Rummy's Monster Chevy - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Radio Controlled Cars
Old 02-04-2009, 06:23 AM   #1 (permalink)
Member # 81026
This isn't really a crawler but thought you guys might get a kick out of it. I just wanted something big to run around outside in the snow and bash with.
Updated 09.09.09
Truck Specs
- 1/6th scale Chevy Silverado body from Wallie World
- Modded TXT chassis with extended upper shock mounts (I have ahd some chassis plates design in CAD I've been trying to get machined but they're to big for most people to do)
- Integy Savage shocks de-anodized and running MGT springs 40wt oil
- Junfac rod ends, 10-32 all thread sleeved with 1/2" OD Delrin
- X-factor Axles converted to 17mm hexes (From a Mammoth ST). Rear Axle is locked front axle has 10k oil. Custom Servo mount I designed and had laser cut out of 16ga steel.
- Ofna full offset rims (I want to change out to something nicer)
- Jumbo Kong tires (8.5" OD)
- E-maxx Trans converted to single speed
- Revo drive shafts (took about 4 complete shafts to make them long enough)
Electronic Specs
- MMM V3 ESC with CC BEC
- Hitec 5995 Steering Servo
- (2) 7T Cobalt Puller Motors
- Turnigy 3S 20C 5000mah lipo
- Spekky receiver (3Pk radio)
YouTube - Junkyard Testing
This is the only picture I have next to 1/10th vehicle. This was a mock up before I got the wheelbase corrected.
nickrummy is offline   Reply With Quote
Old 02-04-2009, 10:27 AM   #2 (permalink)
Member # 102365
that thing i huge
now build a jump for it and report back
MOLON LABE
urbanmuddboger is offline   Reply With Quote
Old 02-04-2009, 10:36 AM   #3 (permalink)
Member # 128865
trade ya
trade you for a well built clod crawler. all set up for super class. with many many parts
360powerdNISSAN is offline   Reply With Quote
Old 02-04-2009, 11:42 AM   #4 (permalink)
Member # 81026
No thanks
Old 09-09-2009, 06:23 AM   #5 (permalink)
Member # 81026
I was over here reading up on some other info and forgot I had this thread started over here. I had the truck tore down and had a chassis designed in CAD I was trying to get machined. Couldn't get anyone to do it so decided to just put it back together to run it. I was getting tired of seeing it sitting on the workbench in parts.
I have a bunch of photos and a few videos so it might be a few posts. Hope that's ok......
I rebuilt the transmission and converted it to a single speed to get rid of some of that rotational mass and cut back on some of the slop. I also changed out shocks. I had plastic shocks from a savage before and now I'm running some aluminum savage shocks with MGT springs. This helped the suspension A LOT.
New shock setup.
Freshly rebuilt trans
Chassis back together. I was going for rear steering but after doing the test run found that the servo I had just didn't how the power to hold the wheels straight under a load (and it's a good 200oz servo too)
Chevy Testing Video
Old 09-09-2009, 06:26 AM   #6 (permalink)
Member # 81026
Another testing session.
Took it to the rocks to see how it would do. The axles complained quite a bit (can't keep the ring and pinion from stripping) but other than that it had plenty of power with the current gearing and the suspension seems pretty stable. Center of gravity was a lot better than I thought. I'm not running any foams at all in the tires. Sometimes it's ok and other times it's not, mainly when there is a heavy load on one tire. I think I'm going to have to modify the stock foams and put them back in.There weren't to many places it wouldn't go. No real challenging climbs.
Then it was over to the baseball field for some low traction high speed testing! They didn't mind me running for a few minutes.
You can definitely see the need for foams when running wide open.
To much fun!
Old 09-09-2009, 06:31 AM   #7 (permalink)
Member # 81026
Then it was time to get a little muddy
Didn't get to much video. It was a new place to run with some massive hills and TONS of mud. I actually got MYSELF stuck in the mud haha
Chevy parking lot bash video
Then towards the end I was racing up a hill against a slash and drifted over to the left and caught a downed tree head on.....
Ended up snapping the output of the diff off and obviously destroyed the axle housing. Broke the housing on the servo and smashed up the servo arm too. Not to bad for a 20lb truck probably doing around 20mph and stopping instantly.
I have lots of spare parts though so didn't take long to get it back up and running. Here are a couple shots out running on some trails with another guy's trucks for size comparison. The jeep has TLT axles and is a 1.9.
Poser shot
Old 09-09-2009, 05:40 PM   #8 (permalink)
Member # 129038
sweet rig like the videos do you have one of it muding
heminutt is offline   Reply With Quote
Old 09-10-2009, 07:00 AM   #9 (permalink)
Member # 81026
No muddin videos right now. I'll try and get some soon.
Old 09-10-2009, 10:34 PM   #10 (permalink)
Member # 105183
Want to goto ellet sunday?? We can get some mud on that thing.. I will get the wienie king ready I have to put a pinion on it and I am ready
We can park on that backstreet and goin threw the park so we are not trespassing as much
sloppy12 is offline   Reply With Quote
Old 09-11-2009, 07:43 AM   #11 (permalink)
Member # 81026
The diffs are on their last leg so I might as well end their life in some mud
I'll give you a call when I figure out what the weekend plans are. I should be able to come out and run for an hour or so. My problem last time was no one to take the video. I'd like to try some of those hill climbs out there too
Old 09-11-2009, 07:35 PM   #12 (permalink)
Member # 105183
well no problem I will drive it for you you shot the video
I talked to nat. She said she is in for sunday to maybe.. She was not to excited about 9 though
Old 10-12-2009, 07:26 AM   #13 (permalink)
Member # 81026
Here's a thread I made with a muddin video
http://pirate4x4.com/forum/showthrea...566&highlight=
While waiting on the two speed to get here I started looking into something else I've always wanted to do with an RC. It's been done before so it's nothing amazing but I wanted to approach it differently.
YouTube - Monster Truck Goes Sailing is something I'm sure most of you guys have seen and know about.
Stopped at the local Harbor Freight and found some inner tubes that fit inside the Jumbo Kongs. 8" OD x 2.5"w wide for a 4" rim. I'm running 3.2" rims but that's ok.
Deflated inner tube
Added a little air to see how the fit would be
Not to bad. A little narrow.
Drilled a through hole for the valve stem
Put the tire on.
Added about 10psi to see what would happen.
Since the tube was too narrow it didn't stay centered.
I took the stock foam which is 4" wide and cut 2" out of the center. Then I used the 1" rings left over on either side of the inner tube inside the tire.
Old 10-12-2009, 07:28 AM   #14 (permalink)
Member # 81026
Inflated to 20psi (on mistake, thought the gauge said 10psi) next to a jumbo kong that has nothing inside it.
You're probable wondering the size difference? The stock Kong measured 8.4". The inflated Kong?
Yes, it's insanely big!
However, 20psi was too much and the inner tube blew sometime over night. I have to pick up another one at lunch today. I built the 3 other tires and they have all held at 10psi so far and measure around 9" OD
