Spot fire on Rubicon - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Land Use and Trails > Rubicon Trail
Old 08-11-2003, 08:20 AM   #1 (permalink)
cruzila's Avatar
Member # 6650
I was coming out late about 8:30PM Yesterday and between Walker and Ellis Creek, about halfway, there was a strong smell of smoke. My passenger being a firefighter, was quick to spot it. Up off the "track" in the duff close to the brush was a spot 6-10 inches around black and smoking. There was no cigarette, not a campfire and no other indication of ignition. Lightening has been over up there for quite some time? We got out the shovel and dug down several inches and it was hot down there! If it had caught, there are alot of trees in that area up the hill
The only other thing I thought it could have been was welding, but it did not look like the ground had that much foot traffic near it.
Scott Johnston
Rubicon Trail Foundation
Founding Director and Past President 2010-2012
WIN a fully built Toyota pickup at Cantina 2013
Davez Off Road and Trail Gear are supporting Rubicon Trail Foundation
cruzila is offline   Reply With Quote
Old 08-11-2003, 09:06 AM   #2 (permalink)
BEAR's Avatar
Member # 1746
Thanks for for keepin an eye out.
Whatever started it, im just glad you guys put it out!
Thanks!!
Still Politically Uncorrect
BEAR is offline   Reply With Quote
Old 08-11-2003, 09:25 AM   #3 (permalink)
Rubicrawler's Avatar
Member # 2037
Good job Scott! Glad you stopped and checked it out!
Mark Langford
KI6TMK
'86 CJ7, ProRock60's, 4.88's/Detroits/35 Spline Alloys/CTM's, TBI 350, 700R4, 4:1 D300 w/Twin Stick, 17" x 8.5" Trail Ready HD Aluminum beadlocks, 37x13.5x17 Toyo MT's
Dysfunctional Rockcrawlers (TDO)
Rubicrawler is offline   Reply With Quote
Old 08-11-2003, 10:11 AM   #4 (permalink)
Pirate Chick
Member # 110
we've seen some fires that had to have been started by a piece of glass in the sun
Mrs. Maniac is offline   Reply With Quote
Old 08-11-2003, 10:54 AM   #5 (permalink)
JoshC's Avatar
Member # 5378
Our group cam across something similar a couple years ago and we put it out. Just a smolder pot a couple of inches under the surface. Weird?
DangerRangerRacing.com -- Want to help a "Little guy" race at King of the Hammers?
JoshC is offline   Reply With Quote
Old 08-11-2003, 11:12 AM   #6 (permalink)
cruzila's Avatar
Member # 6650
Wierd, yes. There was no glass and it seemed to be in dirt. It had that peet texture. With all the lightening recently it could have been going for a while?? Anyone heard of this?
Scott Johnston
Old 08-11-2003, 03:53 PM   #7 (permalink)
Land Use Zeus
Jeepndel's Avatar
Member # 3982
Fires with no apparent cause:
Residual fires and smoldering hot spots are very common in the high country where lightning strikes, but does not immediately flame up. It can take days or longer. Some fires in our sierras can actualy burn under the snow, over winter, if there's some O2 getting to them.
So it was probably lightning. Let's hope. Other options include an idiot with a camp fire electric match. But usually, if you have enough fuel to get a fire going, it will take off. Only lightning, with the high intensity, can get a coal bed going, even when the humidity or other factors keep the flames from jumping up.
Hope this helps.
Del
Retired Fire Chief, CDF
Del Albright
BlueRibbon Coalition Ambassador
Co-Founder, Friends of the Rubicon (FOTR)
Building an Access Army to Fight Back -- SOLDIER UP
Follow the Trail Tours TAPT
Jeepndel is offline   Reply With Quote
Old 08-11-2003, 10:28 PM   #8 (permalink)
Blue Devil Toyota's Avatar
Member # 13438
Re: Spot fire on Rubicon
Was it on the right on the way out? Near a hole? Because there was a broken white jeep wrangler from the Jeep Jamboree there on Friday. I went back through there on Sat evening around 8:00 and some people from the Jamboree were fixing it. They said it had a broken axle. Don't know but they might of done some welding or cutting mabey to get it fixed.
Team ateteight #88
Sponsors: Frontier 4x4, Superior Axle & Gear, Rock4X Fabrication, South Bay Drive Line, Lucas Oil, Degnan Printers, Grid 6
Blue Devil Toyota is offline   Reply With Quote
Old 08-12-2003, 09:04 AM   #9 (permalink)
cruzila's Avatar
Member # 6650
Re: Re: Spot fire on Rubicon
Don't know about the hole? but it was on the right. It was closer to Ellis than Walker. Beyond that I would need gps to tell ya exactly. We ran into that YJ at Buck Island. Still had a broken front and the rear end was clanking
Scott Johnston
Old 08-12-2003, 09:21 AM   #10 (permalink)
Member # 13438
Dell,
Do you think it would be worth it to call the people that thru the Jamboree and find out if they had to do any cutting or welding. If they did they may want to know to be more carefull in the future.
Bernie
Team ateteight #88
Old 08-12-2003, 10:21 AM   #11 (permalink)
Land Use Zeus
Jeepndel's Avatar
Member # 3982
I will follow up on the welding possibility with the trail vendors/commercial guys. thanks, good idea.
Del
Del Albright
