might pick up a lincoln 180 hd used - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-18-2012, 10:37 AM   #1 (permalink)
Member # 164241
I'm gonna try and get it for 250 I see them going for about 550 online. Any one have experience with these or bad news. Just wondering if it worth the deal.
morethrottle88 is offline   Reply With Quote
Old 09-18-2012, 10:50 AM   #2 (permalink)
robert-r's Avatar
Member # 38318
I had a 175 HD for several years.
It worked well.
$250 seems a little low. I'd check it very carefully.
ROCKING DEAD
robert-r is online now   Reply With Quote
Old 09-18-2012, 02:30 PM   #3 (permalink)
Member # 113418
Wink
just know that model is built for places like Home Depot and who ever else sells to the hobby market.
They can`t even be bought by a welding distributor.
Make sure it works and you have full range and control.
It is cheaper for a reason
Wyoming9 is offline   Reply With Quote
Old 09-18-2012, 02:42 PM   #4 (permalink)
Member # 164241
It's cheap cause I'm a Jew lol. I'm getting it from a buddy who got it for Christmas and used it a few times. 250 will be my offer. No guarantees ill get it that cheap though
Old 09-18-2012, 04:34 PM   #5 (permalink)
angryblack's Avatar
Member # 142394
They are cheaper because they use way more plastic in the mig gun..Plus the liner is cheaper plastic.. Other than that its primarily the same unit
Unfortunately there is no end to human stupidity -- making things foolproof only creates more ingenious fools
angryblack is offline   Reply With Quote
Old 09-18-2012, 05:46 PM   #6 (permalink)
Member # 207169
I have a Lincoln 3200HD unit and it comes with magnum 100l mig gun but the drive assembly is all plastic which I am not fan of ...
TorqueRanger is offline   Reply With Quote
Old 09-18-2012, 08:29 PM   #7 (permalink)
Off the shitwagon
SkooledMedic's Avatar
Member # 170546
I've said this a million times, don't waste the money on a low end machine. They're barely good enough to do anything over 10 gauge and even then you'll hit the duty cycle like its your job.
SkooledMedic is offline   Reply With Quote
Old 09-19-2012, 05:07 PM   #8 (permalink)
Member # 207169
I fully agree with you....
I am a 6th generation welder and the only reasons I bought such a cheap welder because I had no one to teach me and this was my first welder and wanted to make sure that I would really use this thing ... But I have learned that it pays to quality equipment and my next purchase will be a miller 211 or bigger from miller ...
Old 09-19-2012, 06:58 PM   #9 (permalink)
Member # 155913
I've got the Lowes version. It's identical to the Lincoln SP180T. The Lowes model is packed for Lowes with a different control bezel as is the Home Depot model. Same welder, though. There is more plastic in that model (and the 180T) particualrly the drive rolls. This is from calling Cleveland before I bought it and also directly comparing the two. I've had it for five years and have done several cars and cages at this point. It easily does better than 10 ga. I've only had duty cycle issues on 1/4" plus on the trailer (.035 flux core), then I went to the stick on my Sq Wave 175. It's a great little machine.
The next step up is the Power Mig 180C. Metal drive system and continuously variable heat control. According to Lincoln, same electronics as the other 180 amp machines. You'll find one of these on nearly every NASCAR or Indycar hauler. They mount them on a hand truck with a 40cu ft bottle. Pretty neat. I've got a pic somewhere of it.
vegasloki is offline   Reply With Quote
Old 09-20-2012, 11:25 AM   #10 (permalink)
Member # 164241
Well I'm getting it today. I know its cheap and gay and blah blah blah. But for 250 dollars fawk it. I can sell it later for more money. Thanks for the info gents
Old 09-21-2012, 12:10 AM   #11 (permalink)
Member # 164241
Got it
Old 09-21-2012, 05:17 PM   #12 (permalink)
J&L Fasteners Expres
J&L Fasteners's Avatar
Member # 227935
A buddy of mine bought one of those used for $100, I've welded with it plenty of times. Its a fine machine for the price, as long as you aren't trying to use it for production. However there is a drastic difference between that machine and my Miller 180 and I haven't welded with a smoother machine than my 350P but neither of those are $250 either.
Just be sure to run good clean wire through it. He had a harbor freight roll of wire in it that didn't want to run through it. The Lincoln stuff from Home Depot seems to run fine though.
Is it possible to swap in metal drive rolls?
J&L Fasteners Express
Get 10% off on our website using promo code "Pirate10"
J&L Fasteners Express eBay store!
Facebook
Mike Baum
Mike@JLFastenersExpress.com
J&L Fasteners is offline   Reply With Quote
Old 09-21-2012, 05:42 PM   #13 (permalink)
robert-r's Avatar
Member # 38318
Just curious.... have you owned or operated this machine?
ROCKING DEAD
Old 09-22-2012, 04:57 AM   #14 (permalink)
BESRK's Avatar
Member # 26393
I rocked a Promig 175 for a few years.. built sevaral cages, dozens of bumpers...etc. Only thing I had to do to it, was change the liner.
I email Lincoln a few years ago. Asked them about the differences between the Models in the same Amperage category (ie.. pro, sp, hd... et). The reply email stated that mechanically, there was no difference. It was simply a difference in naming them for the various distributors.. other than that, same machines.
Little CJ5 on 35s.
BESRK is offline   Reply With Quote
Old 09-22-2012, 09:54 AM   #15 (permalink)
Off the shitwagon
Member # 170546
I borrowed one for six months while saving/deciding what kind of welder I was going to get.
originally I was going to get a 180amp machine but I hit the duty cycle so often and was so limited in what I felt it was capable of doing I opted for a Powermig 255.
that being said for $250 I would definitely pick up a 180amp machine purely because they are far easier to transport than a 300lb machine.
Old 09-22-2012, 03:23 PM   #16 (permalink)
Trailbusters4x4 club
FuzzyZ's Avatar
Member # 117547
I have the Pro Mig 180C also and its a great welder. I agree with not getting the lowes/home depot version 180T. Its a lot less quality machine. The 180C will do what ever any normal garage mechanic will do.
83 toy pickup, 02 TJ, 02 GMC 2500HD
Trailbusters4x4 club Solano County
Dont blame me i voted Republican!
ECV 1004
FuzzyZ is offline   Reply With Quote
