is it feasible? - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Land Use and Trails > Rubicon Trail
Old 01-04-2017, 10:53 AM   #1 (permalink)
Member # 583409
is it feasible?
is it feasible to take an extended cab long bed rig up the Rubicon?
I will be doing suspension mods and bigger tires accordingly
turbo'd is offline   Reply With Quote Quick reply to this message
Old 01-04-2017, 02:47 PM   #2 (permalink)
Member # 36895
Huge suspension lift and tires.
I'd still expect body damage.
MSlaug is offline   Reply With Quote Quick reply to this message
Old 01-04-2017, 02:56 PM   #3 (permalink)
Member # 583409
how big of a suspension lift and tire size are we talking about?
Old 01-04-2017, 04:56 PM   #4 (permalink)
Curly's Avatar
Member # 20205
KI6PPU
It's very black and white. It becomes Gray when you give quarter....
Curly is offline   Reply With Quote Quick reply to this message
Old 01-04-2017, 06:59 PM   #5 (permalink)
Member # 21815
Dave did a great job driving that thing, and still did damage to the rockers on both sides...
He did make it through though!
WWDD?
N6YBH
Thanks to
for sponsoring the 2016 Cantina For The Con!
"If you need a tool and don't buy it, you will ultimately find that you have paid for it but don't have it". -Henry Ford
resqme is offline   Reply With Quote Quick reply to this message
Old 01-04-2017, 07:04 PM   #6 (permalink)
Wheelin 24/7
Beat95YJ's Avatar
Member # 22176
Originally Posted by resqme View Post
Rob did a great job driving that thing, and still did damage to the rockers on both sides...
FIFY
I swear sometimes this place should be called "Autism on bath salts".
:tank:
Old 01-04-2017, 11:06 PM   #7 (permalink)
clb 017's Avatar
Member # 166307
Yer gunna need 31's
If its made in china IT WILL FAIL!
clb 017 is offline   Reply With Quote Quick reply to this message
Old 01-04-2017, 11:57 PM   #8 (permalink)
Member # 583409
thats impressive he took a quad cab up there, mine will be an extended cab
Old 01-12-2017, 11:54 AM   #9 (permalink)
Member # 160801
Saw the truck posted in this thread on the trail with lots of body damage.
Saw a full-size Dodge extended cab make it to the springs years ago, and it experienced massive amounts of body damage. That guy really destroyed that truck.
Also saw an old-school crew F250 on 40s go to Buck island and experience very little damage, but he never braved the ledges and big sluice to go any further than that (essentially did half the trail).
The trail has been made significantly easier over the last few years though, so its a maybe.
desert dogg is offline   Reply With Quote Quick reply to this message
Old 01-12-2017, 01:44 PM   #10 (permalink)
Member # 583409
Thats what scares me is I wont make it out without some significant body damage
Old 01-12-2017, 03:57 PM   #11 (permalink)
Member # 36895
You won't make it out without significant body damage.
Old 01-12-2017, 05:33 PM   #12 (permalink)
Member # 583409
how would a regular cab long bed fair through it?>
Old 01-12-2017, 09:59 PM   #13 (permalink)
Member # 24195
I would put on STRONG Nerf bars and rear quarter protection. That is where most of the body damage will be. IE Surf the Nerfs! Most long rigs pivot around rocks on the Nurfs or slam down hard on the rear/ rear corners coming off ledges. Don't worry too much about going with a tall lift. Keep the vehicle with a moderate lift and just plan to use your steel for protection. Just my opinion. Cheers!
Crawl ratio 447:1. 14b frt and rear, 40 spline ARBs. F 3 link, R 4 link, 49" IROKs, double bead
toyrocs is offline   Reply With Quote Quick reply to this message
Old 01-12-2017, 10:11 PM   #14 (permalink)
Wheelin 24/7
Beat95YJ's Avatar
Member # 22176
FYI, the synergy megacab did not have nerfbars and that's where the majority of damage was.
:tank:
Old 01-29-2017, 07:14 PM   #15 (permalink)
Member # 235117
Yes you can do it. Build yourself (or buy) good rock sliders, good bumpers, and a good skid plate. I don't have an 8' long bed but I have the full 6 foot bed.
Camolicious is offline   Reply With Quote Quick reply to this message
Old 01-30-2017, 05:59 AM   #16 (permalink)
Hey Y'all Watch This
Country69's Avatar
Member # 204026
Got a buddy wheeling a full size extended cab longbed. Does the Con, Fordyce etc.
Seems to do just fine. No major carnage.
Country69 is offline   Reply With Quote Quick reply to this message
Old 01-31-2017, 12:02 PM   #17 (permalink)
Member # 113272
Send a message via AIM to Garlic Bronco
sure its doable, you just have to be aware of what you're doing and prepare correctly.
this is my buddys rig, hes been across the con multiple times and the dusy as well as others.
and he had crossed them before he swapped to the cargo bed deal, when he just had a shortish 5-6 foot bed
he personally isnt worried about the doors/body damage but for the first few passes is was fairly clean
Garlic Bronco is offline   Reply With Quote Quick reply to this message
