Special offer on the all GAZ shocks * Quality backed by expertise! - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Rally Racing
Old 04-26-2011, 07:51 AM   #1 (permalink)
MultiTasKing
WorldRallyTeam's Avatar
Member # 165307
Thumbs up Special offer on the all GAZ shocks * Quality backed by expertise!
We have partned up with GAZ SHOCKS and would like to invite you to check out their 2011 CATALOG.
The GAZ gear will be distributed by another partner of ours, CASANOVA MOTORSPORTS (who is also a Yellow Star Dealer here on Pirate offering Factory Direct Deals).
So if your looking for new dampers, coil overs, or a full racing suspension for your rally car, autocross, or daily driver look no further. GAZ has what you need.
10% off to all Pirate member PM for a quote or click QUOTES and send us a message
Here is the GAZ SHOCKS PRODUCT RANGE
The Minority Racer®
The first and only minority racing team in world racing rock & desert motorsports, plus rally!
Powered By:
VEHO MUVI HD Cameras
KC HiLites
PRP Seats
FOA Shocks
RACELINE Wheels
Master Pull
Tom Woods Custom Driveshafts
WorldRallyTeam is offline   Reply With Quote
Old 04-29-2011, 08:53 AM   #2 (permalink)
MultiTasKing
Member # 165307
Gaz shocks now available in the usa
YouTube - WRC Technical - Dampers
The Minority Racer®
Powered By:
KC HiLites
PRP Seats
FOA Shocks
RACELINE Wheels
Master Pull
Old 06-04-2011, 10:48 AM   #3 (permalink)
Wholesale Prices
cjcp1's Avatar
Member # 40515
Send a message via Skype™ to cjcp1
Feel Free to pm us what application you are looking for with details abour your car. These GAZ kits are custom made.
Casanova-Motorsports
superchips@gmail.com
956-242-4612
310 Houston St Laredo,Tx 78040
email or pm me for the best quotes on VEHO MUVI HD CAMERAS, Rubicon Express, Rough Country, BFGoodrich, ARB lockers, Detroit Lockers, Yukon gears, KMC WHEELS, Superchip Tuners, Diablo Sport, Procharger, Msd Ignition, PRP Seats, Raceline Wheels, FOA Shocks. RACING GEAR FOR RALLY, DRAG RACING, OFFROAD, AUTOCROSS, FACTORY DIRECT PRICES!
cjcp1 is offline   Reply With Quote
Old 07-01-2011, 08:31 AM   #4 (permalink)
Wholesale Prices
cjcp1's Avatar
Member # 40515
Thumbs up Gaz suspensions now available in the usa
Here are some interesting facts that separates GAZ from the competition.
* All units are provided with high quality race spec coils springs in various rates and diameters.
* On car damping adjustment, no need to remove the unit from the car. Ride height is also adjustable without removing the unit from the car
* Shortened body and stroke lengths to allow ride height adjustment.
* Coarse acme form thread for ease of adjustment and to minimise corrosion * Zinc plated.
* High quality coil springs in various rates and diameters. Spring rates can be altered on request to suit customers requirements.
* Easy rotary adjustment providing the facility for fine tuning without the need to remove the shock absorber from the car.
Double lip seal plus a further stem seal on the piston rod. Produces a shock absorber with unrivalled performance characteristics for both the road and track.
* Fully tested and despatched with an individual dynometer report.
* Made to accredited ISO9001 standard and supplied with a 2 year warranty.
* Electro plated body that resists salt spray and road grime on vehicles where detailing really matters.
* Gaz units are provided with an on car multi point adjustment facility that alters bump and rebound settings by a single control knob on the base of the unit.
* They have nickel plated bodies for maximum protection against corrosion.
* Manufactured and built in England.
* Fully rebuildable and servicable.
THE GAZ GHA KITS are designed for daily use, fast road and track days, this kit comes with all fittings and bushes and uses your car's original suspension points meaning fitting is a simple bolt in job.
The main features of these GHA kits are:
* Spring and valving rates are matched to your car and its intended use. GAZ takes into consideration many aspects such as whether your car is a fully stripped caged racer for circuit use, a drift car or for use in gravel rallying, the tyres you use from road, sticky track-day or full slicks. The power output, engine swaps and whether the car is fitted with an LSD are also taken into consideration.
* 16-way adjustable for bump damping. This adjustment comes from a single control knob on the side of the front coilover unit.
* 42-way adjustable for bump and rebound damping. This adjustment comes from a single control knob on the side of the rear damper.
* High quality race spec coils springs in various rates and diameters.
GAZ GOLD GGA KITS are designed for tarmac motorsport and the serious track day enthusiast.
* 20-way adjustable for bump and rebound damping. This adjustment comes from a single control knob on the side of the front coilover unit.
* 40-way adjustable for bump and rebound damping. This adjustment comes from a single control knob on the side of the rear damper.
* 62mm bodies for increased oil capacity to prevent frothing and cavitation so the damping stays consistent throughout a race.
* 22mm diameter piston rods that have been induction hardened and chrome plated, for increased strength and durability.
* Fitted with a gas cell in the outer reservoir to pressurise the damping oil. The oil itself is a high viscosity index racing multigrade oil to prevent frothing, cavitation and fade in motor racing conditions.
* Lightweight billet alloy components are used (where possible) such as bases, end fittings, seats, lock rings, rod guides and gland nuts. The outer tube is steel with a nickel coating to provide the best anti corrosive finish possible. All outer alloy components are anodised. This reduces weight and increases life and performance.
956-242-4612
Old 07-27-2011, 04:20 AM   #5 (permalink)
Wholesale Prices
cjcp1's Avatar
Member # 40515
Red face VW Golf Mk4 Estate Gaz GHA Adjustable Coilover Kit
VW Golf Mk4 Estate Gaz GHA Adjustable Coilover Kit ON SALE FOR $1100 USD
CLICK HERE to read more about this kit that can can be altered for various motor sport use ie drag racing, track day or race use at the point of order.
956-242-4612
Old 08-09-2011, 12:11 AM   #6 (permalink)
Wholesale Prices
cjcp1's Avatar
Member # 40515
Thumbs up New Gaz Suspension Product: GAZ ‘Gold’ Suspension for Ford Fiesta XR2
Leading suspension specialists GAZ are now offering a special version of their GAZ Gold coilover suspension kit for the Ford Fiesta XR2.
The front struts now have a flat recess on the side to allow extra wide wheels/tyres to be fitted without fouling the strut. The lower mounting flange features elongated slots and eccentric cam nuts to allow the camber to be adjusted.
The GAZ Gold kit is intended for full race use but can also be specified for fast road and trackday use and GAZ will supply them with appropriate damper rates and springs for the intended purpose. Naturally all the usual GAZ Gold features are included... there is a gas cell in the outer reservoir to help prevent cavitation. The units are then filled with a multi grade high viscosity index fluid to help resist fade under extreme conditions.
GAZ Gold units are bump and rebound adjustable while on the vehicle by means of an easily accessible adjuster knob. Ride height is adjustable through 60mm of adjustment and the units are plated and fitted with anodised adjusters for long life and all units are individually tested before leaving the factory and covered by a 2 year warranty.
956-242-4612
Old 08-09-2011, 12:18 AM   #7 (permalink)
Wholesale Prices
cjcp1's Avatar
Member # 40515
Gaz coilovers recommended all over the world!
‪106 llandow 21/05/11‬‏ - YouTube
956-242-4612
Old 08-10-2011, 08:47 PM   #8 (permalink)
Wholesale Prices
cjcp1's Avatar
Member # 40515
Cadwell 11th AUGUST 2009 172 Clio chasing chipped 258bhp R26r Megane - YouTube
956-242-4612
Old 10-18-2011, 01:34 PM   #9 (permalink)
Wholesale Prices
cjcp1's Avatar
Member # 40515
Gaz shocks - 2004 VW R32 GOLF MK4 KIT
1979heep,
Price quoted for that 2004 GOLF MK4 R32 light rally suspension kit. Thanx for the business.
956-242-4612
