Swag Sales
Member # 90594
In Ground - Air Over Hydraulic Lift *Tech*
I just bought a house that has an awesome garage. It has a two post, in ground, air over hydraulic lift.
![]() About half the people I talk to say they are very dangerous. I would like this thread to disuse:
Oh kay, From what I can tell my lift is a Global but the numbers on the seals don’t match anything I can find. Problems I am having:
I can put your business, personal and/or club name on shirts, hats, coolers, koozies, pens, jackets and more! Just ask! Get with me on your industrial safety needs as well! Andrew Dial Jedco Sales Inc. jedcosales.com PM me or email andrewd@jedcosales.com We are family owned and in our 30th year! Big enough to get great products and prices. Small enough to know who you are! |
Member # 4251
First of all, until you get it "safe" Stay out from under it when moving and block it up with something that will support the combined weight of the lift and truck to work. That will at least keep you from being crushed.
![]() There was a really good thread over at garage journal that dealt with a guy rebuilding an old garage that had a similar lift. He excavated the thing and rebuilt it before putting it back in service. It had a huge thread and might even be a sticky. I'll try to find it. Edit: Found it! 1930s garage
Details removed for clarity Last edited by Johann; 09-13-2012 at 09:32 AM. |
Bobbing for Fries
Member # 190574
I've used these in the past, it was an in ground two post. When it would shoot up unexpectedly, that meant it was low on oil. I cant think of the manufacturer right now. Yours may be set up differently.
To lock it in the "up" position I used a block of wood to hold the air valve open . There should be some type of foot or lever near the base of the ram that flips down when its all the way up. Some have a safety that looks almost like a ladder, along side of the ram, so you can set the lift at multiple heights.
If everyone is thinking alike, then somebody isn't thinking.
#5 (permalink) | |
Member # 45530
![]() ![]() ![]() ![]() ![]() ![]() had to quote that. That's one of the most amazing things I have ever seen... |
We see our fair share of those junk in ground lifts...90% of the ones in the Wash DC/Baltimore area get put out of service. The hydraulic tanks are in ground and often time develop cracks allowing water in or hyd oil out. Get some better pics of it without a rig on it.
Your rapid up or down sounds like air in the cylinders and or low hyd oil. Depending on the type of lift, there will be a bleed screw, usually flat blade. It will either be directly on top of the cylinder if there is a access hole or on that big ring where the seal is in the floor. With the lift up half way empty, crack that line and let the air bleed out...and work it a few times and re do if need to. Those two little rods next to the cylinders are your lock rods. Usually you need to go up 3-4feet before they will even engage. should be a simple peice of steel that flips out.
94 Grand Cherokee-5"-6" Lift, 39.5 Iroks, D60's, 5.13's, some tube work and lots of cutting... |
For seal replacements, Simple job, for seal parts, we use colliflower, but couldnt tell you if have one out there.
For topping off oil, either top of the cylinders or in the ground there will be a 1.5-2" plug for filling. sometimes with a dipstick, most of the time not. Rick
#9 (permalink) | ||||
Swag Sales
Member # 90594
![]() Quote:
I don't like my in ground lift this much!!!!! lol (from the 1930 garage thread)
Member # 192237
We used these in my HS auto class. They were probably from the '60s, and that was last year.
![]() The surging is likely not enough fluid as others have said. If it shimmies up the leveling cable is loose, they've usually got a couple inches of adjustment on either side. WHEN THE CABLE WEARS OUT DO NOT PULL IT OUT FOR REPLACEMENT. It is a bitch to get it back in there. Get a new cable ordered and attach them end to end, then pull the new one through. Figure out a way to use a fishtape if you need to get a measurement. The ones we had didn't have latches, but there were slots in the anti rotation tubes [that also housed the leveling cable] at the top of the travel. I guess you could toss a piece of bar stock through, but that never got done. If it doesn't hold a car up for days on its own you need new seals. We'd park cars crossways under cars in the air on those lifts over the weekend, nothing but hydraulics holding them up.Your fluid will look milky, it collects water from the huge amount of air in contact with it. The seals in ours only failed once in the 4 years I hung out there, and a reseal on the ram wasn't too bad, 3-4 hundred IIRC. |
Swag Sales
Member # 90594
Check valve. Push to lower
![]() Here is the valve to add air and dump air to the tank ![]() The tank ![]() The lift has arms that go on it. ![]() This part of the safety? I think these metal bars with the teeth are connected via a shaft underground to keep the two rams even.
#12 (permalink) |
Swag Sales
Member # 90594
Plug in the floor. Bleed plug or add fluid plug? It needs oil, do that with the lift all the way down?
![]() ![]() These rods were laying by the lift. I assume they are the safety? Problem is there is only two holes and they are only useable when the lift is all the way up. ![]() We used it to pull the t-case on my jeep. We lifted it up, ratchet strapped it to the lift and let it sit over night. It held up all night. ![]()
#13 (permalink) | |
Member # 207169
#14 (permalink) | |
Member # 192237
The tank probably has a fill plug in the top. Fill with lift down and all air pressure released. Maximum fill level would be pretty much full. Just keep adding juice until the thing acts full, then an extra 2 gallons for good measure. |
#15 (permalink) | |
Swag Sales
Member # 90594
They are like this ----->
#16 (permalink) |
Member # 104430
First COOL yer a Luck sob
![]() Have used the LARGE single ram with anti rotation pole. The anti rotation pole had holes drilled in it and if you wanted to you would slide a rod through like you did in your pictures. As for the dogged bar, there is IIRC a mechanism that locks into those. Take a look under that plate that the bar goes through. Take and fill it with it down. I have pulled a couple out of the ground..it sucks...LOTS Of oil in the cyl I tell ya! |
#17 (permalink) |
Member # 110491
My friend's dad has one of these but it is a one post lift and it doesn't have any safety or anti-rotation like was said above. I had no idea these were dangerous and I've had my Jeep up there a bunch of times to work on it. That said, I never had any problems with his and he has had his quad cab Cummins up there a bunch of times so I'm sure my Jeep is no big deal.
norcaljeepers.co |
#18 (permalink) |
Swag Sales
Member # 90594
I put 2 gallon of 46 hydrolic fluid in it and it is acting better. Still goes up and down uneven when ou first start to move it. one it is moving it stays even
#20 (permalink) |
what about talking to an elevator mechanic? has to be the same principal as a hydraulic elevater?
Ryan Morgan Tow Rig = 2006 Chevy Silverado 3500 Rock Toy = 1973 K5 Buggy Automatic Gates by Morgan and we are on Facebook too. Who is the FOTR? Who is the RTF? |
#21 (permalink) | |
Swag Sales
Member # 90594
Im not sure where I would find one in the middle of BFE Illinois
#22 (permalink) | |
Member # 192237
When it gets loose it'll shimmy a bit, you can tighten the cable ones, try looking for a removable cover to look at yours and try to adjust it tighter. |
