am4x4 gets an AX10 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Radio Controlled Cars
Old 02-13-2009, 10:25 PM   #1 (permalink)
Member # 50177
am4x4 gets an AX10
Thought I would post up some pics of my new toy. It's not that special yet but I have done some tricks to get it working a little better than stock. I have only had it on real rocks once so far but it seemed to work way better that my buddies stock rtr. To bad I forgot my camera that day. I will get some action shots when the rain stops
AX10 ARTR
Castle sidewinder esc
Integy 55T
Old ass futaba Tx and Rx
Weak old Futaba servo that can barely turn the wheels (soon to be upraded)
TCS 8cell split packs
Mirrored trans
Stock shocks with shorter/softer assocated springs+internal pen springs
Modded stock skid plate to inboard links at frame end
rear shocks and links moved outboard at axle end
All link/shock pivot balls replaced with Traxxas balls that allow more angle
Weighted and drilled wheels
All plastic nuts replaced with real hardware
TCS delron 4 link plates front and rear
TCS delron split pack axle mounts
Trimmed body
Lowered to 2 1/2" belly clearance
safety wired driveshafts to keep them from poping off
Toyota Link Suspension Systems, Weld On Beadlocks, Custom Fabrication, and More
www.MayhemMetalWorks.com
________________________________________________
05 GMC 2500HD d-max, 87 4runner, X chassis rock buggy
my buggy build
http://www.pirate4x4.com/forum/showt...e33fc&t=488938
am4x4 is online now   Reply With Quote
Old 02-13-2009, 10:42 PM   #2 (permalink)
Member # 50177
more pics
my buggy build
Old 02-13-2009, 10:56 PM   #3 (permalink)
Member # 50177
neked pics
my buggy build
Old 02-14-2009, 07:27 AM   #4 (permalink)
Member # 126428
Nice! I was gonna buy one of those but decided to go with the losi.
CJ-6 is offline   Reply With Quote
Old 02-14-2009, 07:47 AM   #5 (permalink)
Member # 50177
I thought about waiting for the new losi but I am impatient and wanted it before KOH. I also like tinkering with things and where is the fun in buying something that doesn't need some tweaks here and there.
my buggy build
Old 02-14-2009, 11:37 PM   #6 (permalink)
Member # 22060
Lookin good.............. Now go scratch up those diffs a bit
You went the opposite way I did for the shocks. You went wider and softer. I went inboard with stock springs to try and free up some flex (amplified torque twist though).
How is it working for you?
sparky2 is offline   Reply With Quote
Old 02-15-2009, 10:56 PM   #7 (permalink)
Member # 50177
they are scratched up now, along with the skid plate, links, roof, ect.
The rear end set up seems to work really good, I don't have much to compare it to but I have not noticed any torque twist at all
Why would you want more flex than stock? I limited mine quite a bit. In addition to relocating the shocks I put springs inside which limit droop and I added 6mm of vacume hose on the shock shaft to limit compression. Too much flex is a bad thing, mine had 90 deg stock and I have it down to about 60 deg now.
my buggy build
Old 02-16-2009, 05:42 AM   #8 (permalink)
Member # 129544
what moter do u have is it a 55 turn
rcfreak is offline   Reply With Quote
Old 02-16-2009, 11:48 AM   #9 (permalink)
Member # 50177
yep, integy 55t lathe
my buggy build
Old 02-18-2009, 01:17 PM   #10 (permalink)
Member # 117486
Running a Sidewinder you should try it on 3s Lipo. Slow speed crawlability from the 55t plus wheelspeed. We love ours.
John82601 is offline   Reply With Quote
Old 02-21-2009, 07:34 PM   #11 (permalink)
Member # 22060
I guess I should clarify a little. I wasn't looking for more flex in terms of more angle. I was looking for easier flex within the desired range. Damned thing would tip over before rubbing the tires on the RTR truck body. I'm currently at around 70deg of free and smooth flex before hitting the fuel line bump stops. Before toying with it, it would allow you to force it way beyond that, but began to bind up, and the springs fought articulation so much that it flopped all the time.
At this point I think I have reached the limits of the stock springs. I will relocate them to a wider stance with softer springs. Hopefully that will curb some torque twist and maintain or better yet improve the action of the suspension some.
Old 02-21-2009, 10:12 PM   #12 (permalink)
fairlane_68's Avatar
Member # 77346
Not that I need another mini-money pit ( I already have two T-Maxx's), but how much do those run?
fairlane_68 is offline   Reply With Quote
Old 02-21-2009, 11:29 PM   #13 (permalink)
Member # 22060
Cost - as much or as little as you like within reason.
A RTR that will keep the kids happy with just enough speed to do some bashing will run you around $240.
They go up from there as you get the ARTR or the kit version. (Do some searching to find out what best fits you) As said above the sky is the limit - if you have to have the best of everything, you could sink near $2K into one. A nicely capable rig with decent electronics, a few tires for different terrains, etc. - could be near $500 to $700.
Might also search other brands - they are similar in price range, but vary in how they get the job done.
Old 02-22-2009, 11:00 AM   #14 (permalink)
Member # 77346
That right there rules me out. I started out with a basic RTR T-Maxx, and went nuts with it when I was stationed in Korea. The only thing original on it now is the throttle servo. These little bastards are addictive fun. I can see myself getting the ARTR AX10, and trying to fit a nitro motor on it. I think it can be done...
Old 02-22-2009, 08:50 PM   #15 (permalink)
PJR
Member # 3811
Send a message via Yahoo to PJR
But why.......
It's a shame stupidity isn't painful
PJR is offline   Reply With Quote
Old 02-23-2009, 10:17 AM   #16 (permalink)
Member # 77346
Originally Posted by PJR View Post
But why.......
Ah...but why not?
While I was overseas, alot of my time and effort went into making my T-Maxx a reliable crawler. And it worked. And I love the smell and sound of a nitro engine...
Old 02-23-2009, 12:13 PM   #17 (permalink)
Member # 50177
The first thing I did was get rid of those stiff ass stock springs. I am using some shorter, softer springs that came with some associated shocks for my t-max. I guess you could say I have a semi droop setup, I have up and down travel from ride height. The only problem I had with moving the bottoms of the shocks out is the shock cap would bind on the frame. To fix this I cut the stock pivot ball off the shock cap and screwed a short link end on instead. when I did that mod it also allowed me to move the shock a little more outboard at the frame. I will try to get some pics up soon.
my buggy build
Old 02-23-2009, 06:57 PM   #18 (permalink)
Member # 50177
here are some some pics of the updated upper shock mounting
my buggy build
Old 02-23-2009, 07:01 PM   #19 (permalink)
Member # 50177
And finally some wheeling pics
my buggy build
Old 02-23-2009, 10:57 PM   #20 (permalink)
Member # 50177
Last time I was out I took a tumble down an eight foot almost cliff and landed on the side of the right rear tire. When it hit it broke the rear 4 link plate and the rear axle housing.I had been wanting longer upper links anyway so instead of buying a new 4 link plate I cut the old one down a little and drilled new holes further back and further apart. To make up the additional link lenth I used some 1/4in spacers from the hardware store. moving the links apart at the axle allowed me to get rid on the factory spacers between the link end and the frame. I ended up with a 99mm upper link which is about 79% as long as my lowers. That would be about perfect in the 1:1 world so we will see how it plays out in 1:10
my buggy build
