PEBKAC
Member # 135367
Laminated 2x6's instead of 6x6?
I'm going to start building a pole barn style shop and was wondering if anybody's done the laminated 2x6's instead of treated 6x6s? I've built a few pole barns and we've always used treated 6x6's, but a buddy if mine had one built last year and the company used 3 2x6's glued/nailed together. I had never heard of this but after some googleing it seems to be the norm, and is a decent amount cheaper and supposedly stronger.
I did some searching on here but didn't come up with much so I figured I'd ask.
.,_________ //_|__l__\\___\ ____ l_/ \’ _|’ __/ \_ llllll _(o))-o-))(o))--o)) |
Paris Hilton Fan
Member # 11249
I used them on my shop build and they are fine. Only thing is, if they get wet, they have a potential to warp, but I guess thats with any wood.
They are actually a true 6"x6" post too and they are not usually just 2x6's glued and spiked -they are milled lumber glued spiked and then ran through a jointer to finish the outer dimension.
Read what I've learned about the Baileigh Industrial TN-250 I won here on Pirate4x4! http://www.pirate4x4.com/forum/showt...=tn+250+review |
Member # 44692
(3) 2x6 laminated together will make a stronger product in that you will have less warping and twisting than a single post, as well as not nearly the issue of the wood drying out and splitting. the load capabilities will be roughly the same for a like sized solid post or laminated.
the down site is esthetics of a single solid post is better than laminated with nail heads showing, as well as getting all the lumber to match up perfectly flush on all sides will be next to impossible without milling after it is built. if you are doing like mudzerk and getting rough lumber milled, glued and re-milled, basically a LVL idea post, then you will likely be the same cost as a solid post but with less/no warp/twist issues. Last edited by crimsen; 05-08-2012 at 10:16 AM. |
PEBKAC
Member # 135367
No milling, it will just be glued and nailed, I'm not concerned with looks so much as strength. It looks like the 2x6s would save me a couple hundred dollars so that'll probably be the way I go.
Way tougher than you
Member # 141446
Just remember that 3 2x6s is actually going to be 4.5" x 5.5" where a post will be 5.5" x 5.5". Not sure if this is an issue for you, it wouldn't be for me. But you better account for it during layout.
I carry a gun, because a cop is too heavy ECV 3-Lord Sholto Douglas |
Member # 189427
I don't know if it's the right way to do things, but i needed a beam when i took an interior wall down, and to make it the right width I glued and screwed a strip of plywood between the 2x8's to get the dimension i was after. Is this acceptable or does this weaken it??
#7 (permalink) | |
Size does matter. Leave the Zukes to those who really understand. |
#8 (permalink) | |
Member # 141446
Member # 149288
I am just about building a house, and that is the ONLY way that I would do the posts for the car port and for the front porch. All 6 posts are in the area of 16' long, and I was very worried about them twisting like I have seen 6x6's do so often. I used 1/2" plywood between each 2x6. I did this for extra strength, and to make them have the same dimensions as a 6x6. I would DEFINITELY do the plywood in the middle if I were you!
#10 (permalink) | |
Member # 44692
Adding plywood to increase the dimension is perfectly acceptable and common.
#11 (permalink) | |
Member # 141446
#12 (permalink) |
Member # 149057
Laminates are supposed to be much stronger and better than regular lumber. The huge pole barn local place uses them for all their buildings. I have a 30ft clear span garage done this way and have no issues with snow, winds and even a tree that damaged the roof.
#13 (permalink) |
Member # 141446
Your laminated beam is most likely an egineered piece of wood that you or your builder had to special order. We are talking about simply nailing 2x6s together to achieve a desired width. Totally different animal altogether.
#14 (permalink) |
shoes optional
Member # 142117
off topic, how big are you goin with this, if its 800SQft or less and you already have a pad poured why not just frame it normally rather than a big ugly pole barn that likely with have ugly sheet metal and no insulation...
framing walls is relatively cheap,plywood is cheap, and framing the roof is cheap by avoiding trusses. hell even hardi plank siding is cheao these days... |
#15 (permalink) |
Lights and Sirens
Member # 208882
SCREWS not nailed! And make sure they wont deteriorate in the natural moisture in the wood over time, I have seen many with the head of the screw rotted off and the boards separating.
#16 (permalink) | |
PEBKAC
Member # 135367
