Member # 42539
Bend Pak lift....symmetric or asymetric
I narrowed my lift choice to a Bend Pak. It's either going to be a XPR-10ACX or XPR-10CX.
My race car is a Buick Grand National. Either lift would have no trouble lifting it. I'm not too concerned about opening the doors once it's up due to it having a roll cage in it. The issue arises lifting a crew cab, 8' bed Ford F350 diesel, single rear wheel truck. I know the heavier trucks benefit from a symmetrical lift. Also, I would like to put a vehicle on the lift backwards at times. The symmetrical lift wouldn't know the difference. It is not recommended to put a vehicle backwards on a asymmetrical lift but it can be done. The Buick weighs 3200lbs so I doubt the 10K asymmetric would "care". The XPR-10ACX lift is capable of lifting either way, symmetric or asymmetric. Does anyone have any experience with the XPR-10ACX lifting vehicles either way? Both would be set up in the wide option. The lift is for personal use. Thanks Billy T. gnxtc2@aol.com Last edited by gnxtc2; 11-24-2011 at 05:29 PM. |
Newbie
Member # 55462
I have a Bend Pac 10000 lb asymmetric lift in my personal shop. It has no problems lifting my 2003 F250, super cab, 8ft bed, diesel, 4x4 tow rig as long as I pull a little more forward to help balance the load. I would not try to lift the truck backwards for sure with it so If that would be an issue I'd get the symmetric one. I have lifted my 67 Fairlane facing backwards once and had no issues. The only real benefit in my opinion to the asym. lift is that you can open the doors wider to get into and out of the vehicle easier.
I try to pull my f250 through till the mirror on the door is just past the lift post. The main thing to keep in mind it the vehicles center of gravity needs to be between the lift arms where they touch the frame to be stable. I will use one of those "dead man" screw type jackstands under the hitch of the truck to help stabilize it if I'm doing heavy work such as changing the clutch. The shop I work at has nothing but asymmetric lifts also.
2003 F250: 6.0 PSD, 6spd, 35" tires, Tow rig/DD 1978 F150 Truggy: 351M with GM TBI, 4spd, ARB'd 60, 4 linked 14bolt rear, 42 TSLs 1967 Fairlane GT: worked over 390FE, factory 4 speed, cage, etc. |
skullfuckery
Member # 29016
i just got a bend pak 10k non symetrical. dont know the exact modle.
but it has zero problems lifting a 07 dodge 4wd crew long bed, barely ever changed the tone of the pump motor, didnt sag the arms at all. it all matters how much room you leave on either side of the lift. if you leave enough ahaed to back the truck in until you get the long arms as short as possible then i dont think it will be a problem. fwiw you could also put the short arms on the back side. flip the long arms from side to side and install them on the front of the rack. you can switch all for arms in about 5min by your self. the cariage and up rights are the same for the 2 lifts. the arms, cables and top plate are all whats different. center the weight and it wont care which way its pointed.
Impeach or revolt, which will it be? buy my quad http://www.pirate4x4.com/forum/vehic...00-2500-a.html I WILL TRADE FOR A ROAD WORTHY 55-57 or 71-87 CHEVY 2WD PICK UP |
Member # 6398
With the Xtra wide drive thru clearance opening the doors is less of an issue, so get the symmetric IMO.
I've got the XPR-10XC and have no complaints, altho I bought it for lifting trucks. The smallest thing I've ever had on it is either a GMC Canyon or a Dodge Caravan. I've had the same experience as trkklr77 - even crew cab diesels dont' change the tone of the pump motor, or the lifting speed from what I can see. edit: note that while it may be symmetric, the front and rear arms are different. Front arms are 3 stage, rear arms are 2 stage, but as stated above they should be able to be swapped as BP doesn't know what's "front" or "rear" in your shop and the columns are square to one another.
"Take 300 people and on average 290 of them just generally suck at life" Last edited by D60; 11-26-2011 at 05:56 PM. |
MASTER TECH
Member # 54844
i have both at work. for cars and non heavy shit the asymetric is nice, although i do lift big shit with that one ( crew cab 4xs ) i prefer to use the "normal " one for full size stuff. its easyer to load big stuff on
BSW Racing, Calrocs Super mods 12 & ? Driver: Aaron Whitehead - Driver: Joe Hutchins Spotter: Adam Kovarik - Spotter: Dustin Knight Crew Cheif: me fuckers ![]() build up of the truggy /forum/ford/544813-update-pics.html |
Member # 124086
for a crew cab long box truck i'd definitely get the symetrical, if you had a short box i'd say get the a symetrical but the long box's make me nervous, generally i would rather have the big symetrical for any of the crew cab pickups but beings there are only 2 in the shop sometimes we make due. so in short get the symetrical and about lifting cars backwards, i doesn't matter with either so long as you hit the right lift points you'll be ok. most smaller cars don't even need to be strait on the hoist to lift. so long as the arms reach without over extending
