Tahoe Ham Frequency change
Hey hams, the output frequency on the Tahoe repeater that is linked to the 805 has changed...
It is an “odd split”, meaning that the new repeater doesn’t follow the standard band plan with a 600 kc split. So the new frequency is: 145.350 (repeater transmitter), odd split to 146.205 (repeater receiver), PL123.0 I know this is confusing to some, but it is what it is! Hopefully you can all get it figured out. |
Aw, man. I gotta dig out the manual for this FT60.
I know it's "FW", then "set", but I can't remember which option lets you change/edit the frequency of an already stored entry. If I get it right, I'll post step by step for everyone else. |
1 Attachment(s)
Tune to 805TAH “memory #2 on my radio v/m to get out of memory mode enter in 145.350 push and hold F/W for 1 sec rotate dial knob to memory #2 “do it quick” hold PTT and press F/W until it says memory in V/M to go back to memory mode and your done Then I did this with a file a Birdie sent me just to be sure:D |
John, which frequency is it?
you posted 145.530, also sent me an email with the same number. the following posts here are 145.350 ? the first one would be a 675 shift, the second a 855 ? thanks I can enter both tx and rx in the memory, just want to be sure which it is. for those that need help on the programing, or don't have their manual. 28 FT-60R OPERATING MANUAL MEMORY STORAGE 1. Select the desired frequency, while operating in the VFO mode. Be sure to set up any desired CTCSS or DCS tones, as well as any desired repeater offset. The power level may also be set at this time, if you wish to store it. 2. Press and hold in the [F/W] key for one second. 3. Within five seconds of releasing the [F/W] key, you need to make a decision regarding channel storage. The microprocessor will automatically select the next-available “free” channel (a memory register on which no data has been stored), so you may not wish to make any change; if this is the case, proceed to step 4. If you wish to select a different channel number into which to store the data, rotate the DIAL knob to select the desired memory channel. You may jump 100 memory channels, if you’re in a hurry (101 1 201 301 …) by pressing the [BAND(BAND DN)] key (multiple times, if necessary). 4. Press the [F/W] key once more to store the frequency into memory. 5. You still will be operating in the “VFO” mode, so you may now enter other frequencies, and store them into additional memory locations, by repeating the above process. Storing Independent Transmit Frequencies (“Odd Splits”) All memories can store an independent transmit frequency, for operation on repeaters with non-standard shift. To do this: 1. Store the receive frequency using the method already described under MEMORY STORAGE (it doesn’t matter if a repeater offset is active). 2. Tune to the desired transmit frequency, then press and hold in the [F/W] key for one second. 3. Within five seconds of releasing the [F/W] key, rotate the DIAL knob to select the same memory channel number as used in step “1” above. 4. Press and hold in the PTT switch, then press the [F/W] key once more momentarily while holding the PTT switch in (this does not key the transmitter). Whenever you recall a memory which contains independently -stored transmit and receive frequencies, both the the “+ “ and “ - “ indications will appear in the display. |
Thanks for the update, sux if have to search for it when your on the trail.
The correct freq is 145.350, sorry about that! |
What was the reason for the switch? Was it interfering with another station? Just curious.
Thanks for the info though. I'll have to go change it tomorrow. |
So I'm going to redo those steps above, but using 146.205 instead(since those steps set the TX). Then, redo the same steps with 145.350, but at the end AVOID pushing PTT, but only FW(to set the RX). Finally, push FW, then 0(set), dial over to TN FREQ, and set it to 123. I *think* I'm done. :) |
Can't seem to hit it and I could the old pair. Just to clarify, the repeater INPUT is 146.205? I'm used to reading repeater "input" and "output" ... sorry, old school I guess. Hope all that head up have a ball this weekend ... My Son will be there and was hoping to monitor. 73, WU6X
The repeater's frequencies: Receive: 146.205 Transmit: 145.350 Decode PL-123.0 Your mobile/portable frequencies: Receive 145.350 Transmit:: 146.205 Encode PL - 123.0 Hope this helps! |
Cannot get my Yaesu FT-2800m to accept this. I've spent an hour with the manual (odd splits) with no luck. This is not the first time the manual has been wrong, so if anyone with an FT-2800 has figured this out please let me know how you did it.
TIA |
EXCEPT before the last press of the D/MR(MW) button, press and hold the PTT while you press the D/MR(MW) button My troubles usually stem from not pressing the button momentarily, one second, or holding as directed. (My Icom HT seems to be working also, completely different process of course. Different brands => glutton for punishment. ):shaking: Hope that helps, Good luck |
Hey Jim,
I did hold the ptt down while pressing on the D/MR button. Nothing happens. I made sure the mic wasn't locked and tried it several times. A google search found a couple other guys with the same problem on ft-2800s. So I ordered the cable and am going to get the software to program both my 2800s which is what I should have done a couple years ago. :shaking: You going to Rubithon? Quote:
Just put in the frequencies in my FT-7800. Thanks for the heads up!
Here's the part form the manual of the 7800: Quote:
W6FTW |
thanks BK Cruiser!! Couldn't have done that with just the FT60 manual!
805 seemed to work just fine for me this last weekend (8/12,13).
All the old settings. Went in with Harold for a day from Wentworth to Loon. First trip in, what a gas! I think I'm hooked! So much to unlearn. J.B. AD6WX and Dillon KI6BNP |
Yeah, last time I was up, I tried hitting the repeater with the old freq's. It didn't work. The new Freq's worked just fine :)
Thanks for the clarification <sp?>
J.B. AD6WX |
thank god for my FT-60 programmer and cable, I don't think I would have gotten there without it!
Randii |
| All times are GMT -7. The time now is 04:03 PM. |
