JD2 model 3 degree wheel ?'s - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-09-2012, 06:56 PM   #1 (permalink)
Grayguy's Avatar
Member # 38695
Send a message via AIM to Grayguy
So so this may be silly, but how do I properly use the degree wheel in my new to me model 3? I tried setting it so once there is tension on it the flat edge of my die is at 0 degrees, but then when I get to 90, the tube it's self is no where near a 90. I've seen pics of other Peoples dies having a spot for a little metal needle thing, but mine doesn't have that.
Basically, what I'm looking for is the best way for my to get the degree wheel to be accurate? I knee there was gonna be a steep learning curve to bending, but this part seems to be confusing me when k don't think it should be haha
Grayguy is offline   Reply With Quote
Old 02-10-2012, 03:58 AM   #2 (permalink)
TMI
TMI's Avatar
Member # 122938
Your die should have come with a copper pointer.
Robert Gaskins
Team Moto Inc. / ProBender.com / ProCutCNC.com
Tel: 763.315.5019 ext. 112
Brooklyn Park, MN 55443
TMI is offline   Reply With Quote
Old 02-10-2012, 04:44 AM   #3 (permalink)
Amateur Hardcore
sne97hd's Avatar
Member # 76694
This^. Should have a small bolt to attach a piece of tig rod or clothes hanger to make a pointer. If it's not there, just drill and tap one. Rotate the indicator to zero once the tube is strapped in and ready to go.
The Great Southern Trendkill <--- Build Thread
YJ7 Makeover <--- Another Build Thread
sne97hd is offline   Reply With Quote
Old 02-10-2012, 05:09 AM   #4 (permalink)
fabcam's Avatar
Member # 19763
The degree ring should be called a reference ring. Because of spring back and some other factors to try to make the degree come out exactly on the degree ring is not practical in most cases. Use the degree ring to know how far you need to go to get to a given bend angle. Example: I know I need to pull to 97 degrees to get a 90 degree bend with the 1.75 x .120 wall DOM I am using.
In addition, if you don't have one, you will want to get an angle finder like those at www.tricktools.com
The site for the fabricator: [URL="http://www.offroadfabnet.com/index.php"]www.offroadfabnet.com[/URL]
[COLOR="Orange"]Bend-Tech [URL="http://www.2020softwaresolutions.com/bt_pro.htm"]PRO[/URL] is now available!!![/COLOR]
Design full tube [URL="http://www.2020softwaresolutions.com/web_images/Racer-X_5[1].jpg"][U]chassis[/U] [/URL]in less than a couple of hours with the PRO
[COLOR=Cyan]We are the developers of the Bend-Tech products.
[COLOR="Yellow"]651-257-8715[/COLOR] for sales and support[/COLOR]
[URL=http://www.2020ssi.com]www.bend-tech.com[/URL]
[COLOR="Cyan"]10,000+[/COLOR] now using Bend-Tech
fabcam is offline   Reply With Quote
Old 02-10-2012, 07:11 AM   #5 (permalink)
Grayguy's Avatar
Member # 38695
Ok, so I'm not crazy haha. I had it setup so 94 on the wheel meant 90 on the tube, but then the wheel moved...so I'll get a pointer on my die, and play with it more and see where my new 90 is.
Am I better off having the wheel move and just resetting it to zero everytime?
I thought my die was missing something when I got it...
Old 02-10-2012, 07:38 AM   #6 (permalink)
Member # 21858
I do not have a degree wheel in my bender , what i use its something calle carpenters false square (2 pieces of flat stock making a hinge bolted trough so i could put against the outer side of the tube and tigth the nut on the bolt, and then measure angle or try it where it supposed to be fitted , a lot easier than use my angle finder or other tool to guesstimate the angle needed
cj5 76
SOA,OBA,OBW,LPG
14b & 60RC W/detroits
High steering and ram assisted
ford t18 and 205 , rear Fox air shocks
new toy Cj7 82 on 33's setuped to mall crawling :D
MCgiver4x4 is offline   Reply With Quote
