What media are you using in your blaster? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-18-2011, 11:11 AM   #1 (permalink)
86 slo-vo's Avatar
Member # 148322
Picking up a new blast cabinet this week, just wondering what everybody else uses.
Will be most used for some rust clean up and paint/powder coat removal.
Thanks for the suggestions.
94 ranger, d35 8.8, 4.10's detroit locker/truetrac, duff long arm, chevy 63's 36 sx's
86 slo-vo is offline   Reply With Quote
Old 12-18-2011, 12:22 PM   #2 (permalink)
Member # 35780
Go to Shreckers and tell them you want Black beauty sand. very aggresive and last a long time. Comes in 80 lbs bags.
A2ZUK is offline   Reply With Quote
Old 12-18-2011, 01:44 PM   #3 (permalink)
Member # 130300
x2
Mikes79bronco is offline   Reply With Quote
Old 12-18-2011, 02:13 PM   #4 (permalink)
RLC Welding
Member # 105383
Black Beauty is a trade name for coal slag.
Make sure it's not too coarse or it won't go through most cabinet sized nozzles.
The equipment rental places usually carry it.
RLC Welding and Fabrication
Louisville, KY
(502)403-6832
Winch bumpers for 73-98 Full size Chevy, 87-91 F-series, Ford Explorer and Rangers, Jeep xj and zj, Nissan xterra, and MORE!
CNC Plasma cutting!
jamscal is offline   Reply With Quote
Old 12-18-2011, 03:40 PM   #5 (permalink)
86 slo-vo's Avatar
Member # 148322
Here's the cabinet I picked up,$100 and never been used so I figured it was a decent deal.
http://www.harborfreight.com/40-lb-c...net-93608.html
Old 12-18-2011, 03:41 PM   #6 (permalink)
Indefatigable
Elvis-n-Texas's Avatar
Member # 35904
I currently use glass bead. It's a bit slow; but does not harm the surface.
Is coal slag to aggressive for aluminum?
What size (gauge) should I ask for when purchasing?
I may try some and change out the media between jobs. (My cabinet is a gravity media feed design)
86 4Runner, 22RE Fully Restored, Garage Queen
93 PU, 22RE
IFS; IRS Buggy Project: Unfinished, Untested and un-paid for!
Elvis-n-Texas is offline   Reply With Quote
Old 12-18-2011, 04:39 PM   #7 (permalink)
kf4zht's Avatar
Member # 80248
I use a mix of glass bead, alluminum oxide and black beauty, depends on what I am doing. For heavy paint/rust removal on steel/cast BB rocks. For all around use without too much surface damage AO is good. For cleaning AL without risk of damage Glass beads are good.
I keep 5 gal buckets of each under mine so I can swap out as needed.
Where there is a way, there's a will.
[size=4] [font=arial black] [url=http://www.tricktools.com][color=Yellow] Check out Trick-Tools.com for all of your metal fabrication needs! [/url][/color][/font] [/size]
kf4zht is offline   Reply With Quote
Old 12-18-2011, 04:44 PM   #8 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
aluminum oxide. Coal slag is some naaaaasty shit to inhale unless your unit is sealed well
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
You cant ban knowledge, learn to make your own guns right Here.
New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight.
usmcdoc14 is offline   Reply With Quote
Old 12-18-2011, 04:46 PM   #9 (permalink)
86 slo-vo's Avatar
Member # 148322
Where can the aluminum oxide be bought from?
Old 12-18-2011, 04:57 PM   #10 (permalink)
usmcdoc14's Avatar
Member # 13344
Harbor freight, northern tool.
Old 12-19-2011, 07:59 AM   #11 (permalink)
370
Member # 153116
i use coal slag. you can get it at menards or home depo for like $8 (50lb bag) i even shoot aluminum with the coal slag. i wouldn't shoot aluminum i wanted to polish or machined surfaces with coal slag but if your going to paint it then it leaves a good surface for paint to stick to. my old cabinet held like 8 50lb bags in it.. so swapping media wasn't easy.. coal slag is cheap and effective
370 is offline   Reply With Quote
Old 12-19-2011, 03:09 PM   #12 (permalink)
86 slo-vo's Avatar
Member # 148322
I picked up some of the black beauty today, guess I'll try it out.
Old 12-19-2011, 03:59 PM   #13 (permalink)
Member # 22501
I picked some up from Harbor Fright and it is some aggressive stuff very good maybe too much for most alum. jobs but I like it for most of my work is clean up for weld or paint.
1968 Baha Bug with 2.2 ecotec motor 170 hp, king coil-overs,etc
1998.5 Dodge 2500 4x4 Cummins
Ed ke6bnl is offline   Reply With Quote
Old 12-19-2011, 04:09 PM   #14 (permalink)
Sroufe7's Avatar
Member # 121758
Send a message via AIM to Sroufe7
I use aluminum oxide in my blasting cabinet. If you use too aggressive of material in a cabinet you'll eat the insides up. In my pressure pot blaster I use a lot more aggressive material.
Sroufe7 is offline   Reply With Quote
