Welder upgrade time - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-28-2011, 10:31 AM   #1 (permalink)
Member # 107431
Welder upgrade time
I know there are a million threads like this, but I feel like the recommendations depend on what the n00b actually wants to do with a welder. I currently have a $100 welder from Harbor Freight that I bought to decide if I enjoy welding. Turns out I do, and this welder is a joke. I've built a couple of bumpers and stuff for around the house, but it can't even fully penetrate 1/8" steel.
I've pretty much decided on the Miller Autoset 180, but the option is out there to get a Hobart 210 or a bigger chinese welder for the same price. I want to make bumpers, sliders, tube flares, suspension brackets, links, etc. I'm having a hard time picturing what I'd need to weld that's thicker than 3/16" other than d-ring mounts.
And yes, I've checked craigslist (for months) but the Austin hippies/hipsters don't seem to put a lot of good used welders up for sale.
smearig is offline   Reply With Quote Quick reply to this message
Old 12-28-2011, 10:39 AM   #2 (permalink)
dsnelson91's Avatar
Member # 189403
Stick with the big three, miller Lincoln or hobart. Esab is good too. The Chinese welders are good for getting into welding, but if you want a tool not a toy then get something that will last. Hobart is the little brother of miller and are a little cheaper. Made in USA still.
dsnelson91 is offline   Reply With Quote Quick reply to this message
Old 12-28-2011, 12:18 PM   #3 (permalink)
Member # 107431
Yeah, I'm fairly set on a big name US-made welder. But the 210 multi-voltage Hobart for the price of the 180 Miller is kind of tempting.
Old 12-28-2011, 05:18 PM   #4 (permalink)
dsnelson91's Avatar
Member # 189403
id go with the bigger hobart. If you can get more welder for the money, why not? You won't be disapointed with more amperage available.
Old 12-28-2011, 07:09 PM   #5 (permalink)
Banned
Member # 207261
bigger hobart is not a bad choice.
casecase is offline   Reply With Quote Quick reply to this message
Old 12-29-2011, 08:13 AM   #6 (permalink)
Member # 107431
Is there a scenario on a mild TJ build that could take advantage of the additional capabilities of a 210 vs a 180? I'm not going to be shaving a rockwell or trussing a 14ff or anything like that.
Old 12-29-2011, 08:30 AM   #7 (permalink)
TorqueRanger's Avatar
Member # 207169
It's better to have and not need than to buy because of a need later..
Plus better duty cycles on the 210
TorqueRanger is offline   Reply With Quote Quick reply to this message
Old 12-29-2011, 08:40 AM   #8 (permalink)
Goat Jeep's Avatar
Member # 136128
duty cycle is the biggest thing to look at. While you will not be welding 3/8" plate every day, you will be able to weld 1/8" for a longer time on the Hobart 210 vs the miller 180.
I have the Hobart 210 and have built an entire frame and I am in the process of completing the body work. great little machine. I would also say look at getting the spool gun with this welder as a combo. They are a little more now but a lot cheap them buying separate.
Also don't be fooled by the auto set function. If you can weld you can set a machine up.
Goat Jeep is offline   Reply With Quote Quick reply to this message
Old 12-29-2011, 08:49 AM   #9 (permalink)
Member # 107431
Yeah, I don't really want the Miller for the Autoset as much as the sort of legendary performance and quality. Around here a Miller 180 would sell used on Craigslist at or above the Cyberweld's $850 shipped price.
The Hobart 210 is rated 30% @ 150 amps (3/8" max) and the Miller 180 is rated 30% @ 135 amps (5/16" max). I'm not really sure that's an appreciable difference.
Old 12-29-2011, 11:10 AM   #10 (permalink)
Soulless ginger
landscraper's Avatar
Member # 124369
I bought a Miller 211 last year and love it. The dual voltage is great for when you have to take it somewhere without 220. And if I ever need to upsize, I figure the blue paint will help sell it quickly and at a good price.
I shopped it online, and took the best price to the local dealer. They came within $50 of the online price, so I bought it there.
landscraper is offline   Reply With Quote Quick reply to this message
Old 12-29-2011, 11:30 AM   #11 (permalink)
Member # 50751
Do you have any desires to want to TIG weld something at some point? If so take a look at the Thermal Arc 181i which is around $800 shipped online. TA just came out with the Thermal Arc 252i as well but it's closer to $2,000. These are nice inverter based machines. I have a 181i and it works really nice and I also have a Miller Passport, Miller 350P and a Dynasty 300DX Tigrunner so I've used a variety of machines. I was never impressed with Miller/Hobart's lower end machines. Inverter is where it's at.
unixadm is offline   Reply With Quote Quick reply to this message
Old 12-29-2011, 12:34 PM   #12 (permalink)
Member # 107431
I'm definitely interested in it, but that welder is apparently a Thermal Arc branded version of the Everlast MTS 160 without a TIG torch included for $100 more.
But I'm certainly tempted at the idea of picking up something that useful for less than a Miller 180 mig welder by itself. Did you buy it from a local place or order it? Have you done both MIG and TIG with it?
Old 12-29-2011, 12:40 PM   #13 (permalink)
Member # 50751
It does appear similar to the Everlast however the Fabricator 181i has an all metal wire feed assembly. I have only used it for MIG welding as I did not buy the TIG torch but for a few hundred more you can have the capability of doing both which can come in handy though I wouldn't want to TIG with it all the time due to the lack of a gas valve and lift start. It's also a very compact machine with a nice MIG gun. Just food for thought.
Old 12-29-2011, 01:08 PM   #14 (permalink)
fj40guy's Avatar
Member # 9576
You can buy TIG torches with a gas valve on them. My gas solenoid needs to be replaced, but with the valve on the torch, not to big of an issue.
Tom
Beautiful young people are accidents of nature, But beautiful old people are works of art. Learn from the mistakes of others. You can't live long enough to make them all yourself.
fj40guy is offline   Reply With Quote Quick reply to this message
Old 12-29-2011, 06:58 PM   #15 (permalink)
Antisocial
JMAN3203's Avatar
Member # 139337
If country of origin is an issue at all, I'm pretty sure the above equipment is Chinese...
Originally Posted by 45acp
I found out about him being an orphan Chinese immigrant. Dude worked the first half of his life in a dim overcrowded toy factory, scrubbing lead dust off of dolls. I can just see him over in the corner with his little asbestos brush and a bottle of formaldehyde cleaner...[...]
JMAN3203 is offline   Reply With Quote Quick reply to this message
Old 12-29-2011, 07:01 PM   #16 (permalink)
Member # 50751
You are correct. But then again I've had more made in USA equipment fail than made in China so go figure. It's not HF quality by any means - it's a nice machine. Look at the other welders I own - I'm not a cheap ass in regards of buying equipment.
The 252i is built in NH and not China. I was talking to Thermal Arc today about that machine because I may be purchasing two of them.
Old 12-29-2011, 09:38 PM   #17 (permalink)
Antisocial
JMAN3203's Avatar
Member # 139337
Yeah, but I just can't stand seeing those words. Hecho en Mexico, and Made in China, etc. What kind of equipment you have fail?
