Plasma cutter problem Hypertherm Max42 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-19-2012, 08:30 PM   #1 (permalink)
AllGoNoShow's Avatar
Member # 46318
I have an old hypertherm max42 plasma cutter. I used it a couple nights ago and it worked fine. I went to cut some brackets tonight, it will cut fine for about 3 seconds, then stop. Once it cuts out, I can hit the trigger again and it will go for another 3 seconds or so, then cut out again. I changed tips and still not any better. I took the handle apart and don't see any apparent problems. Anyone have an idea what it may be? I'm guessing something pretty simple, since it was working fine a couple nights ago.
Vote Trump 2016.
AllGoNoShow is offline   Reply With Quote Quick reply to this message
Old 03-19-2012, 09:54 PM   #2 (permalink)
JohnC's Avatar
Member # 3310
Got air pressure? I always forget the stupid easy things like turning on the compressor.
JohnC is offline   Reply With Quote Quick reply to this message
Old 03-19-2012, 11:47 PM   #3 (permalink)
Member # 46318
Yep plenty of pressure, but I'm a and forgot to move the ground cable, that was attached to my fab table... to the chunk of steel I was trying to cut, which was across the shop. Who would of thought it would still cut for a period of time, without the ground attached to the chunk of steel being cut. In short, I forgot to move the ground cable from my fab table to the chunk I was cutting.
Vote Trump 2016.
Old 03-20-2012, 01:19 AM   #4 (permalink)
Wyoming9's Avatar
Member # 113418
Smile
What you were getting is the pilot arc
It will pilot no matter where the work clamp is.
It was just not transferring to the cutting output.
Glad you got it figured out.
Wyoming9 is offline   Reply With Quote Quick reply to this message
