Trail Conditions 2017, go to First Post for Current Conditions - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Land Use and Trails > Rubicon Trail
Old 03-08-2017, 08:54 PM   #51 (permalink)
Member # 24195
Originally Posted by Scouty View Post
What are the specs on that rig? Bad Ass for sure.
1998 GM 4.3l Vortec stock except for headers/ air filter ( left stock for reliability). Best guess 190 HP/ 230 torque. York air compressor,4l60e, klune V 2.28, 5.0 Atlas, 14b front steer axle with 40 spline shafts/arb, CTMs, Rear 30 spline 14b/arb. 5.38 gears, Wilwood brakes, hydro boost, full hyd steering, 3 link front, 4 link rear, firestone air spring suspension/ automatic leveling with driver override modes ( AiRock system adapted from a TJ), Double beadlocks with 49" iroks, FOA bypass shocks, 16"+ vertical suspension travel, custom sway bars. Originally a 1989 Std cab Hilux with an extracab welded on later, wheelbase about 120", width 98" Empty weight with snowtires/ tools full fluids 5800-6000 lbs. I have tried to reduce the weight and removed about 200 lbs from the rig in the last 5 years. The big tires/ wheels/ axles weights sure add up fast though.
Crawl ratio 447:1. 14b frt and rear, 40 spline ARBs. F 3 link, R 4 link, 49" IROKs, double bead
toyrocs is offline   Reply With Quote Quick reply to this message
Old 03-08-2017, 09:07 PM   #52 (permalink)
Member # 24195
Originally Posted by timsresort View Post
How far did you get? I take it the Ellis shitter has gone under.
l
Yes I got as far as the Ellis creek Bridge/ Facilities. BIG caverns on trail just 50' east. And to the west I got to within 500' of the upper part of Post Pile. Same thing--- BIG caverns. Running solo I thought it was very wise to not attempt any of those monster holes/obstacles. Now if I was with Cruzila or Jim Job it would have been VERY tempting!!!
Yes the " facilities" at Ellis are under at least 10'-12' of snow. I think there are a couple of pictures already posted. If you look closely you may see the " bump" in the snow.
Old 03-09-2017, 12:24 PM   #53 (permalink)
Member # 41156
were you able to drive out of the bowl or have to winch?
amazing report and pics.
'00 SA Tacoma with a few mods
'00Tacosinger is offline   Reply With Quote Quick reply to this message
Old 03-09-2017, 12:43 PM   #54 (permalink)
Member # 24195
Had to winch out. Used over 200' of rope. 110' on the winch drum +100' extra rope + 30' strap. Yes you will need it in these conditions! No close by anchor points.
Old 03-09-2017, 01:59 PM   #55 (permalink)
MidlifeCrisisUndrWay
CDA 455's Avatar
Member # 95025
Norfolk n Way !!
Excellent point/tip:
1) Need chit load more line for snow outing.
I play in Idaho snow and I thought a total of 90' of various lines was enough.
ΜΟΛΩΝ ΛΑΒΕ
President Trump on building the wall:
"THIS IS WHERE WE HOLD THEM!!! THIS IS WHERE WE FIGHT!!! THIS IS WHERE THEY'RE DEPORTED!!!"
V.P.Pence:
BUILD THIS WALL, BOYS!!!
Fearless Indians:
Awe-Ooo!!!
CDA 455 is offline   Reply With Quote Quick reply to this message
Old 03-09-2017, 02:02 PM   #56 (permalink)
CDA 455's Avatar
Member # 95025
Originally Posted by Curly View Post
If you know where this is you can see the size of this drift. This last batch of snow really got the drifts growing. Quick in and out on the sled today, it was work. That is all
3-7-17
How long is your snow-wheeling season there?
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 03-09-2017, 03:04 PM   #57 (permalink)
Scouty's Avatar
Member # 681
Nice rig, seems to do the job in the deep stuff
"Anything Less is Just A Pile of Chit"
Scouty is offline   Reply With Quote Quick reply to this message
Old 03-09-2017, 03:16 PM   #58 (permalink)
CDA 455's Avatar
Member # 95025
I wonder if a Pullpal would work in the snow?
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 03-09-2017, 03:24 PM   #59 (permalink)
Member # 24195
Yes it does work in the snow. I've had one for about 12 years now. Used it on the Rubicon last weekend.
Old 03-09-2017, 03:37 PM   #60 (permalink)
CDA 455's Avatar
Member # 95025
Awesome!
I was just on their website.
They have a 16,000lb rated one now. Need to put this on my 'need' list.
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 03-09-2017, 07:19 PM   #61 (permalink)
Curly's Avatar
Member # 20205
It varies so much year to year hard to say. This year things really got going in mid November and from what we are seeing we may have our tires in the white stuff till June
KI6PPU
It's very black and white. It becomes Gray when you give quarter....
Curly is offline   Reply With Quote Quick reply to this message
Old 03-09-2017, 07:22 PM   #62 (permalink)
Member # 41156
what is the trick to switching lines? Ie, once you real in that first 100' what do you anchor the rig to while pulling the winch line back out to re-hook up?
I've done a 400' recovery with multiple lines but we had 3 winches to work with so holding the rig while lines were reset wasn't a problem. was on a 60* slope so got interesting
Old 03-09-2017, 08:24 PM   #63 (permalink)
Curly's Avatar
Member # 20205
Hope you can find a way to block it, stop it. It can be a problem.....lol
KI6PPU
Old 03-09-2017, 11:39 PM   #64 (permalink)
Member # 41156
Gravity's a bitch...
Old 03-10-2017, 12:37 AM   #65 (permalink)
Member # 24195
The rig is in soft snow, which holds the rig in place while the line is switched/ attach points changed.
Old 03-10-2017, 11:29 PM   #66 (permalink)
Member # 41156
good thing it twern't ice
Old 03-11-2017, 07:26 AM   #67 (permalink)
CDA 455's Avatar
Member # 95025
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 03-13-2017, 08:17 AM   #68 (permalink)
Curly's Avatar
Member # 20205
Trail has been made to the base of Walker Hill. With that said, there is rig swallowing holes along the way. Travel past Ellis Creek bridge is an adventure. Be prepared to winch, dig, work etc etc.
KI6PPU
Old 03-13-2017, 08:38 AM   #69 (permalink)
Member # 93772
Holy smokes Toyrocs, nice job. I was thinking of trying to see about getting to WWS campgrounds and thought that'd be a task and you're at Ellis.
bsdboy is offline   Reply With Quote Quick reply to this message
Old 03-13-2017, 08:44 AM   #70 (permalink)
CDA 455's Avatar
Member # 95025
What are the holes from?
Just deeper pockets of snow?
ΜΟΛΩΝ ΛΑΒΕ
V.P.Pence:
Fearless Indians:
Awe-Ooo!!!
Old 03-13-2017, 08:45 AM   #71 (permalink)
Member # 93772
I'd imagine running water underneath.
Old 03-13-2017, 09:21 AM   #72 (permalink)
Curly's Avatar
Member # 20205
Mike Elrod and the Scout bringing the action.
#MAKINGSNOWGREATAGAIN
KI6PPU
Old 03-13-2017, 10:59 AM   #73 (permalink)
Member # 86399
A couple of shots from the weekend. It is DEEP... Lot's of work and tons of fun!!
MOTO-ROCK324 is offline   Reply With Quote Quick reply to this message
Old 03-13-2017, 11:12 AM   #74 (permalink)
Member # 86399
First pic: Bottom of Walker Hill looking up.
Second pic: Just awesome!
Third pic: Brody the dog and Jim Job.
Old 03-14-2017, 06:17 PM   #75 (permalink)
Member # 24859
Did Jim really stand Desmond up then go snow wheelin the next weekend ??
Mellonhead
peesalot is offline   Reply With Quote Quick reply to this message
