press Braking, H1 Wheel Centers, H1 Rock Rings, 37"Goodyear MT's, 37" Goodyear MTR's, 12 Bolt, 24 Bolt Wheels, Yukon Gear Distributor, Fabrication Parts and Accessories.
MAD MAC is offline   Reply With Quote
Old 02-03-2009, 09:22 PM   #3 (permalink)
Member # 19156
Yeah, the rear can be set up for a return to center.
Using that gives you a full left/center/full right steering option on the rear.
Otherwise you're driving the rear just like the front...only on different channels.
