The water agency assessment fact or assumption. - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Land Use and Trails > Rubicon Trail
Old 09-15-2009, 12:41 AM   #1 (permalink)
Member # 24377
Send a message via Yahoo to Dickdog
Here is a link I found http://www.sierraconservation.org/ru...il_cao_att.pdf
I hope its not a R..
Can any one help me out here and to make sure that I am understanding this correctly .They used the words assume and assumption in there equation. if I read this right, some of there numbers are not base on real percentage ?
89 toyota 4runner,Exo, marlin crawler, 5.29, lockright in rear, ARB in front, toy rear main leafs in front, 3" body lift, and 36" tires
Buildup thread
[CENTER][SIZE="3"][COLOR="Lime"]I wheel toyotas and fix jeeps for a living!
[SIZE="6"]JV #589[/SIZE][/COLOR][/SIZE][/CENTER]
[SIZE="3"]I read more than I post!!! [/SIZE][CENTER][/CENTER]
Dickdog is offline   Reply With Quote Quick reply to this message
Old 09-15-2009, 01:25 AM   #2 (permalink)
Member # 126704
readily remebered, rambling reject, resoundingly recalled, rendered refuse, revised, resubmitted, refuted
Responses:
http://www.swrcb.ca.gov/rwqcb5/board...erkurt_com.pdf
http://www.swrcb.ca.gov/rwqcb5/board...ifford_com.pdf
http://www.swrcb.ca.gov/rwqcb5/board..._arenz_com.pdf
http://www.swrcb.ca.gov/rwqcb5/board...1mar09_com.pdf
Rebuttal:
http://www.swrcb.ca.gov/rwqcb5/board...frpt_att_b.pdf
Regurgitated:
http://www.calsport.org/RubiconTrail...il_cao_att.pdf
recycle!
[CENTER]"Certainty of death, *small* chance of success... What are we waiting for?" - Gimli[/CENTER]
chasinternet is offline   Reply With Quote Quick reply to this message
Old 09-15-2009, 08:04 AM   #3 (permalink)
flamethrower
Bebe's Avatar
Member # 75270
Send a message via Yahoo to Bebe
Why am I not surprised that pile of TP is still on Karen Schambachs website
It was pulled from the Water Boards Website, because it was sooo bad, no one would put their geologists stamp on it.
There was even a complaint filed to the Geology Board.
What's all the Hub-bub about Blue Stars???
Haulin the Groceries AND Haulin the MAIL
Bebe is offline   Reply With Quote Quick reply to this message
Old 09-15-2009, 09:02 AM   #4 (permalink)
Member # 347
Much of this document was problematic enough that Rubicon Trail Foundation (RTF) paid for external analysis and worked amongst ourselves and with other volunteers to identify the flaws in the research. We worked with Water Law counsel to change the document (we fought hard to get unfounded comments removed with respect to most of the trail and Little Sluice in particular <what remains is mostly about Ellis Creek> and the agenda-based language and assumptions toned down), and in the end, the document itself was withdrawn thanks to the persistence of a few licensed geologists.
There are certainly problems with this report ... bad enough that the Regional Water Quality Board (RWQB) pulled it back. The problem is, of course, that the Cleanup and Abatement Order (CAO) process was initiated with this document, and even though the 'study' document has been withdrawn, the CAO wheels have been set in motion, and can't be stopped; they will run their course. We can and should work with the RWQB to ensure as good a result as possible, but we're unable to put the CAO genie back in the bottle
The good thing about the CAO is the unprecedented cooperative of response from RTF, FOTR, clubs, and independents -- we pulled together and responded with such organization and factual basis, that the game changed. Thousands of users submitted affidavits, and many showed up at the RWQB Hearing to support OHV. RTF's fax machines were smoking hot with affidavit responses from FOTR, Cal4, NORA, PBB, and other folks who wanted their voice to be heard.
The trick is to keep rolling that momentum forward...
Randii
randii is offline   Reply With Quote Quick reply to this message
Old 09-15-2009, 10:16 AM   #5 (permalink)
Member # 24377
Randii
WOW !!
Thank you for the more insight on the subject. Iím glad that Iím not the only person that saw it that way .
End of subjectÖ
Buildup thread
