cheap,simple,fast and easy. All words that dont go with the word shop build. - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-02-2012, 05:39 PM   #51 (permalink)
twoslo4five0's Avatar
Member # 87916
lighting done, got the boat in (what a bitch that was) after that i was shot. Looking at my shed i have some serious rearranging and cleaning to do.
77 Banana-build thread here
88 giant midget-build thread here
80 Chevy luv AKA The mega crawler- 5 tons, warmed up 408 SBC, Th350 203/205 and rear steering.
twoslo4five0 is offline   Reply With Quote Quick reply to this message
Old 04-03-2012, 12:51 PM   #52 (permalink)
Member # 87916
any recomendations for a good "temporary floor" under the trucks to keep me out the gravel? im thinking i/o carpet but not sure how it would do with oil leaks and such.
Old 04-03-2012, 02:44 PM   #53 (permalink)
Member # 204868
Pavers?
sauce is offline   Reply With Quote Quick reply to this message
Old 04-03-2012, 03:41 PM   #54 (permalink)
Member # 12429
Craiglist.
Pavers or Bricks can be had cheap if you get them in time
Todd W is offline   Reply With Quote Quick reply to this message
Old 04-03-2012, 06:14 PM   #55 (permalink)
Member # 87916
good deal?
http://richmond.craigslist.org/mat/2906312191.html
Old 04-04-2012, 05:37 AM   #56 (permalink)
B.A.R.K's Avatar
Member # 8540
Years ago my dad used 4'x8' sheets of durock cement board over gravel as a temporary shop floor before pouring the slab. You can get 3'x5' sheet at Home Depot for $10. There is a textured side and a smooth side. It can last for quite a while under normal use, but highly concentrated loads will make it start to crumble.
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB
Nothing is stronger than stupid...
B.A.R.K is offline   Reply With Quote Quick reply to this message
Old 04-04-2012, 01:16 PM   #57 (permalink)
Member # 87916
i was also thinking about pallets with plywood across the top, after thinking about it paver seem like a lot of work and not sure if anything would roll over them well.
Old 04-04-2012, 02:17 PM   #58 (permalink)
Member # 87916
made one garage door opener, not quite to my likeing but it will work, still 8 + feet under the door up which is way more than i had at the old shop.
Old 04-19-2012, 06:43 PM   #59 (permalink)
Member # 87916
fills up fast
Old 04-20-2012, 03:34 PM   #60 (permalink)
Member # 130003
Proves two things!
Buildings fill up FAST.
You can't build one too big.
Harold Phipps is offline   Reply With Quote Quick reply to this message
Old 04-21-2012, 06:13 AM   #61 (permalink)
Member # 129765
I like your light setup, I need to do something like that in mine. Man, I bet your meter really gets spinning when those things are on.
hydrogeo is offline   Reply With Quote Quick reply to this message
Old 04-21-2012, 01:34 PM   #62 (permalink)
Member # 87916
i dont know honestly, they use less juice than a regular 100w bulb and right now the shed and the shop are all running on 20 amp breaker (not ideal trust me,gonna change) and i havent tripped the breaker once. not even running my 4 hp air compressor (not one pictured)
Old 04-24-2012, 05:26 PM   #63 (permalink)
Member # 87916
started building a lean to today to house the 1300r and the air compressor. going to lay the roof on tomm. and yes i will add more joists as need be.
Old 05-10-2012, 04:41 PM   #64 (permalink)
Member # 87916
went on vaca for a week and just got started back, just about finished up the lean to. compressor is mounted and tied into the old shed via 3 4x4s and sided the lean to with some old decking i had off a deck we re did, the old look keeps the county off my back also put in a simple light for night time stuff if i need to go in there, they way i dont find a copperhead the hard way
Old 05-10-2012, 05:24 PM   #65 (permalink)
Member # 99927
too bad you don' work this well on any of your other projects!
kota4bye is offline   Reply With Quote Quick reply to this message
Old 05-10-2012, 05:41 PM   #66 (permalink)
Member # 87916
this shits simple and cheap!
Old 05-17-2012, 11:50 AM   #67 (permalink)
Member # 17042
Cool build and glad I could inspire you of the ways of tent garages.
As for a floor, I would go to a co-op or Tractor supply type place and get a few rubber floor horse mats. It'll give you a flat surface for rolling a jack on, keep you out of the gravel, and not rot or break like wood or pallets. Just a thought.
I like the light setup and I have to say that DAMN that's one big tent.
[QUOTE=Myanarchy;9475039]maybe if more kids got involved in projects we'd have less kids living in projects:flipoff2:[/QUOTE]
76scoutman is offline   Reply With Quote Quick reply to this message
Old 05-17-2012, 01:56 PM   #68 (permalink)
R290's Avatar
Member # 46467
I can see it in 5/10 years with metal siding, and concrete floor.
To stay out of the gravel, just use a sheet 1/2 ply wood. Got oil leaks? use cardboard.
edit: empty garage and rototill in some portland cement, water and pack. Not perfect, but it will hold fine.
73 IH Scout
R290 is offline   Reply With Quote Quick reply to this message
Old 05-17-2012, 02:04 PM   #69 (permalink)
Member # 87916
ive been thinking about a small cement mixer inside the shop and do a little at a time not draw a bunch of attetion to myself
Old 05-18-2012, 12:57 AM   #70 (permalink)
Member # 170546
you won't
SkooledMedic is offline   Reply With Quote Quick reply to this message
Old 05-18-2012, 09:44 AM   #71 (permalink)
R290's Avatar
Member # 46467
I would just leave it as is, this will allow time for it to age and look like it belongs there. Then maybe this fall think about the floor. Might be easier to just pour a concrete pan on top of the gravel. This will help keep ground water out too as it will be a bit higher. Still a temp structure on a concrete pad.
73 IH Scout
Old 05-18-2012, 07:24 PM   #72 (permalink)
Member # 129765
I wish I could stick my compressor outside like that, but it just gets too damn cold here in the winter.
Old 06-01-2012, 06:55 AM   #73 (permalink)
Member # 147440
Where did you buy this? Northern tool?
ffjosh is offline   Reply With Quote Quick reply to this message
Old 06-01-2012, 12:15 PM   #74 (permalink)
Member # 87916
http://www.shelterlogic.com/
Old 06-23-2012, 04:17 PM   #75 (permalink)
Member # 87916
today was the first day I really got a good solid day to work on my own junk in the shop, seems ive became the shop to work on your stuff if its raining
well now its just my stuff in there and its a mess
