Member # 181746
What to build out of a small lathe?
Hi guys,
got this lathe for dirt cheap and i`m not sure what to do with it. First i wanted to sell it, but i`l probably keep it... ![]() What should i build out of it? A badass notcher?
I'd rather die trying to live, than live trying not to die. |
Expert Web Wheeler
Member # 122722
no need for a small lathe i am assuming? my dad had an old jewelers lathe before he passed and it came in handy making litte odds and ends such as custom bushings bolts etc.
I mean you could easily make a notcher attachment also but i would not if it made it so you could not use it as a lathe after. |
Curious to hear ideas on this too, I've got a very similar lathe in a similar situation.
DD/Tow-rig: '06 GMC Sierra 2500HD Duramax Classic Rig: '88 FJ62, 100% stock In the weeds waiting for resurrection: '94 FZJ80, 33s, locked |
Member # 192237
Set it up with a die grinder as a toolpost grinder. Then when you want to turn hard things like bearing races you don't have to get grinder dust all over your nice lathe.
Might slick up the chinese ways a bit too, being coated in grinder dust.
I would agree with the toolpost grinder idea. They come in handy from time to time!
I took one of these: http://www.harborfreight.com/flexibl...ver-40432.html And drilled out a boring bar holder for my quick change toolpost to fit the grinder handle. Then I just hang the motor on a hook over my lathe and plug it in directly instead of through the variable speed pedal and start grinding! Works like a champ! Oh I also bored out the chuck on the little handle thing to accept 1/4 shank bits too... It only accepted 1/8 or 3/16 before. |
hate keeps me warm
Member # 151139
A mini cannon is a great project to get your feet wet with using a mini lathe.
There ain't no good in an evil-hearted woman And I ain't cut out to be no Jesse James And you don't go writing hot checks down in Mississippi And there ain't no good chain gang |
#9 (permalink) | |
Biohazard
Member # 3088
I'd make a notcher if you need one. A large roughing endmill in the chuck, and use the cross slide to feed the tube in.
Wanted, Ak parts, kits or whole rifles! |
#12 (permalink) |
Member # 181746
I already have a notcher, but this is a lot more comfortable to use...
But, i decided that it`s not worth it. I`m going to sell it, to raise my funds to buy a mill...
#13 (permalink) |
Trailbusters4x4 club
Member # 117547
lot of the professional chassis builders use lathes for notching. work good and make good looking cuts.
83 toy pickup, 02 TJ, 02 GMC 2500HD Trailbusters4x4 club Solano County Dont blame me i voted Republican! ECV 1004 |
#15 (permalink) | |
Biohazard
Member # 3088
"A large roughing endmill in the chuck, and use the cross slide to feed the tube in. "
In this case a hole saw, but everything else is the same. There's really not much more to it
#17 (permalink) | |
Whatever Works
Member # 128472
In high school we made bongs...
Samurai Build on a Low Buck Budget: The Tin Can Quote:
#19 (permalink) |
Member # 7588
I would think that it comes down to a guy figuring shit out for himself by doing it... obviously the holesaw needed more spacing to clear the chuck on angle notches
1948 Willys 1952 M37CDN Powag |
#21 (permalink) | ||
Member # 32464
I only see one bolt holding the tube holder in place? Any trouble with it moving on you as you feed the tube in? Is something else there we cant see? Speaking of the tube holder, is it just some square "tube" the tube fits in, I would think it would want to rotate if only held in place by a jam bolt which could also scar up the tube being notched? I understand the concept, yes it can be built from the pics. |
#22 (permalink) | |
Member # 130300
#23 (permalink) | |
Member # 181746
The tube holder is some scrap welded together to a somewhat "square" tube with an angle iron where the tube is pressed against...
