Member # 148059
Longevity plasma tig stick
Will the tig on this unit be adequate for my 2" .5 wall chromo links? I have never Tig welded, and am thinking this might be a nice unit for me. I am starting a buggy project, and am thinking this may be a good addition to the shop if the tig is good enough. (I already have an A/C stick welder, and a Millermatic 210 mig)
Here is the linkhttp://www.longevity-inc.com/product...ldMax-164i.phpWhat do you think? If I practice will the unit handle my .5 wall chromo links without issue? Last edited by Stonebone; 05-05-2012 at 09:31 AM. |
Member # 16829
Let us know how the tig welding goes with that Hypertherm.
![]() I've never tig welded with mine but it stick welds great. ![]()
Member # 50525
I have no experience with that unit, but I don't think 160 amps is sufficient for 1/2". I have a 165 amp inverter machine and would consider 1/4" to be the max for full penetration. (Insert small penis joke here
) Also be aware that a lot of the combo TIG machines have scratch or lift start rather than HF and no provisions for a foot pedal, which in my mind makes it less than a true tig machine, like using a Dremel with a cut off wheel rather than a 4.5" grinder with one...Mine has HF start and foot pedal capability, but even with that it is still very lacking by not having pulse and AC ability, so I am still going to have to replace it eventually. |
Dynomite!
Member # 86280
You can weld 1/2" with way less that 165 amps. You just bevel and run multiple passes. The specs on that machine look decent, but I can't speak to the quality. For me though I wouldn't buy a tig that didn't have ac and high freq, so I could weld aluminum.
#8 (permalink) | ||
Member # 148059
Thanks for the info. |
